12-11-2015, 08:15 AM | #1 |
11-30-2015, 07:16 PM | #2 |
I'm trying to fit 18x9.5" +25ish rota p45rs onto my fronts on s13 body.
I'm assuming I would need to pull my fenders or buy overfenders. I currently have no mods except for section coilovers with camber plates and 15mm spacers. Is it possible to fit these p45s on? If I left out any info, let me know. Just curious as to whether I may need to buy aftermarket steering or suspension parts before I install everything. |
11-30-2015, 10:39 PM | #3 | |
Follow me on Instagram or don't @cason880 |
12-19-2015, 08:11 AM | #7 |
run 225-45-17 0* and you will be fine. Those are wide enough to fill the wheelhouse, and offer just enough sidewall angle that they will not rub with a '0' fender gap(lowered to be even with the tread)
12-21-2015, 10:10 AM | #11 |
What are peoples opinions on Cosmis Racing wheels?
Anyone have an appropriate fitment for the front/rear with stock fenders? (s14, Rolled inner lip) I know Enkie RPF1 18x9 +22 (front) & 18x10 +38 (rear) with fat 255 and 275 tires fit (not sure if that really helps) |
12-29-2015, 04:56 PM | #12 |
Glad to see this thread is still going strong. Good to see members help one another. Maybe I'll get another s13 and get back in the s chassis loop again. Ha
http://thatistupid.tumblr.com/ |
01-02-2016, 10:40 AM | #13 |
Ok looking into ....MBBattles plan is 17x9.5 +15
First off in rocking the s13 with an aftermarket coilover right now... No clue what is is And the from z32 brake upgrade So 1 with the rim clear the brakes? And 2 do I need to space due to the coilover And what size tire should I run And to wrap all this up I am 10000% noob when it come to tires plz treat me like a retard Thanks! |
01-02-2016, 11:48 AM | #14 | |
MRP Manufacturing |
01-02-2016, 05:58 PM | #16 |
Yes, you will still need it especially in the rear
MRP Manufacturing |
01-03-2016, 12:33 AM | #17 |
Are there a set of MBBattles that require no modification? Aka no rolling or camber? I honestly do know if my fenders are rolled but I wana stay away from modification
01-15-2016, 06:20 AM | #18 |
If you want MB Battlee's or Weapon's, the 17x9 +15 will reequire no modification...but you will have to stay about 1/2" UP from the tire, ie, NO LOW for you. With a simple roll from 10 - 2, you can drop those all the way to the edge of the sidewall
01-14-2016, 07:05 AM | #20 | |
On a different note, this question is for everyone using an 11.5" wide wheel in the front: what kind of caster settings are you using and what/ how much work did you have to do to the inner wheel wells up front for clearance? |
01-22-2016, 07:01 PM | #21 |
Just tried test fitting my new wheels I bought them because of a really good deal
Here's the setup Work Vs-xx 17x9 +36 17x9 +47 Looks like I'm having some rubbing/clearance issues on my coils Would I be fine with Ichiba ver 2 spacers 25mm all around? Or What do you guys suggest?? This would be going on a s13 coupe |
01-23-2016, 10:12 AM | #22 | |
Perfect fitment on any stock s-chassis is 17x9 +15 This fitment fits all years on stock suspension, or lowering springs to a 0 gap, or coils down to a 0 gap with no need for roll or pull. Knowing these measurements, you can now say your WORKs will fit easily with Front spacer should be ~20mm spacer Rear should be ~35mm You can also go 15mm front and 25mm in back and you will be ok, but you will tuck a lot more. the 20mm/35mm will make it close to flush
01-23-2016, 09:09 PM | #23 | ||
Thanks guys for putting it into perspective for me! |
01-22-2016, 07:41 PM | #24 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
You can easily run a 30MM spacer up front and a 25MM spacer in the back.
What kind of tire sizes were you planning on running? |
01-27-2016, 06:30 PM | #25 |
Have a s13 silvia. Wanting to run 18x11 in front and 18x12 in rear with 55mm front and rear fenders. What offsets would I need. My car will have tubbed front
Sent from my SM-S975L using Tapatalk |
02-01-2016, 03:28 PM | #28 |
You should be fine. I had a 9.5j -5 with the same tire size recently on my s13. According to willtheyfit you'll be 7.4 mm towards the strut and 5.4 mm closer to the fender. I had full camber on my coilovers (Pbm) and had more than 7 mil extra space to the fenders and more than 5.4 to the strut as well. I can't comment on rubbing at lock but I didn't rub with my size at all. No tubs but I have beat that area pretty substationally too.
02-03-2016, 04:59 AM | #30 | |
http://www.rimsntires.com/specspro.jsp
