Old 03-19-2014, 10:43 AM   #3691
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Originally Posted by xoxide View Post
Something else id like to get worked out before the next event....
I remember reading JZ's run hot, but sitting on the grid my water temp is around 190ish on a hotter day, 180 on a cooler day.... After I go for a run and come back to the grid my water temp ranges from 220-250 and then lowers back down to 180-190.... It doesn't seem like it should be getting that high?
I have a Koyo 2 rod radiator, dual 12 inch flex-a-lite pusher (normal configuration) fans, stock t-stat, distilled water, and problend motorsports 40 below water additive. 1.1 bar radiator cap.
Any ideas on what I can do to get it to run cooler? There are no air bubbles in the system, ive bled it multiple times, and top off the water after every few runs if it needs.
If you are not running an oil cooler, I would look into that. An oil cooler can dramatically lower the temp of the engine overall. I had a cooling problem on my sr, ran about 220 during runs. After adding the oil cooler it ran consistently at 185 during hot laps lol.
Invest in one.
di-devol is offline   Reply With Quote
Old 03-19-2014, 12:08 PM   #3692
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
I do need to invest in an oilcooler. I do not have one.
xoxide is offline   Reply With Quote
Old 03-19-2014, 12:54 PM   #3693
CooleyXXXIII
CooleyXXXIII is an unknown quantity at this point
Quick question just installed my harness , what does the power wire from the battery go to?
Insagram: CooleyXXXIII
CooleyXXXIII is offline   Reply With Quote
Old 03-19-2014, 04:38 PM   #3694
kalel540
kalel540's Avatar
kalel540 is an unknown quantity at this point
Got some sexy stuff today in the mail.
kalel540 is offline   Reply With Quote
Old 03-20-2014, 07:51 AM   #3695
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
Just need to get my intercooler piping, battery relocated, AC stuff fitted, and other do hickies. It's going to feel alot different than my gutted s13 coupe to now being a fully loaded vert lol.
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 03-20-2014, 10:47 AM   #3696
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Looks good! Any exterior shots? What turbo/manifold setup is that?
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 03-20-2014, 12:32 PM   #3697
93egallmotor
93egallmotor's Avatar
93egallmotor is an unknown quantity at this point
how is everyone connecting their fuel feed to the oem fuel dampner without using an expensive kit? my setup is basic, stock turbos, ecu, boost. dont need a crazy fuel setup. just curious if there is a simple way to plumb this.
Zenki s14 1 J Z- G T E
93egallmotor is offline   Reply With Quote
Old 03-20-2014, 01:19 PM   #3698
Sky80
Sky80's Avatar
Just run some 5/16th fuel hose to the fuel damper? Cheapest easiest way
Old 03-20-2014, 01:49 PM   #3699
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Originally Posted by BiG MiKE86 View Post
I'll measure mine tomorrow - I think that's about where I'm at as well. Get nuts lab brackets and custom 2" aluminum mounts
Measured clearance from back of head to firewall as ~1-1/4"-1-1/2"
I also shimmed my mounts to fix the rubbing issue I was having from my mounts being too short
Made some 1/8" aluminum shims
Lifted engine a bit
Inserted shims and patted myself on the back
FYI get nuts lab brackets (modified) with 2-1/8" solid mounts is what's happening there
Hood closes with no issues now except for the front hook touching the hood a bit
BiG MiKE86 is offline   Reply With Quote
Old 03-20-2014, 06:52 PM   #3700
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Take the hooks off? That's what i plan on doing, im just gonna keep them in my tool box until i need them.
Old 03-20-2014, 07:28 PM   #3701
BiG MiKE86
BiG MiKE86's Avatar
I left em both on but the front one I just "rocked backwards" and left it there
Gettin close to rollin!
Old 03-20-2014, 07:44 PM   #3702
dpkid101
dpkid101's Avatar
dpkid101 is an unknown quantity at this point
That things looking good man. Nice and clean
dpkid101 is offline   Reply With Quote
Old 03-20-2014, 07:45 PM   #3703
Mister.E
Mister.E's Avatar
Trader Rating: (53)
I have one of those K&N filters for my IACV too. Did you oil it or run it dry? i was reading on supraforums that the people that were oiling were getting gummed up IACV's and they would stop functioning correctly. I was thinking about running mine dry, but im unsure if it would even be effective like that.
Old 03-20-2014, 07:47 PM   #3704
BiG MiKE86
BiG MiKE86's Avatar
Thank you sir
I did not come with oil so I put it on as-is. I believe it comes pre-oiled but I'm not sure. People have issues all the time with these type filters and MAFS or other sensors when they overdo it on the oil. I run dual K&N's on my G37 with no issues thusfar
Old 03-20-2014, 08:22 PM   #3705
EvilEgg13
EvilEgg13 is an unknown quantity at this point
2JZGTE First start problems
I am assuming that my turbos are bad?
This is the sight I was greeted by after starting my 2JZ for the first time.
That being the way it is can USDM 2JZ turbos be swapped out without adjustment onto a Aristo 2JZ?
Any opinions or alternatives would be great.
EvilEgg13 is offline   Reply With Quote
Old 03-21-2014, 01:00 PM   #3706
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
Went to tweakd's shop yesterday, cam is an awesome dude. Glad I went tweakd. And he's only about an hour away. Hoping to have my car up and running here in a couple weeks. I've been getting a little lazy lately. Going on a little over a year.
Last edited by turbob16ef; 03-21-2014 at 01:02 PM.. Reason: I isn't spellingd correctling.
turbob16ef is offline   Reply With Quote
Old 03-21-2014, 07:42 PM   #3707
93egallmotor
I get that part. But is there a certain fitting to physically hook it up to the dampner? I mean there has to be because the feed inlet is just a threaded hole lol
Old 03-21-2014, 08:34 PM   #3708
Sky80
Sky80's Avatar
Take a picture and post it. Are you talking about the inlet of the fuel rail? Or the damper that is lower on the block?
Old 03-21-2014, 09:05 PM   #3709
CooleyXXXIII
Completly stumped when it comes to this wiring installed my harness hooked everything up an when I turn the key the starter just dings off the flywheel
Old 03-22-2014, 10:23 AM   #3710
dpkid101
dpkid101's Avatar
Before I deleted mine I just cut the threaded end off with a pipe cutter and clamped a hose down on it. That worked fine for the little time that I used it.
But what you could do is get like a 90 degree fitting with just a 5/16th hose barb on it and run your fuel hose straight into the rail. Bypassing the dampner. Unless you really just want to use the dampner.
Old 03-22-2014, 03:24 PM   #3711
93egallmotor
awesome man. that's the kind of info I was looking for. id rather keep the dampner because of the lack of room between the rail and the firewall. now if I can just find the thread pitch of that dampner fitting ill be set. thanks for the help my man!
Old 03-22-2014, 04:41 PM   #3712
kalel540
kalel540's Avatar
Anyone using the Pro torque cast manifold know the thread pitch for the turbo flange bolts?
Is it M10 X 1.25" or M10 X 1.50"?
I've been looking online but can't find anything.
Old 03-22-2014, 07:43 PM   #3713
Mister.E
Mister.E's Avatar
Trader Rating: (53)
This:
http://www.summitracing.com/parts/ea...FcRefgodrDcAjw
or this + a 90* -6AN fitting:
http://www.driftmotion.com/12mm-x-1-...r-p/dm2172.htm
Old 03-22-2014, 08:01 PM   #3714
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Mike, would you mind taking a close up photo of how you mounted your FPR? i have the same one and was wondering where i was going to mount it.
Old 03-22-2014, 08:03 PM   #3715
BiG MiKE86
BiG MiKE86's Avatar
Sure ill do that tomorrow - there's really only one spot it will bolt to
It shares one hole with the dipstick
Old 03-22-2014, 08:13 PM   #3716
Mister.E
Mister.E's Avatar
Trader Rating: (53)
did yours come with the bracket? im not sure if i got one or not, ordered it from DM.
Old 03-22-2014, 08:20 PM   #3717
BiG MiKE86
BiG MiKE86's Avatar
Oh sorry, no. I have the Freed Engineering bracket.
http://www.freedengineering.com/onli...gulator-mount/
Old 03-22-2014, 09:10 PM   #3718
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Ok cool, ill have to pick one of those up. You dont have to take a pic of your setup now, thanks for the info man.
Anyone know if that bracket fits a 1JZ?
Old 03-23-2014, 08:22 AM   #3719
BadazzSr20
BadazzSr20 is an unknown quantity at this point
Hey guys,
I'm not trying to read 125page to find my question. Does anyone know if zero lift brackets any good? I have the eBay ones and they were
GOod for 400whp. Now that I'm making a lot more power there no good the reign to sink. Anyone know a good bracket kit for cheap. I like zero lifts price but I don't want to be in the same boat as i am now.
Anyone have any info on there brackets of a reputable bracket that will hold 1000+ wheel?
BadazzSr20 is offline   Reply With Quote
Old 03-23-2014, 12:16 PM   #3720
dpkid101
dpkid101's Avatar
Since everyone is talking about fpr mounting figured id toss up a picture. I just used some kind of bracket that was already on my manifold. Seems to work pretty well.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
