#3601 | |
http://zilvia.net/f/showpost.php?p=1681750&postcount=30
#3602 |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
im not a fan of stretched metal... just doesnt look good IMO. also not big on wide fenders. my goal with my current S13 has always been to just build a great all around car, and thus far its been pulled off quite well. i prefer stock body anymore to wide/pulled fenders. also, once you pull fenders, there is no fixing it or going back.
#3603 | ||
In my opinion he is providing vital information for people who do NOT want to ruin their fenders and run that rim size. Again, just my thoughts, but some people have gotten so used to the pull, roll, stretched, flare scene, that if someone provides info that does not involve this, it's as if they're doing it wrong. All of this is my humble opinion.
#3604 | |
#3605 |
Not buying it.
Modifications are done to fit the maximum amount of tire possible. Isn't that what this thread is about, what mods and settings you are doing to fit what tire? Otherwise it would just be pictures of everyone with 17x9 +35 wheels and 245 tire... "pull, roll, flare (leaving stretch out because it's not pertinent to this thread) scene" is not a "scene". Wheel arch massaging is a common modification, for decades, among all lines of motorsports enthusiasts in order to fit more rubber under a car. More rubber almost always = more performance |
#3606 | |
Simply put, a 245 is not "maximum" rubber on a 9.5" wide rim. A 265 or 275 would be maximum tire for said rim. A 245 is considered stretched on a 9.5" rim.
#3607 |
I am not saying that rolling, pulling, flaring... etc is not acceptable, to each their own.
What I am saying is to say that his information is irrelevant is a bit short sighted. With that you're saying, your point of only MAX rubber is reaching towards the 12 inch wide rims with flare on flare body panels and ridiculous front tires. Is THAT the point of this thread?
#3608 |
#3610 | |
Tires have a rim width range recommended they fit on. In order for it to be considered a "max" setup, your tire should fall in the lower portion of that range. For instance, a 245 can fit on to as narrow as a 8" rim, with 8.5" being ideal. A 9.5" is at the top of the range bordering stretch territory with 245's. Therefore, regarding it as not max tire. Yes, it is the maximum he can fit or so chooses to fit, but not for those wheels and their given width.
#3611 |
Maybe you don't know the meaning of maximum, so let me ask this,
Can you fit a 290or295/30or35 tire on your car? Because if the answer is yes, then you do NOT have the maximum tire and according to your owner words, your info is irrelevant. If the answer is no, then that means my point is proven because with the space given, the tire you have is the MAX you can fit.
#3612 |
Listen, I'm not going to sit here and argue with you about the definition of maximum. His setup does not fall in the category of maximum tire for that rim or the chassis in general. IT IS the max he can comfortably fit, as stated, but apparently you've failed to recognize that. Not only was that stated, I laid out plainly why his setup, like others have posted before him, is not a maximum rubber setup. 245's on a 9.5 just don't fit in this thread, sorry get over it. I'm not sure why you think turning this to personal attacks was warranted or necessary, it's a heated debate about someone else's setup, that doesn't belong, get over it.
#3613 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
well i dont plan on going anywhere seeing as i really like this thread and have at least TRIED to be part of it!
guess theres always someone who takes things way too seriously in every crowd... for fucks sake, were 240sx owners, not goddamn lambo owners! |
#3614 | |
![]() Join Date: Jun 2010
ka-titties posted his setup of 17x9 +22 with 255/40 on his stock metal S13 on pg. 115, but he needed a pull in the rear. I'm curious how much you're going to need with the wheels an extra 7mm outboard. |
#3615 | |
It's not that I take things seriously, but just like this forum, this thread has rules and guidelines to abide by. If a mod can't follow simple rules, what kind of example does that set for other members of this forum? Now, back to our regularly scheduled program...
#3616 |
#3617 | |
#3618 | ||
![]() Join Date: Feb 2014
#3619 |
Ah bummer man. I run a 340 Aeromotive in my 370, since my Walbro 255 shit the bed on the dyno during tuning lol.. What size are you going to use? I think I'm going to use another 340 for my LS swap.
#3620 |
Absolutely, there's still more room there. Not sure about anything higher than 30, but 30 for sure will fit.
#3621 |
It would depend on your coilover or shock/spring setup. With my coilovers 18x11+30 is basically touching the coilover. Hardly 1mm to spare.
#3623 | |
#3624 | |
Sent from my VS990 using Tapatalk |
#3625 |
Who all is running 285's or wider up front?
I only know a couple of the SM guys are, but I'm trying to figure out which suspension parts to purchase.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#3626 | |
![]() ![]() Here's a video of me firing it up for the first time! https://drive.google.com/file/d/0B0V...ew?usp=sharing |
#3627 |
-S14
-5zigen 17x9 +22 offset -Hankook Ventus V12 Evo2 ---deciding between 255/40/17 or 245/45/17 -stock, no bolt ons, function/form type 2 coilovers -Street but eventually track/autoX Concerned about clearance issues and rubbing. I don't plan on going lower except maybe a little in the rear. Currently on cheap ass Accelera Alpha 235/45/17 with slight rubbing at full lock but not enough to hear or feel. Gonna measure everything with a tape measure but thought i'd hit up zilvia 245/45 or 255/40? 2016-04-26 01.11.13.jpg 20160422_145213.jpg |
#3628 | |
Haha it totally doesn't look like it would sound like that!
#3629 |
![]() Join Date: Feb 2007
Trader Rating: (66)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 66 reviews
#3630 |
![]() Test fitting 285's up front on 18x10 et +18. It looks like they'll need a 15mm spacer to keep from rubbing the coilovers.
