#3661 |
Will post dyno results when I'll get it.
Replaced my 2876.86 with GT2871.64 - same power output,lower boost,better response and surprisingly a great high end |
#3662 | |
![]() Join Date: Jun 2010
Edit: 1.2 bar is only 17.4 psi. Very impressive numbers for that boost pressure. |
#3664 | |
![]() Join Date: Jul 2005
WHen we post dyno numbers, we have to post dynojet numbers, or at least say what dyno was used. Dynojet is an easy standard. That S15 engine on a dynojet would show 315rwhp IMO. |
#3666 |
the 240z and 300z are sweet rides. 200sx nice, I own a 96 sentra tinker toy 1.6 5sd, computer bad not pulsating injectors. I wish to upgrade performance since I have to change it anyhow. any information would be much appreciated. pics are to come soon.
#3668 |
blacktop, gt2871r .64, freddy mani, 750cc, walbro, aem ems v2, arp studs, cosworth gasket.. boost by gear 12, 18, 18, 18, 12.. numbers are in my sig.. dynojet. ill scan the sheet if i head out to the garage tonight.
#3672 |
Hey guys quick question with my 2871r im getting full boost at 4400rpm (20psi) what rpm do you guys get full boost 18-20 psi only not people with 15 psi or less
Sent from my iPhone using Tapatalk |
#3676 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Try editing your post?!
You have to have some sort of starting point or guide. Usually rpm, and gear for dyno, and street. maybe even speed and vacuum gt2871r.64 56trim t04e 50ar compressor housing 3rd gear street 2500rpm 0 vacuum full boost 20psi 3400rpm 4th gear street 2500rpm 500mmhg full boost 20psi 3500rpm 4th gear dyno 2000rpm full boost 20psi 3200rpm None of the street pulls were full throttle btw. There are factors that can affect spool, pros and cons. I also tune by the 300ftlbs for 3000rpm rule!
#3677 |
GT2871 USERS. SR motor
On the street in 3rd im getting 20 psi when I touch 4400rpm this is at full throttle, tial wastegate 8psi spring and I have my MEGASQUIRT ecu controlling boost I have set boost duty at max 100% and the best I can get was that. How are you getting full boost by 3500 that is a extremely big difference
Also do you have an upgrade plenum or stock Sent from my iPhone using Tapatalk |
#3678 |
Stock s13sr intake, stock exhaust manifold with Tial v44 gate 1bar spring, blitz dual sbc, I don't remember the gain or duty, I set it over 2 years ago.
I have a question for you. Does your setup sweep past 0 when coming from vacuum into boost or does it take a slight pause? And does your turbo spin during idle, and shut down? Sent from a Highly Tuned Note 4.5!!!
#3679 |
Sorry about the delay, it doesn't sweep past 0 I also boost leak test and fixed all leaks, the turbo is spinning on idle I put a harder spring in the wastegate and set my boost controller to the max and all I could get was full boost at 4000-4100
Turbo is brand new Sent from my iPhone using Tapatalk |
#3680 |
There's probably things you can do, like make sure your bov is not leaking.
Also I make full boost within 1000rpm so if your in 3rd at 3000rpm and you reach 20psi at 4000rpm I'd say that's normal. You could also try tuning for max best torque, vs horse power. if using a brake dyno you will most definitely see an increase in spool on the street. Sent from a Highly Tuned Note 4.5!!!
#3681 | |||
![]() Join Date: Aug 2013
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
![]() Quote:
I searched this pretty thoroughly and have yet to see a good solution for the 3" universal 2871 and z32 MAF. ![]() I had a APEXi Super Suction, but it does not fit with 45* reducer (hits the HP PS line and the Res Return line BEFORE it even has the MAF on it.). Trimmed the coupler, tried tucking up the ISIS hot pipe pointing forward towards the radiator; nothing. I have given up on my super suction ![]() ![]() So, what are people's solutions? Something with a vacuum line for the catch can and a port for the BOV Recirc. Please post your pictures if you have them!
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() Last edited by 5280VertDET; 08-04-2015 at 01:44 PM.. Reason: Changed to port to recirc the BOV. |
#3682 | |
Side note, BOV needs to see vac and boost - meaning it needs to be plumbed to IM.
@UpshiftEngineering |
#3684 |
![]() Join Date: Oct 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
Pipingpro.com use to have an intake kit available for the GT2871R. Not sure if they're still around, I remember they use to be on Zilvia offering up custom intakes like 7-8 yrs ago.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
#3686 | |
![]() Starting to realize that. ![]() I know, I know, but has anyone used this thing? ![]() http://www.amazon.com/Spectre-Perfor.../dp/B000BPUTO6 It's just about the only DIY option, besides the ducting tubes... ![]()
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
#3687 | |
![]() Join Date: Nov 2010
I get that it's on the intake side, but I was melting specter couplers when they were right before the intercooler. I can't imagine this one holding up connected to the turbo near the manifold.
#3689 |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Probably as much as you want if you crank down the preload tight enough or add additional springs. I know of an evo in Phoenix running an internal gate on like 45psi because he has a bunch of extra springs holding the flap closed in addition to the actuator.
