Old 06-28-2016, 02:52 PM   #3661
Soilsack
Soilsack's Avatar
Soilsack is an unknown quantity at this point
Alright, I looked through the thread and saw plenty of suggestions for 17x9 +25 for stock S14 fenders. a lot of the people were saying 245/45r17 and 255/40/r17 MAY fit with no fender mod. I did not see any confirmation that they DO fit.
So the question is, 17x9+25 with 255/40r17, will fender modification be required?
Car is a S14 lowered on Fortune Auto 500, probably 2-3 inches below stock. No rubbing from 17x8 with 225/45/r17. How are we looking for the bigger tires? And if I did want to go with 18s, would 18x9.5 with 255/35r18 be too big?
Soilsack is offline   Reply With Quote
Old 06-29-2016, 02:00 PM   #3662
GoodShow
GoodShow's Avatar
GoodShow is an unknown quantity at this point
Originally Posted by GoodShow View Post
Anyone running a 18x 10 -18x 10.5 +20 rear on a s14? Would I be looking at a huge roll and pull job? Any pics would be helpful.
Any help anyone?
GoodShow is offline   Reply With Quote
Old 06-30-2016, 10:47 PM   #3663
Mikuni
Mikuni's Avatar
Mikuni is an unknown quantity at this point
Will 17x9 +22's clear a Z32 brake setup without spacers?
Mikuni is offline   Reply With Quote
Old 06-30-2016, 11:30 PM   #3664
derass
All depends on the spoke design, but I have 2 different sets of 17x9 +20 that clear. Many people clear RPF1's in the size you listed as well.
Old 07-03-2016, 10:55 AM   #3665
Bluejayde
Bluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond repute
Alright dudes, looking for some help. I'm not a total newbie but I'd like to step my fitment game up. Here's what I'm working with-
Advan Model V's, 17x9+35 front and 18x9+25 rear. Both are wearing 225/45 rubber. I have about 10-15mm of spacer up front to clear R33 Brakes (PBM adjustable spacer)
I have rolled the front and pulled the rear a bit for clearance, and hammered the inner fender in the rear somewhat. I still rub a bit on hard cornering. I have all the adjustable arms front and rear except for LCA's. I have Whiteline adjustable sway bars and Fortune Auto Coilovers (7k front and 5k rear). Currently I have about 3+1/4 inches of clearance from frame rail to ground in the front, and 3+3/4 clearance from frame rail to ground in the rear. I can't go too much lower.
This is a street car, not a track car. I would prefer very little camber in the rear, but I am okay with a little in the front. I want to get the wheels as close to the fender as possible without rubbing, but I want to maintain function on the street.
What can I do to improve?
Bluejayde is offline   Reply With Quote
Old 07-03-2016, 11:39 AM   #3666
derass
I would get wider tires, should be able to fit 245 or 255 easily.
Or if you want to keep the 225s, use those adjustable spacers to figure out exactly how much spacing you need in the rear.
I'd say the front fitment is pretty good, you can either leave it as-is or go with wider tires and add camber.
Old 07-03-2016, 03:10 PM   #3667
Bluejayde
So either way, I need more clearance, cuz I'm rubbing now. Camber could fix that, but it'll look worse. So how can I get more clearance front and rear? Just look where it's rubbing and BFH? Or are there secrets I don't know?
Old 07-04-2016, 09:38 PM   #3668
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute
Feedback Score: 24 reviews
run a 40 series tire ^^^
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 07-05-2016, 08:59 AM   #3669
Bluejayde
^^ That would drop me about 1/2 an inch, but I guess I can live with that. It will also give me 1/2 an inch more space between tire and fender, which is good for rubbing but bad for looks.
Old 07-19-2016, 08:09 PM   #3670
illest_s15
illest_s15's Avatar
illest_s15 is an unknown quantity at this point
This might be a shot in the dark but does anyone know who's car this is? I found a picture of it on instagram, its a s15 it clearly has a set of sr04 esr wheels on it! I wanted to inquire as to what offset / sizing this is. I have looked through this entire thread, no other pictures of this car around
illest_s15 is offline   Reply With Quote
Old 07-21-2016, 05:28 PM   #3671
theStig880
theStig880's Avatar
theStig880 is on a distinguished road
^^ His name is Chris Lacey and his instagram is @chrislacey_. Those wheels are ESR reps of Work Equips. They are 18x9.5 and 10.5 with 225/40 and 235/40 tires sizes respectively.
Follow me on Instagram or don't @cason880
theStig880 is offline   Reply With Quote
Old 07-23-2016, 02:19 AM   #3672
TurboDieselDan
TurboDieselDan's Avatar
TurboDieselDan is an unknown quantity at this point
Does anybody know if these 17" 350z wheels will fit an S14 with the 4 pot CTS-V calipers? I'd be even more interested to know if the 6 pot CTS-V brakes will fit behind those 17" 350z wheels with or without a spacer.
I also heard that the 6 pots will fit behind just about any 18" wheel I so was looking at these 18x9 +30mm 10th anniversary SVT wheels if they would fit and the 350z's wouldn't but thats only if I end up becoming dead set on the 6 pots.
Thanks
Dan
New member- first time 240sx owner but a long time modified car guy.
TurboDieselDan is offline   Reply With Quote
Old 07-23-2016, 06:39 PM   #3673
TurboDieselDan
Old 07-23-2016, 06:41 PM   #3674
TurboDieselDan
Old 07-23-2016, 11:09 PM   #3675
TurboDieselDan
Old 07-25-2016, 04:32 AM   #3676
Im Zero
Im Zero is an unknown quantity at this point
Total newbie here. Looking to get a Z32 rear brake set up with wilwood BBK fronts. Whats the most aggressive setup I can possibly get without having to roll/pull my fenders too much or add a lot of camber. Trying to go wide since I'm going to do an LS3 swap soon but covering suspension and brakes first before I go on with the swap.
Im Zero is offline   Reply With Quote
Old 08-06-2016, 12:30 PM   #3677
boatwright_doug
boatwright_doug has a spectacular aura aboutboatwright_doug has a spectacular aura aboutboatwright_doug has a spectacular aura aboutboatwright_doug has a spectacular aura aboutboatwright_doug has a spectacular aura aboutboatwright_doug has a spectacular aura aboutboatwright_doug has a spectacular aura about
Question for the experts
18x10.5 +15, on a stock body how far does it poke out. Looking a 65mm overs (only comes in that size) and wonder how bad it'll look.
Sent from my SM-G930V using Tapatalk
boatwright_doug is offline   Reply With Quote
Old 08-06-2016, 12:35 PM   #3678
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Youll prob have some really shitty looking fitment. I wouldnt go more than 30-40mm depending on how you want the car to sit how low youre going tire sz etc
jared420sx is offline   Reply With Quote
Old 08-06-2016, 12:37 PM   #3679
boatwright_doug
I actually just got off the phone with a buddy of mine, he was telling me I'd have to run a big bolt on spacer if I want the wheel to become flush with the quarters; and reason being that wide of a quarter is, it only comes in that size sadly.
Old 08-06-2016, 08:16 PM   #3680
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
Like this dude is saying ^ gonna be sunk as fuck!
Bnr32gtr is offline   Reply With Quote
Old 08-10-2016, 03:38 PM   #3681
Too4d
Too4d is an unknown quantity at this point
Will 18x9.5 +12 fit on an s13 coupe with tein lowerin springs. And what would it look like with them? Bad? Decent? Let me know before I make a mistake.
Too4d is offline   Reply With Quote
Old 08-10-2016, 04:33 PM   #3682
jared420sx
jared420sx's Avatar
How much of a drop are the lowering springs? Are you doing anyother suspension mods? What sz tire?
Old 08-10-2016, 06:48 PM   #3683
Too4d
The tires are 235/40 r18 and I plan to install coilovers in the near future.
Old 08-10-2016, 06:53 PM   #3684
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
This is my old pic with my old set of Gram Lights 1895 +12 all around. I run Tein coils with camber plates. All stock body. Front tires 225/40, rear 235/40
Old 08-10-2016, 07:49 PM   #3685
Too4d
But the difference here is I have a lowering spring setup not coils so the base of them stick out more
Old 08-11-2016, 04:43 PM   #3686
TurboDieselDan
I am about to pull the trigger on buying four 350z 17x8 seven spoke wheels for my s14. I want 4 of the same size wheels and tires (square stance) because I have plans on taking it to Thunder Hill for on track instruction.
Does this sound like I will run into any problems running the wider 17x8 350z wheels up front with 235/40/17 all around?
Will I need spacers or a different size tire to get the best performance from it?
Thanks
Dan
Old 08-11-2016, 04:54 PM   #3687
jared420sx
jared420sx's Avatar
Thanks
Dan
If youre not lowering your car anything more than 2in you should be fine maybe a small spacer for clearance purposes. Also i dont know if youve upgraded to a bbk but if you have you might run into clearance problems depending how big of a kit you have. Other than that it looks like a good track set up just get some |quality| Tires and start shredding!
Old 08-11-2016, 05:34 PM   #3688
TurboDieselDan
The previous owner had it slammed (CX Racing coilovers) on the 16" SE wheels with a small wheel spacer spacer up front. I 'm planning on having a race shop corner balance and align my car for the track. I'm guessing that they will adjust the ride height as well.
As for BBK I've seen a Z32 calipers fit these wheels up front and possibly even the 4 pot CTS-V calipers which I'd like to get.
Old 08-13-2016, 09:53 PM   #3689
1gr8bar10der
Trader Rating: (77)
Do you have adjustable arms? If so it shouldn't be a problem.
Old 08-19-2016, 03:55 PM   #3690
kickahlick
kickahlick is an unknown quantity at this point
RFP1 what size is this set up
baby needs new shoes looking to buy these wheels i want this exact set up tire size and all
kickahlick is offline   Reply With Quote
