Old 02-14-2017, 05:51 PM   #3721
Arteeste
Arteeste's Avatar
Arteeste is an unknown quantity at this point
Arteeste is offline   Reply With Quote
Old 02-15-2017, 09:10 AM   #3722
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Originally Posted by silviaks2nr View Post
where's the wide tire pics
Damn that's wide. Are your fenders pulled?
spooled240 is offline   Reply With Quote
Old 02-15-2017, 02:01 PM   #3723
silviaks2nr
silviaks2nr's Avatar
Originally Posted by ka-titties View Post
I've got 255's on 17x9 +22 RPF1's. Fenders slightly pulled all around.
A little bit, maybe 3/4" at most. 295/30 1.5* ish camber
Old 02-16-2017, 08:33 AM   #3724
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
Damn still my all time favorite max rubber stock metal S14! This is the standard my friends!
Quote of the year?
Originally Posted by projectRDM View Post
Zoom in a little more, it's not blurry enough.
bshotts is offline   Reply With Quote
Old 02-16-2017, 09:45 AM   #3725
97SerevoSX
97SerevoSX is an unknown quantity at this point
What size wheels are these!?
97SerevoSX is offline   Reply With Quote
Old 02-16-2017, 01:20 PM   #3726
silviaks2nr
They are 18x11 +30 rear. Thanks!
Old 03-06-2017, 02:16 PM   #3727
stockbee
stockbee's Avatar
stockbee is an unknown quantity at this point
Send a message via AIM to stockbee
Wheel/tire setup: Front fenders pulled pretty decently. Rear is the same way.
-Advan TCIII wheels Front: 18x9''+25mm with 10mm spacer. Rear:18x10''+35mm
-Falken RT615K tires, square setup: 275/35/R18
Untitled by eric.burnett09, on Flickr
stockbee is offline   Reply With Quote
Old 03-06-2017, 02:45 PM   #3728
TheRealSy90
TheRealSy90's Avatar
Man I'm surprised that 295 on the 11j still looks stretched at the sidewall haha.
Do you think a 295/40 would have the same fitment on a 17x11 as the 295/30 on 18x11?
Such a good signature.
Old 03-06-2017, 06:13 PM   #3729
97SerevoSX
It'll depend on the tire manufacturer more than anything. Nt05s run kind of narrow but an RS-3 runs a bit wide (I think).
Old 03-21-2017, 11:57 PM   #3730
600supersport
600supersport's Avatar
600supersport is an unknown quantity at this point
Maximum TIRE(Rubber) fitment thread
I picked up a set of Konig Hypergrams recently since they look pretty good, weigh very little, don't cost much and have at least some semblance of quality control.
These are 18x10.5 +25 with 315/35 R888s. To keep the S15 HLSD and add more beef, but pay about 1/2 total of what DSS axels cost, I went with 350z axels which, with the adaptors will add a little more than an inch in length & track width from stock. So these wheels stick out that extra ~1.1" more than most. These wheels/tires would probably clear ok with a pretty big fender pull and to save the factory fenders, I decided to pull the fenders and will rivet on these free fender flares (I've never been a fan of them, but they actually go pretty well). My front 17x9 +25 still fit within the fenders so I don't see much use for discussion there. I'm running between -1.7* of camber all around.
For an extra $3-4,000, I could've achieved better fitment and maybe more axel strength, but I'm about to be a Dad so that'd be silly. For all that money, maybe in a few years, I could probably squeeze in a +40 18x12 with a 335 tire since there's a fair amount of space left for more wheel/tire inward toward the spring now. Hopefully these 315s will be plenty sticky on the street and at the track though LoL. Adding about 4" of width to the rear of the car will be interesting on track once the weather clears up.
600supersport is offline   Reply With Quote
Old 03-22-2017, 12:07 PM   #3731
2bar_silvia
2bar_silvia is an unknown quantity at this point
Here's mine. 18x9.5 +15 with 265/35/18 for the fronts and 18x10.5 +18 with 315/30/18 for the rears. Tires are Toyo R888's.
2bar_silvia is offline   Reply With Quote
Old 03-22-2017, 12:29 PM   #3732
spooled240
spooled240's Avatar
^^ Really digging your setup ^^ are your front fenders pulled? They look stock. Any other pics to see if/how far they stick out past the fenders?
Old 03-22-2017, 12:40 PM   #3733
2bar_silvia
Front fenders have not been pulled, just rolled.
Old 03-22-2017, 02:18 PM   #3734
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
Wait, what? Axle length doesn't determine track width. The lengths of the multilink arms do.
You're going to install flares over the pulled fenders? Why? It won't gain you any clearance. Either leave the pulled quarter panel as-is, or install the rivets and cut out all the metal underneath.
jaysgottaredtop is offline   Reply With Quote
Old 03-22-2017, 02:49 PM   #3735
600supersport
I'm not hacking apart a factory fender and welding it back together then filling/paint/etc when I only need a bit of extra clearance for the tire to miss the fender, so a bit of pull to help the fender flare will be sufficient. If I change wheels/tires in the future, I'm not married to this fender flare or over fenders.
The multi-link arms need to accommodate whatever length axel you have (shorter or longer) unless you want a binded 350z axel. The 350z axels need more physical space than the s14 axels do so all the arms push the hub outward, hence this rather excessive fitment.
Old 03-22-2017, 04:28 PM   #3736
jaysgottaredtop
1) Slapping a flare above your pulled quarter will not gain you any tire clearance.
2) You don't want to cut the factory quarter... but you're cool with pulling the piss out of it, and then drilling holes to rivet on a flare?
Old 03-22-2017, 04:44 PM   #3737
spooled240
spooled240's Avatar
fuck that's perfect. I have 18x9.5 +17 all around I'm thinking some 255's or shit, maybe 265's will fit fine with minimal camber on a stock body s14 that's not too low..
Old 03-22-2017, 05:01 PM   #3738
600supersport
The car isn't slammed and the tires will only barely touch the fender now so a little pull would be enough to clear the tires and welding a couple little holes shut later would be easy.
Old 03-23-2017, 08:03 AM   #3739
silviaks2nr
18x12 +40 will never fit with stock subframe IRS.
Old 03-23-2017, 08:23 AM   #3740
600supersport
I'll have to measure to be exact, but there's about an inch between the tire and spring now so maybe +30, but it's not something I'm very interested in. I'm sure the longer axels are key.
Old 03-23-2017, 09:00 AM   #3741
Arteeste
Arteeste's Avatar
Anyone running a 255 square setup on a s13 with an s14 rear subframe ?
Old 03-23-2017, 09:22 AM   #3742
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Yup.
Works on stock bodied hatch and coupe if you don't go crazy on offsets.
I'm at 17x9 +22 in front, 17x9.5 +38 in back. 9.5 +38 also works all the way around with a spacer in front.
-3.5* F, -1.5*ish R for camber.
Old 03-23-2017, 09:24 PM   #3743
Mintyboy
Mintyboy's Avatar
Mintyboy is an unknown quantity at this point
Posted on the Zenki thread but decided to show some love in here as well.
18x9 +20
255/35/18 all around
Mintyboy is offline   Reply With Quote
Old 03-23-2017, 09:30 PM   #3744
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
^maybe a picture taken from a different angle would help your car fit in this thread a little better. Rubber numbers?
Tuners are big bullies
feito is offline   Reply With Quote
Old 03-24-2017, 05:27 AM   #3745
jr_ss
I'd have to measure to be exact, but there's about an inch between the tire and spring now so maybe +30, but it's not something in that interested in. I'm sure the longer axels are key.
Typically, you'd run into issues with the LCA before the spring.
Old 03-24-2017, 07:10 AM   #3746
Mintyboy
Mintyboy's Avatar
Will get a better pic after work. Rubber size is 255/35/18 all around
Old 03-24-2017, 10:54 AM   #3747
600supersport
I'll be sure to measure next time exactly how much space is left.
Old 03-26-2017, 12:50 AM   #3748
tonee
tonee has a little shameless behavior in the past
Woops just realized I posted in the wrong thread ��
tonee is offline   Reply With Quote
Old 03-27-2017, 08:49 AM   #3749
silviaks2nr
Ask in the wheel fitment questions thread not this one.
Old 03-27-2017, 09:24 AM   #3750
travon47
travon47 is an unknown quantity at this point
Never seen a wheel run into the rlca , mine use to hit my coilover when it would gain camber when it pushed up. Plus how his rlca is adjustable (knuckle side) it pushes the wheel away from where it could possibly hit it, it will probably hit the coilover first since that is fixed the knuckle.
I think the modified Villians stubs would have worked great for you instead of the adaptors since you are running such large tires. You don't need to run extended lca's with them since they shrink up the stub axle mounting point inwards to allow for the slightly wider g35/z33 axles in a s-chassis
travon47 is offline   Reply With Quote
