#3361 | |
![]() Join Date: Jun 2009
![]() Feedback Score: 7 reviews
im just confused because i have read that altering the Voltage on the MAP signal will screw everything up instead of fixing the issue trying to see if anyone on here has any experience with this. |
#3362 | |
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
#3363 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Depends on your location as well, or else you're paying shipping. It took me 8 months to find one under $650, and that still came with no clutch, flywheel, bell housing, hub, fork, shifter extension. NADA.
#3364 | |
Now on ToyMods I found out that once you go single turbo and you run a new relay to run switched 12v power to the fuel pump and no longer letting the ecu control the pump that all you have to do to eliminate boost cut is to take the hose of the map sensor and block the hose with something and leave the sensor plugged in and that will take care of boost cut. Many have confirm that this works and they have no issues. I'm in the process of putting my engine back (with a single swap) in so ill get back and leave some feedback on this matter. |
#3366 |
#3368 |
it will work with both, it all depends on how you wire up the engine, I would run a relay for just the fuel pump though, to keep the ECU from controlling it.
#3369 | |
![]() Join Date: Nov 2006
![]() ![]() ![]() Feedback Score: 0 reviews
never seen a r154 this cheap here and when they are cheap they dont have a JZ bellhousing or they are damaged. The market for those transmission where I live is around 1500$ and in great shape 1700$.....crazy price if you ask me... |
#3371 |
![]() Join Date: Jul 2007
Trader Rating: (18)
![]() Feedback Score: 18 reviews
^LOL I have that same Super Street magazine on my coffee table right now. Nice.
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
#3373 |
#3375 |
#3376 | |
Zenki s14 1 J Z- G T E |
#3378 |
![]() Join Date: Feb 2007
who runs a swirl pot?
here is a question for you guys. on my sr's i've always run the return to the lower rad hose using a buddy club hose adapter but the 2j water pump has a nipple right after the thermostat on the back of the water pump. (in the pic below it's capped) my question is can i just run the return right to that nipple? (i don't need it anymore, i would either use it for the swirl pot or cap it) ![]() |
#3382 | |
Thought this was supposed to be the ugr lambo killer?all money spent on this thing it seems like it hasn't been running that long and already getting rid of it. |
#3383 |
so if my research is correct, this is the map sensor plug and the sensor is missing from my swap. or is this the "turbo pressure sensor" plug. or are they the same thing?.... anyway, whatever it is whats the cheapest/ best way to find a replacement?
Zenki s14 1 J Z- G T E Last edited by 93egallmotor; 01-25-2014 at 11:33 AM.. |
#3385 |
sorry for the confusion, im missing the SENSOR lol not the plug. those pics are of my plug. im looking for info on what map sensor i need to buy
#3386 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
2JZGTE Swapped S-Chassis thread
Oooo gotcha I'll take a pic of mine later but I think you can find one online for cheap ![]()
#3387 | |
#3389 | |
What engine mounts did you use? s13 or 14? Hood clearance?
#3390 |
I used Get nuts lab mounts on an S13. I have not put the hood back on but, there is no way there will be any clearance lol. also my GodSpeed sway bar does not clear either. this mounts push the motor really close to the fire wall.
