![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
Got everything mounted...doesn't look the best, but is functional for me. SR swap hopefully within a month or so, so I will actually be able to use them
Yes, I do like it. The gauges mounted up top above the steering wheel (Boost and Oil Pressure) I felt were more important to keep my eye on. But the other three along the shifter/passenger area (Oil Temp, Water Temp, Air/Fuel) I didn't want all up in my face on the dash (although functional) and didn't want to fill my dash with holes to run the wires.
As far as passengers go, my roommate complains slightly that they get in the way, but I sat in the seat myself and personally have no problem with how they are mounted. Yes, it does take away from letting the passenger lean their knee on that area, but there is still plenty of space for someone to fit comfortably. As far as I'm concerned, having the gauges where I want them and where I can comfortably see them is more important than how comfortable my passenger is haha. So yes, I do like how it is set up, since all I have to do is glance down for a second to check them and they aren't all bright in my face. As long as you keep the passenger seat fairly far back, I'm sure you'll have no problem with that as well. Hope this helped. P.S. I'll post better pictures once it stop raining and I get a chance to get outside. I also need to re-ground the air/fuel gauge haha. |
#5 |
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Installed my new tach on the right there today. Can't seem to find the right tach signal wire though so it's just sitting there right now. Would have put it in the ATI steering column pod but it was 60mm instead of 52mm like I thought.
BitDestroyer.com |
#6 |
#10 |
![]() Join Date: Jan 2007
i do agree that u should at least have a water temp gauge and oil pressure .. those are the most important ones .. i just had my laptop with me and it would show me all of them AEM EMS knock,water temp.. and so on but here is my lil ugly gauges ...
not the best pix but okay ![]() and a friends <a href="http://photobucket.com" target="_blank"><img src="http://i21.photobucket.com/albums/b274/Studgus/two%20thousand%20five%20to%20two%20thousand%20seve n%20june/IMG_8309.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a> ![]() and can someone please tell me what part number it is for a s13 ? and what color that guy has on here http://www.superbrightleds.com/ |
#11 | |
#12 | |
![]() Join Date: Jul 2005
WIll the 4led/6led fit or no? |
#13 | |
http://www.zilvia.net/f/showpost.php...1&postcount=58 This post shows which ones I used. I get good, even illumination out of them, but they could be a bit brighter. I'm thinking about ordering some white ones, as the data sheet shows them as being brighter than the blue ones. I've also seen some that don't have any lens on them at all (not even the bullet-shaped one on most LEDs), just a bare diode on a bulb base. Don't remember where they are from, but I saw them on hidplanet.
#15 |
#20 |
![]() Join Date: Oct 2007
anybody know if 60mm defi gauges can be fited like so ... i think is set-up is with 52mm gauges
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 Last edited by rbs14kouki; 07-12-2009 at 11:38 PM.. |
#24 | |
Screw the CF piece, How much were the pimp sheets? Those are straight baller status.
#25 | ||
![]() Join Date: Aug 2006
haha.. that's Aladdin mayne. |
#26 | |
#28 | |
they are fuel pressure water temp oil temp oil pressure boost waiting for EGT then in the middle gona make a 60mm hole for the tach all STRI X-line gauges Kognition Design CF gauge cluster panel. |
