06-08-2012, 08:37 PM | #301 | |||
Trader Rating: (58)
Feedback Score: 58 reviews
06-08-2012, 09:02 PM | #303 | |
And I could always just run the turbo at low pressure until I get better and gradually work it up. I'll be sticking to 10psi or so at autox for a while and only bring out the big power for the occasional drag run. |
06-10-2012, 10:06 AM | #304 | |
To get to one bolt, you have to remove 2 other bolts. Once oriented for top mount, there is at least one bolt you can never get to without taking it all apart again to tighten that bolt. |
06-10-2012, 10:13 AM | #305 | |
If your dead set on an EFR buy the fullrace manifold and save yourself the pain. Buy the Garrett and save yourself even more pain. |
06-10-2012, 11:38 AM | #306 | |
Efr powered sr20det startup! - YouTube It's obvious that a GTX2867 is the easy choice (and still a great one performance-wise) but making the best choice is what I'm concerned about. I probably will wind up with GTX2867 anyway but for cost and reliability, not ease of use or performance. If I had a bunch of money that I could drop on a $1k full-race mani and replace my turbo if it blows then it would be a different story and I'd be leaning more towards EFR. |
06-11-2012, 10:31 AM | #307 |
I have a gti-r manifold on my shelf you can buy to confirm the fact it doesnt fit. Yeah ive seen that video too. ive also got a video of mine running on a top mount. in my shop. on my car. installed by me.
My manifold was less than 500 but modified to accomodate the efr's giant ass. |
06-11-2012, 11:41 AM | #308 | |
And thanks for confirming the FWD manifold wont work. e1_griego, any dyno updates? |
06-11-2012, 11:57 AM | #309 |
Attempts at bottom mount got to aggravating. Top mount slightly less so. The flange still had to be cut off and reattached. I had to change the flanges position on three axis's(sp?) so it would fit. The garrett was pretty much a drop on. You need the understand the EFR is big and uncooperative. The Full race price wasn't the issue, I'm a DIY'er. First I put this motor in a BMW. Then I made my own harness, attached a laminova liquid to air intercooler from a Cobalt SS, and made my own BBK using Dodge Stealth 4 piston calipers and rotors from an MG TF from britain. My diff is a Z3 BMW Torsen center with 4.27 gears from a euro 525i BMW. The entire hot pipe set up I have now I put together from Volvo, Saab, and junkyard intercooler pieces.
06-11-2012, 12:02 PM | #310 | |
06-11-2012, 12:10 PM | #311 | |
Trader Rating: (24)
Feedback Score: 24 reviews
The tune is safer than it was which was the primary purpose of retune to begin with . The orig tune was from my gt2876 two years ago which did 345/303 on a dynojet @14psi, so these new numbers seem right to me. Gonna try to head back to the same dynojet for an apples to apples comparison, and hopefully get the boost creep addressed. |
06-11-2012, 12:18 PM | #312 | |
And that's pretty great that a 9mm smaller compressor is about the same considering the creep and dyno differences. That really speaks well of Garrett's new billet design. I look forward to your creep-free dynojet results! |
06-11-2012, 12:21 PM | #313 |
Trader Rating: (24)
Yeah, hp/tq.
Really the best part about the turbo is that if you apply throttle it makes *some* boost. A couple psi at 2k rpm really helps get things going. Full boost is still around 3500-3700 (vs 4200ish with the 2876) but it just seems much faster to get there. Hoping that is more obvious with the dynojet runs. |
06-11-2012, 01:23 PM | #314 | |
And is there any way you could get us some time to torque info on your next run? I know codyace is a big fan of that and so am I. There just really isn't any better way to measure a car's response since rpm to boost or time to boost doesn't say anything directly about what kind of power the car is making. Also, I'd love to see an overlay of your 2867 graph on your 2876 graph. Judging by what you're saying, I'm guessing there's gonna be a big chunk of area from 2-4k or so where you're putting out a good amount more torque with the 2867. |
06-11-2012, 05:34 PM | #316 | |
You'll still have an awesomely fast car but about 30whp less awesome I would however suggest some cams. Not only will you gain power but you can tailor the power to how/when you want it which is the real benefit IMO. |
06-11-2012, 06:56 PM | #317 |
I was looking at the Tomei Poncams and the JWT S3 cams, which would be more beneficial to this size turbo? And which would would cater to faster spool? I really only want 350whp, I just want it as early as possible and sustainable. Im all about area under the curve.
-Kyle |
06-11-2012, 07:51 PM | #319 | |
06-11-2012, 09:13 PM | #320 | |||
Trader Rating: (58)
Call me the fanboy, but there is a reason the JWT S3/S4/C1 cams have (for more than a decade) been the cams of choice for the SR20.
06-11-2012, 09:56 PM | #321 |
If going the tomei vs. s3 route, what additional parts need to be installed along with the cams to make them work. retainers? Valve springs? Rocker arm stoppers? Etc... Im not sue which power band is more appealing to me now either. Ive always strived for low to mid range power, but after spemding some more time at the drag strip, it sure leaves me wanting more up top.
And what kind of additional power can you honestly expect from each set of cams?
-Kyle |
06-11-2012, 10:02 PM | #322 |
I don't think so in my case. I got some greddy valve springs for a killer deal with se crowed retainers so I'm set with valve train parts. HKS cams are soo hard to find now. I did find a set for $525 so yeah.
06-11-2012, 10:32 PM | #323 |
Trader Rating: (58)
JWT S3 and S4 require no other additional valvetrain modification. Pon-Cams also do not, but PRO-Cams do.
In the grand scheme, think of where your car 'lives' in regard to RPM. I too used to think the 3k-5k area was king, but in the grand scheme of things, I'm never below 4000/4500 on track...so why build around an area that I don't use? I'm all about response, but if you're only gaining 100-200 rpm of spoool, and disregarding 25-30 hp up top, you're doing it wrong.
06-12-2012, 03:07 AM | #324 |
hey Codyace, eventhou jwt s3 cams does not require additional parts for it to function, what would you recommend me to change along the valve train? valve springs? retainers? im developing the vtc ticking noise now and gonna get a new vtc intake gear soon. Is it really worth it to not change the cam gears?
06-12-2012, 04:51 AM | #325 |
Correct me if im wrong Cody but, I believe JWT S3 cams do not retain the VTC function... You honestly cannot and will not beat the VTC function down low with a set of non-VTC cams. It hits hard and makes gobs of torque down low where you want it. I've never understood why guys want to remove that function.
06-12-2012, 05:11 AM | #326 |
hmm i remember that jwt s3 does retain the vtc function as it is direct set of drop in cams. I read it in the 2871r thread here in zilvia too jr_ss.
Sorry codyace what is the other forum for the fwd sr20's? looking into a used sets of s3 :P |
06-12-2012, 07:25 AM | #327 |
I'm pretty excited about this turbo though, Im glad to see people are having success with the new GTX stuff over the 2871.
Where are you guys getting the 2867 from? And where do I get a proper turbine side for it? Internal gated turbine side available?
-Kyle |
06-12-2012, 07:34 AM | #328 |
It uses the same turbine housing as other GT28XX turbos, so yes, there are internally gated options. This also means that anywhere selling GT28XX parts will have what you need. ATP would probably be a good start.
06-12-2012, 05:04 PM | #329 | |||
Trader Rating: (58)
JWT S3 cams require no (zero/zilch/nada/nothing) additional modification on a stock valvetrain. Again, for over 10 years guys have been banging valvetrains off 7850/8000 RPM with them, and never having any spring or valvetrain issue (maybe aside from missed shifts and making rocker arm salad) Quote:
SR20 Forum G20.net - Forums Any of those should help you out. Just remember you want regular S3's, not S3M (mechanical) or the S3's for Roller Rocker Engines (b15's and newer p11's) As stated, it reuses the original housing, so yes itnernal gate. Unless motorsports driven, I'm not sure I'd change things, but for a track guy...it's worth the penny. The time into boost is reduced like mad.
06-12-2012, 05:12 PM | #330 |
On the topic of turbine housings, what's the going rate to have a gt25xx turbine housing machined into a gt28xx housing?
I'm looking to machine a gt2560 specifically. Got any solid numbers on that? I'm curious exactly how much of a difference an external gate makes since I've never really known for sure. What kinda hp/tq did you pick up too? And is the time into boost difference just because of internal wastegates blowing open slightly before boost? If so, would that be fixed with a good boost controller, a stiffer wastegate and/or preload on the wastegate? |
gt2871, gtx, gtx2867r |
