12-01-2010, 06:44 PM | #3541 | |
12-01-2010, 07:04 PM | #3542 |
^^^ they will. you are going to need like a 1 inch spacer to clear your coils. but other than a good pull once they clear coils...and you should be good.
12-02-2010, 08:49 AM | #3543 |
I know this is a n00b statement but hopefully the question is what isnt. In a couple years after i graduate and have a good job I plan on doing a full ka build and i plan on doin the crower stroker and bigger pistons to make it a 2.6 with a bullseye s366xl t4 turbo (a/r selections are .9, 1, and 1.05). shootin for 6s but hopin for 7s on e85. Question: rb25s and 26s spin bigger turbos easier than a ka or any other 4cyl would (like say a t51 for giggles); is it because its a 6cyl or is it because of pure displacement which would mean a "ka26" would spin the bigger turbo roughly the same. My fault for making it long but I have done my homework on the ka and the cost it would take for the build just not on the question. Thanks!
12-02-2010, 09:21 AM | #3544 |
For s14s, are the connectors for the headlights, signals, and sidemarkers the same between the zenki and kouki? ei... would it be plug n play for a zenki headlight wire harness into a kouki. Wondering because previous owner cut my headlight wiring for an HID setup and I want to return to stock.
12-02-2010, 09:37 AM | #3545 |
can someone help me figure out my problem?... i have an s13 sr20det, just replaced the headgasket, no start
here's the thing, normally TDC is suppose to be the 2nd notch from the left... mine was the 2nd notch from the right. Thats where it was when it cam gears/silver gears meet up also I think that i have the CAS in wrong and i need to pull it back apart... or is something seriously effed up and i need to tear back into it? |
12-02-2010, 12:58 PM | #3547 |
i'm pretty sure my intercooler is leaking, and i can visually tell where it is.. its near the very center of the intercooler and about an inch of the row is bent in.. i can see little holes.
is there any way to repair this? its a greddy one.. and i dont wanna shell out $500+ on a new unit |
12-02-2010, 02:33 PM | #3549 | |
http://zilvia.net/f/tech-talk/187760...-flywheel.html You didn't look hard enough |
12-02-2010, 02:34 PM | #3550 |
any one use this site for SR motors just got mine from there JDM ENGINE SR20 TURBO S13 Red Top 91-93
12-02-2010, 03:26 PM | #3551 |
i searched, so shut the fuck up if its been asked before. My transmission fill plug is frozen, the nipple is starting to round out but has a few spots left where a vice can grab on, my only problem is the vice keeps slipping and makes it worse. I don't have access to a torch/impact gun, so those are out of the question.
Welding something on is a last resort, i will probably force a socket on before that, what can i do to break it off? I was thinking buying a cheap 1/2" socket and forcing it on but is it worth it? Any other ways?
street dancer. GLEAM |
12-02-2010, 08:30 PM | #3552 | |
12-02-2010, 08:33 PM | #3553 | |
That being said, an intercooler is an intercooler. Theres no reason to drop $500 on a core if youre not making serious power. |
12-03-2010, 12:31 AM | #3554 | |
12-03-2010, 10:42 AM | #3556 |
Just got this a month ago, Is a 91 300zx vg30DE, It has a N62 maf, however, its a grey label, not orange, what´s the difference between the grey label and orange one if both are n62??
12-03-2010, 11:06 AM | #3558 | |
12-03-2010, 01:33 PM | #3561 |
ok i got 2 questions being a noobie and all just installed HKS intake to my s13 am i supposed to reset my ecu how and how long? also my s13 is auto (saving to convert) and i noticed only 3 spds 1,2 and D am i supposed to leave the overdrive on the whole time?
12-03-2010, 02:31 PM | #3562 | |
AFC #1
It's an automatic transmission. Leave it in D with the OD on and let it do it's job. I hope you are not shifting it everywhere you go. If so, I would start saving more. That new transmission is coming sooner then you think. It's a 4 speed transmission (1,2,D,OD). You can take it out of OD when you are coming down a mountain. If you are stuck in the dirt you can bump it to stay in 1st and keep traction. Unless there is a reason to hold it in a gear Keep it in D with OD on.
12-03-2010, 06:30 PM | #3563 | |
1 and 2 are used to prevent the transmission from upshifting. When in 1, the transmission will stay in first gear. When in 2, the transmission will not shift above 2nd gear, though it should still start in first gear. These are really only useful when going down long grades, as you can put the transmission into 2 and use engine braking to modulate your speed instead of using your brakes and potentially overheating them. To be honest, I don't know of a situation in a passenger car where you would use 1. When towing a load in a truck, these gear selections are convenient for keeping the truck from prematurely upshifting.
12-03-2010, 07:02 PM | #3564 |
what is the small bulb on ebay hid kits
I have this hid kit and I want to know what the small bulbs are for on the bottom of the housing and where to get replacements as I don't have them anymore.
12-03-2010, 07:54 PM | #3566 | |
12-03-2010, 11:44 PM | #3568 | |
i was gonna say my car's not auto lol
@dangerdamian |
12-04-2010, 04:56 PM | #3570 |
thanks, i was looking in tech and couldnt find it
