Old 12-20-2007, 03:55 PM   #331
ctnewman
ctnewman's Avatar
ctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of lightctnewman is a glorious beacon of light
Send a message via AIM to ctnewman
oh. i guess i forgot to update you guys.
I traded in the elise on an 04 RANGE ROVER. I also sold my SR20 240sx.
(that is not my black M3 next to the STi.)
RB26DETT BMW E30 BUILD:
onyxsyndicate.com/newman/e30gtr/e30gtr_00.html
ctnewman is offline   Reply With Quote
Old 12-20-2007, 03:58 PM   #332
GSXRJJordan
GSXRJJordan's Avatar
^^^ Not bad, a Range huh?
*cough* balllinnnnnnnn */cough*
Old 12-21-2007, 08:40 PM   #333
ctnewman
ctnewman's Avatar
Spent most of my day at work today blasting suspension components. I blasted:
Rear control arms
Front Control Arms
Top Hats
Front shock tubes/knuckles
F&R Hubs
F&R subframes
Rear subframe mounting plate
I powdercoated the subframes orange (as planned) and they came out great.
Everything else is going to be powdercoated black. The differential is going to be bright green and the swaybars are powder blue. I like that the exterior of the car is fairly subtle, while the underbody is bright.
Also, before i completely blasted the rear control arms i made new spring perches and welded a backing plate on to the swaybar mount. The stock perches were fairly corroded, and while in good condition, the rear swaybar mounts are weak by design.
Some shitty cell pics:
Old 12-21-2007, 08:51 PM   #334
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
YES!! finally updates..
Keep them coming dude, ive been watching your thread for a long ass time.
projekt_s13 is offline   Reply With Quote
Old 12-23-2007, 09:11 AM   #335
ctnewman
ctnewman's Avatar
started grinding off the undercoating.
this is going to suck.
BADLY.
Old 12-23-2007, 09:59 AM   #336
RUTH'LESSDET
RUTH'LESSDET's Avatar
RUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to all
Send a message via AIM to RUTH'LESSDET
"oh you a baller huh"???
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next?
RUTH'LESSDET is offline   Reply With Quote
Old 12-23-2007, 10:17 AM   #337
Edgar
Edgar's Avatar
Edgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfectionEdgar is close to perfection
Send a message via AIM to Edgar
I just read everything, this build is so amazing.
How far are you from Williamsville? I think i'm going to be visiting there for a bit.
Amazing!
Drift Indy
Edgar is offline   Reply With Quote
Old 12-24-2007, 06:44 AM   #338
ctnewman
ctnewman's Avatar
Amazing!
about 10 minutes.
Old 12-24-2007, 07:54 AM   #339
Inlandsilvia
Inlandsilvia's Avatar
Trader Rating: (25)
Inlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond reputeInlandsilvia has a reputation beyond repute
Feedback Score: 25 reviews
Send a message via AIM to Inlandsilvia
wow, you got skills my man!!! Sick build, can't wait till it's done.
Inlandsilvia is offline   Reply With Quote
Old 12-24-2007, 08:32 AM   #340
brewster240
brewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond reputebrewster240 has a reputation beyond repute
Send a message via AIM to brewster240
you traded a lotus for a rover?
brewster240 is offline   Reply With Quote
Old 12-24-2007, 11:56 AM   #341
ilia
ilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to allilia is a name known to all
I would suggest welding a triangular tab perpendicularly to the swaybar mount tab. As you may already see, the stock E30 rear sway bar mounts are loaded in bending, which is not an ideal condition. Welding a second tab transfers the load to tension, which prevents the inevitable- those stock mounts break every time with a big rear sway.
Also, buy the sway mounts from ireland engineering. They go on the chassis side of things in the rear, and bolt through the trunk floor. The rear sway rips out of it's chassis mounts, too.
ilia is offline   Reply With Quote
Old 12-24-2007, 12:49 PM   #342
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
HOLY SHIT about an hour of reading, I couldn't go away!
1. you are the MAN. w/ different personal stlye, but I dig it, kinda rat rod look!
2. you are the man
3. your work is sick.
4. nice fucking work
5. how old are you? you spend money like it has no meaning!!! I WANT THAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
stay up homie! keep the good work up! I know you will.
sillyvia13 is offline   Reply With Quote
Old 12-24-2007, 12:58 PM   #343
ctnewman
ctnewman's Avatar
yeah, i needed a winter car. Originally my STi was my winter whip, but after the 35R it's no longer really a "winter car". I weighed the pros and cons of the elise and sti, and the STi is far more fun to drive, so i kept that.
I have the IE sways. The 10GA backing plate will sufficiently reinforce the tab. From an engineering standpoint, all you have said is correct, but it's unlikely that the joint will be loaded past any yield.
2. you are the man
I'm 26. I'm a mechanical engineer.
Old 12-24-2007, 08:18 PM   #344
brewster240
hes right about the sway bars. extra is better.
e46's rip out rear floor pans
e36's break rear subframe mounts
e30's do their thing.
Old 12-24-2007, 08:20 PM   #345
sillyvia13
sillyvia13's Avatar
I ask age, and say you spend monet alot! lol
you answer...26 and mechianical engineer, lol...that a GREAT paying job...
Old 12-24-2007, 09:38 PM   #346
thetopcow
thetopcow's Avatar
thetopcow is an unknown quantity at this point
glad to see the thread active again, keep up the good work
thetopcow is offline   Reply With Quote
Old 01-09-2008, 09:09 PM   #347
ctnewman
ctnewman's Avatar
OK. I have been a little bit busy. With the car and GF.
But i have the car ready to go back to the blasters. I have been removing the undercoating for the past few weeks now, and i am going to take it back to the blasters to get all the nooks and crannies. From there, i will paint the undercarriage/engine bay and reinstall the suspension... Then i think i will fit the fenderflares and paint the body...
What's slicker? Body color engine bay or black engine bay? At this point i think i am leaning toward black for ease of touchup/cleanup...
Old 01-09-2008, 09:29 PM   #348
TheArkitekt
TheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the roughTheArkitekt is a jewel in the rough
im a fan of the flat black engine bay. makes the engine pop more, not that your build needs any help with that...lol
TheArkitekt is offline   Reply With Quote
Old 01-09-2008, 09:30 PM   #349
SimpleS14
SimpleS14's Avatar
I vote black engine bay
Goals are dreams with a deadline.
L.H.O.O.Q.
SimpleS14 is offline   Reply With Quote
Old 01-09-2008, 09:44 PM   #350
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
black engine bay
Neejay is offline   Reply With Quote
Old 01-09-2008, 10:31 PM   #351
Edgar
Edgar's Avatar
Body Color Engine Bay
might as well
Drift Indy
Old 01-14-2008, 04:10 AM   #352
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
well, with a black engine bay, you hide any possible issues
but on the other hand
you can't see any possible issues...
body color
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 01-14-2008, 10:02 AM   #353
wannabe_drifter
wannabe_drifter's Avatar
wannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to behold
Body color definitely, otherwise it looks like its been half-assed ...
http://i123.photobucket.com/albums/o308/two40/Mine/CoupeSte-Croix.jpg
wannabe_drifter is offline   Reply With Quote
Old 01-14-2008, 11:25 AM   #354
brewster240
silver or machine gray engine bay.
Old 01-14-2008, 02:38 PM   #355
sillyvia13
sillyvia13's Avatar
TRUE BALLERs ROLL WITH WHITE...
just be real careful with assmebly/...
you don't dare...lol...you'll be cleaning everytime you open bonnet...
Old 01-14-2008, 02:53 PM   #356
shift_boost
shift_boost's Avatar
shift_boost is an unknown quantity at this point
body colored engine bay
shift_boost is offline   Reply With Quote
Old 01-14-2008, 02:57 PM   #357
Kinzer SR13gtR
Kinzer SR13gtR's Avatar
Kinzer SR13gtR will become famous soon enoughKinzer SR13gtR will become famous soon enoughKinzer SR13gtR will become famous soon enough
Send a message via AIM to Kinzer SR13gtR
If you paint it anything other than BODYCOLOR,
it may look like a half assed after accident repaint!
Then again, only an idiot would think that, looking at your finished machine.
If I were to paint it differently, I would do it in Gray! Black creates to much
shadow, and its harder to "see" when you are working on it.
Parts, and bolts that may "slip out of your hands" will stand out against the gray paint. Making it easier to find them afterwards.
Have you thought about wrapping it?
Sound deadening, or heat wrap. Something With a repeating logo pattern.
Or something trick... Carbon fiber. Kevlar... Carbon/Kevlar dry weave!
Are you hiding all your harnesses, in the frame-rails?
Wires and Tubes, look like crap contrasted against a lighter colored background! Just some ideas that I have had for myself!
Kinzer SR13gtR is offline   Reply With Quote
Old 01-14-2008, 04:43 PM   #358
Rusker
Rusker's Avatar
Rusker is on a distinguished road
Agreed. Nothing on this car should be half assed
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 01-14-2008, 05:31 PM   #359
acheron
acheron's Avatar
acheron will become famous soon enoughacheron will become famous soon enoughacheron will become famous soon enoughacheron will become famous soon enoughacheron will become famous soon enough
awesome build man, thumbs up... keep up the work and fill in more pics. good luck !!
acheron is offline   Reply With Quote
Old 01-14-2008, 09:56 PM   #360
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
nice work newman, cant wait to meet up this year and have some chit chat.
too bad the elise is gone but youre riding in style now huh? comfyyyyyy.
sti is looking good too.
sheeeeeesh.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold
300hp owen is offline   Reply With Quote
