Old 10-05-2017, 12:53 PM   #331
PoorMans180SX
PoorMans180SX's Avatar
Originally Posted by Juan@Fontananissan View Post
well choke / surge aside. after 5000 RPM you're outside the efficiency range, and with that much boost AIT's would not be ideal either. so close to peak torque would probably make the car real knock sensitive too. I think the S300 is overall a good starting point for any engine 3L and up.
Yeah exactly. While I don’t plan on doing a lot of limiter bouncing, it will be nice to have IAT’s stay in check when I’m blasting down the straight at Gingerman. While part of me wants the insta-spool, having a reliable package and a nice flat torque curve are probably more important. I can always add anti-lag if I don’t think it spools flast enough .
I really only plan on makin 400whp, as any more than that and it’ll blow through tires too fast and possibly compromise transmission components. I’m sure someday I’ll want to turn it up. Maybe when I build the DE hah.
Old 10-29-2017, 03:20 PM   #332
PoorMans180SX
Finally drilled out all the welds on the seat brackets.
Removing those stupid weights on the front of an S13 subframe resulted in me cutting through my bushing mounts. Oh well, I'll be reinforcing these anyway.
blocks on blocks.
Prepping the rear subframe for GKTech's rear subframe reinforcement plates and a few other modifications. Then it'll be off to be stripped to bare steel.
Old 03-01-2018, 07:56 AM   #333
PoorMans180SX
If you've bought the "Contano" 5-lug conversion hubs, do yourself a favor and repack them with quality grease. I caught this one just in time to save it.
Shortened by Q45 output shafts so I won't have issues running Z33 axles. This was a major pain.
Old 03-06-2018, 02:28 PM   #334
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
Quality shit man, glad to see youre still at it!
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 03-06-2018, 07:55 PM   #335
PoorMans180SX
Thanks man!
__________________________________________________ ________________________
Man, I just read through this thread for the first time in a long time, and some of my responses or ideas make me cringe. Funny how many things change in 5 years.
Big news coming soon.
Old 03-06-2018, 09:20 PM   #336
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
sorry havent read the whole thread....so you run those contano 5lug hubs on the track with decent success? are those the 240sxconversions.com hubs?
good to know. wont be so worried to give them a try now.
240KA is offline   Reply With Quote
Old 03-07-2018, 08:03 AM   #337
tuzzio
tuzzio's Avatar
ugh, sell me that stealth fab RSTB.
No luck getting in contact with him.
Old 03-07-2018, 02:32 PM   #338
PoorMans180SX
Yeah just repack them with quality grease.
I can do that. Took me forever to get a hold of him but I’m caging the car soon...
Old 03-07-2018, 02:59 PM   #339
TheRealSy90
TheRealSy90's Avatar
Do those Contano 5 lug hubs not come with packed bearings?
Such a good signature.
Old 03-07-2018, 06:08 PM   #340
PoorMans180SX
They are packed with this waxy green grease. The one you see that’s discolored was on my car for about 30,000 miles.
Old 03-11-2018, 03:02 PM   #341
PoorMans180SX
Refreshing the bores on the VG and measuring bearing clearances before I put it back together and in the car. I'm convinced a lot of the "oiling" issues these engines experience are from people running factory clearances on higher powered engines.
Pin bores needed some honing to be truly "floating".
Old 03-12-2018, 07:27 PM   #342
PoorMans180SX
350Z steering rack showed up. Now things get interesting.
Old 03-13-2018, 11:16 AM   #343
PoorMans180SX
These may or may not be mine.
Old 03-13-2018, 11:20 AM   #344
TheRealSy90
I wonder if the weld-on steering rack clamps that Villains sells would also fit around that Z rack after removing the mounting ears from it. I think Bink has rack clamps as well.
Curious on the difference in total rack travel between the two, with and without tie rods installed since they both can make use of tie rod spacers.
Old 03-13-2018, 11:44 AM   #345
PoorMans180SX
I'm definitely going to be doing a lot of measuring and figuring before I start cutting stuff up, so you'll have your answers here in a bit!
Old 03-16-2018, 05:43 AM   #346
PoorMans180SX
More boring parts updates:
Still have to box these in.
Old 03-16-2018, 05:59 AM   #347
Motary
Motary's Avatar
Motary is making a name for him/her selfMotary is making a name for him/her self
Send a message via MSN to Motary
Moooooore pictures!
GKTech
Motary is offline   Reply With Quote
Old 03-16-2018, 06:42 PM   #348
PoorMans180SX
Originally Posted by Motary View Post
Moooooore pictures!
If you say so.
I dropped my rear subframe, front subframe, and homemade tension rod brace off at the local derusting place. They're going to strip them down to bare metal. Really excited to work on those and get the shell rolling again, so it can come to the shop and I can start on the cage!
Current state of affairs:
Old 03-23-2018, 06:25 AM   #349
PoorMans180SX
Cage material showed up.
Picked up my subframes.
GKtech's subframe reinforcement kit.
That was a good brush up on my TIG skills. Still need work.
Fancy picture of FEAL with GKtech offset strut top for no reason.
Old 03-29-2018, 06:36 AM   #350
PoorMans180SX
My 61mm S300SXE came in today and Dylan decided to take fancy pictures of my parts:
New wheels also came. Motegi MR135.
Old 03-29-2018, 06:03 PM   #351
PoorMans180SX
Finished reinforcing my subframe and filled it with foam since the inside is now bare metal from the acid dip.
Old 03-31-2018, 08:06 AM   #352
PoorMans180SX
We'll get to the actual build portion here shortly, feel like I've been posting pictures of parts forever lol.
Foam is cured. Gotta finish up my front subframe mods and then paint them.
Running 17x8.5+25 in the front (probably with a spacer of some sort), and 18x9.5+15 in the rear. Really want to run a 9" wheel up front, but budget dictates I run some cheap wheels for the time being haha.
Old 03-31-2018, 08:27 AM   #353
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
How much to those weigh?
Old 03-31-2018, 10:18 AM   #354
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
Looking forward to cage fab pics
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 03-31-2018, 11:07 AM   #355
PoorMans180SX
20lbs for the 17s. Haven’t weighed the 18s yet.
Old 03-31-2018, 02:54 PM   #356
PoorMans180SX
Reinforced FLCA mounts. One was starting to oval from lateral force.
Old 04-02-2018, 10:18 AM   #357
90S13
90S13 is an unknown quantity at this point
Prior to doing the repacking of grease to the contano hubs did you have any issues with the hub "working" its way out of the bearing? Ive had two fresh sets start to come apart after putting a couple miles on them, scary stuff.
90S13 is offline   Reply With Quote
Old 04-02-2018, 05:25 PM   #358
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
Pro Tip: When cutting out the sleeve for the subframe bushings, cut on the side that is fully welded. This way a slight mishap isn’t a big deal. Progress looks good!
IG: @scotheocelot
scottie is offline   Reply With Quote
Old 04-03-2018, 03:54 PM   #359
PoorMans180SX
I'm even sure how that can happen?! The axle or the stub hold them in place, how can they move laterally at all?
Haha, thanks. I've had solid bushings in this car for over a year. There was so much galvanic action I just cut them out. I'll be epoxying them back into place, so a cut in the bushing sleeve is no big deal!
Old 04-04-2018, 03:57 PM   #360
90S13
I asked myself that same question, it was like the hub came off of the wheel bearing and started to work its way out. There was in and out play when I would push the hub back into the bearing, while bolted to the car! Both times the axle nuts were loosened from the play even after I had torqued them originally. I have video and pics that ill dig up later.
