Old 08-12-2012, 10:47 PM   #331
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
Originally Posted by ForeignMuscle View Post
200kPa=29psi but that cant be what he meant.
No it's not.
First of all you need to know your elevation and temperature to calculate KPA.
Lets say you are at sea level with an ambient air pressure of 100kpa. To convert to PSI minus 100 and divide by 7.
So in his case.
202-100=102
102/7= 14.57 psi
SMM is offline   Reply With Quote
Old 08-12-2012, 11:55 PM   #332
b14 se-rious
b14 se-rious is an unknown quantity at this point
My Z is built for drag racing. It made 480 whp on pump on low boost. I weighed the car and without me in it it weighs 2250.
Swapping out for a VVL head and going e85. I should clear 600-625 whp and am hoping to see some low 10 second passes on slicks
b14 se-rious is offline   Reply With Quote
Old 08-12-2012, 11:56 PM   #333
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
You're right. I forgot 101.3 kPa = 1 atm. Divide by 6.8xx
Nice setup, I'd like to to see more vids. It would be a wicked ride with a good launch.
ForeignMuscle is offline   Reply With Quote
Old 08-12-2012, 11:56 PM   #334
GSXRJJordan
GSXRJJordan's Avatar
Haven't checked into this thread in a while, glad to see it's still moving.
The GTO-pan LSx guy needs to invest in a baffled pan and an Accusump. I use the 3qt racing can with the 34psi EPC valve on race cars that spend most of their times high in the revs (with an unshimmed pump your hot idle pressures will drop below that and you'll flood the pan with too much oil on a street motor).
Originally Posted by S@nt0s View Post
That's Abel's car
Made 739whp and sent 9.98@142
Really? 700+whp in a S13 with bias plies and skinnies to go high 9's?
Cmaaaaaaaaaaaaan
Old 08-12-2012, 11:57 PM   #335
ForeignMuscle
Give some more info on your setup. Engine works, turbo, boost?
Old 08-13-2012, 02:35 AM   #336
b14 se-rious
480 whp was made with this setup on 17 psi
Tomei 272 cams
Stock head
Arp studs and Cometic HG
ACL race bearings
Stock bottom end
Peakboost manifold
SC6176 on a .82 housing (I started my build before these billet units were out)
Intake Manifold
100 MM throttle body
Haltech E8
Next setup plans to be VVL head , 8500 RPM and 25-28 psi on E85 with a lot more timing through the entire powerband.
Old 08-14-2012, 07:39 AM   #337
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
Cmaaaaaaaaaaaaan
time can be had with less but that will depend on the driver.
with me car i plan to pull that time with my curent power maybe a tad more.
Tomei 272 cams
Stock head
ACL race bearings
Stock bottom end
Peakboost manifold
Intake Manifold
Haltech E8
what kind of timing are you running now? i recommend going E85 now and run it and see where you are at. I am close to the powerrange you want to be at and like you i have a stock head as well reving to 8100 without solid lifters.
MunkyW3rkz Racing
S@nt0s is offline   Reply With Quote
Old 08-15-2012, 03:41 AM   #338
b14 se-rious
I haven't looked at my map for while since my laptop is broken.
I already pulled my motor and while I setup for e85 I am switching to the VVL head. The size of the ports are so much larger than any other sr head.
Also I'm looking forward to no more floating rockers.
Old 08-15-2012, 07:20 AM   #339
S@nt0s
S@nt0s's Avatar
ya VVL is the way to go but its too expensive for me ill just push the DET head as far as i can
MunkyW3rkz Racing
Old 08-15-2012, 09:04 AM   #340
ForeignMuscle
Are you going to build the bottom end while it is out or run it stock?
Old 08-16-2012, 01:12 AM   #341
b14 se-rious
Nope, have no intentions on building it. Right now my goals for the car are to make it run low 10's maybe a high 9 on a stock bottom end/stock head with n1 cams. Then I plan on just enjoying it for 2-3 years, the eventual plans will be for it to run mid 8's with an sr20.
8500 RPm isnt much, and 28 psi I wouldnt call a lot either. I think the stock bottom end will be just fine.
Typically when I build cars I dont take into consideration what everyone says online, until I actually see that my motor throws a rod out the side and have first hand experience, I am not upgrading it.
Old 08-16-2012, 02:11 AM   #342
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
that would be a very expensive failure because it will probably take the turbo out with it when it goes. hope it does not happen to you.
rcdad123 is offline   Reply With Quote
Old 08-17-2012, 12:36 AM   #343
turbociv910
turbociv910 is an unknown quantity at this point
in for rod hanging out of block pics^
www.carolinadyno.com
s13 LSx turbo drag car- 1.42 60 ft, 6.32 1/8
turbociv910 is offline   Reply With Quote
Old 08-17-2012, 09:01 AM   #344
turbociv910
Got another video-
http://www.youtube.com/watch?v=9079RNESlkg&feature=plcp
Old 08-17-2012, 09:41 AM   #345
S@nt0s
S@nt0s's Avatar
sounds good, still sad you put a LS in there tho lol
what stall are you running?
what did u run?
MunkyW3rkz Racing
Old 08-17-2012, 09:47 AM   #346
mr_eh
mr_eh's Avatar
mr_eh is an unknown quantity at this point
what kind of axles are you guys running? I snapped one on my break in tune with 315whp... making 463 on a dyno dynamics now.. have a exedy triple plate in the car atm.
My 96 S14 | 501whp SOLD
mr_eh is offline   Reply With Quote
Old 08-17-2012, 09:53 AM   #347
S@nt0s
S@nt0s's Avatar
hes running a Q45 diff set up.
what were you doing that you snap the axle?
MunkyW3rkz Racing
Old 08-17-2012, 01:22 PM   #348
turbociv910
what did u run?
only way to go fast
2600, 6.3 something.. that was a 1.49 60.. best so far on 2 psi boost
it seems to be holding up just fine, no wheel hop, big sidewall gives alot more than a street tire, barely glazing the tires over. Tire is still tapping the fender in the 60 ft, time to get a bigger hammer
Old 08-17-2012, 01:28 PM   #349
S@nt0s
S@nt0s's Avatar
lol i wouldnt say the only way
easy way yes lol
MunkyW3rkz Racing
Old 08-20-2012, 09:50 AM   #350
ForeignMuscle
Nope, have no intentimy factory ons on building it. Right now my goals for the car are to make it run low 10's maybe a high 9 on a stock bottom end/stock head with n1 cams. Then I plan on just enjoying it for 2-3 years, the eventual plans will be for it to run mid 8's with an sr20.
That's awesome man. People underestimate these engines and also use shit parts and shit tunes, blow them up and then come to the forum to tell the world how x horsepower will sling a rod on said engine. Keep us updated on the build.
Old 08-20-2012, 03:07 PM   #351
steve shadows
steve shadows's Avatar
easy way yes lol
Should bring it down to our dyno dynamics I'd love to do some discounted tuning on a setup like this...
Like Me on FaceBook !
Old 08-20-2012, 04:52 PM   #352
Yellow4g63
are you going to cut the valve reliefs bigger so you can run a bigger cam with the VVL head on those DET pistons?
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 08-21-2012, 01:37 PM   #353
mr_eh
mr_eh's Avatar
side stepping the clutch at 4800rpm... I was only on my 315 break in tune with drag radials and hit 2.1 60 foot on the first launch at the track, second launch broke it.
Old 08-21-2012, 02:47 PM   #354
S@nt0s
S@nt0s's Avatar
I would say you had wheel hop that's what caused the broken axle hooking wasn't the issue
Thanx for the offer but I don't need any tuning services in taken care of by OSR and myself. But I'm more then willin to make pulls for free at least.
No more power can't be pulled from my set up wothout more psi and fine where it's at with it's stock head for now
MunkyW3rkz Racing
Old 08-24-2012, 06:45 PM   #355
2000gtx
2000gtx's Avatar
2000gtx is an unknown quantity at this point
have you ran out at irwindale yet ? i think we can extract a little more but solid lifers and some porting wouldnt hurt...did you get 2 step figured out?...osr
2000gtx is offline   Reply With Quote
Old 08-25-2012, 07:18 PM   #356
S@nt0s
S@nt0s's Avatar
paul i went that one night that was it, i have solid lifter in the box ready to go and a spare head to port. i got my line lock in and just need to bleed it. the 2step is ready just need a relay and connect the wire. i will try to get this done tomorrow and hit the track this coming week or the next.
i replace the diff with a r32 3rd member with 4.36 gears as well
MunkyW3rkz Racing
Old 08-25-2012, 07:47 PM   #357
06_footy
06_footy's Avatar
06_footy is an unknown quantity at this point
Sub'd.........
06_footy is offline   Reply With Quote
Old 08-25-2012, 08:45 PM   #358
blo0d
blo0d is an unknown quantity at this point
this is gonna be epic
blo0d is offline   Reply With Quote
Old 08-26-2012, 01:42 AM   #359
11Banger
11Banger is an unknown quantity at this point
Well you can see my setup in my Sig, Ran a best of 10.1 on street tires.. AWD BABY
AWD 89 Colt, Alum Rod 4g63, 10.5-1, S375, 42psi, E85
11Banger is offline   Reply With Quote
Old 08-26-2012, 08:25 AM   #360
jr_ss
You do realize you cant run anything but stock P11 cams on a stock DET bottomend right? Anything else and you'll be tapping valves with your pistons. Not to mention N1 cams are garbage for forced induction. NA/FI have different cam profiles and the N1s are obviously optimized for NA.
