#3751 |
![]() Join Date: May 2010
![]() Feedback Score: 21 reviews
Does anyone have or know where I can find the OEM twins blowoff valve recirculation tube for a 1j? The little 90 deg rubber elbow that runs from the BOV to the IC piping... Mine split and I cannot find one anywhere.
#3752 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Great reason to go single turbo =]
#3755 |
not sure how i feel about this, but i cant find a 5/16 barb to banjo fitting to save my life. so im willing to give it a try. seams as if it will seal, but we will see i guess. can anyone see an issue with this?
Zenki s14 1 J Z- G T E |
#3756 |
![]() Join Date: Aug 2008
![]() Feedback Score: 7 reviews
You couldn't find a barb fitting to replace the whole banjo setup? That will work just keep an eye on it. IMO I wouldn't leave it like that for a long time.
Whats the thread pitch of the bolt that runs through that banjo? 14mm x 1.5? 12mm x 1.25? |
#3758 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
0.3125 (5/16) inch = 7.9375 millimeter I would recommend using copper crush washers though. |
#3759 |
![]() Join Date: Jul 2007
Trader Rating: (18)
![]() Feedback Score: 18 reviews
Hey 93egallmotor, I have this one that might be better for you. It will probably seal better since it's straight. That is the intake plenum fitting right?
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
#3760 |
Trader Rating: (53)
The fitting he is showing is the one that was hooked to the fuel pressure dampener and the fuel rail. he just cut the rest of the crap off so he could use the fitting.
#3761 | ||
yea it would be temporary. and the thread pitch is 12x1.25. i know i can get a carb fitting to convert to -6, but i dont need all that, the only barb/ banjo fitting is the one we are talking about below here Quote:
i saw this online as well but i wasnt sure if it would be "thick" enough for the toyota banjo bolt. so i figured id just give this a try because it was free lol
#3768 | |
![]() Join Date: Oct 2010
#3770 | |
Which of these tranny options is: 1. Inexpensive. 2. A solid upgrade over an r154. 3. Can hold 500whp / 800whp.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#3771 |
![]() Join Date: Oct 2012
The 350z trannys run about $500 and I have forund them for $300
The 2 main problems with this swap is you have to machine 1/2in off the front of the bell housing and even with the linckage cut the shifter still sits about 4in to far back, to some this may not be a big deal but I want everything to look stock, and it would be nice if the trans did brake to be able to swap it and not have to machine the housing, SPs 350z drag car makes over 1100whp and the car is still on the tranny that came in the car from the factory for the bmw swap I believe it's a m3 tranny not sure which one, they are under $700 American and a bunch of over seas guys use them, I talked to a guy at TX2k from the Netherlands that had one and the car makes over 1000whp and was on the same tranny for the last 3 years, he said it's a very popular conversation over there |
#3772 |
ATLspeed posted problems with ebay mounts a lot of pages back, seems like those mounts are problem mounts. Don't buy them!
The black sprayed THIN looking mounts that are common on ebay have bad fitment. Especially the right mount, it sits too far forward(looking from drivers seat) and there is no way to adjust it. In order to get the trans to sit centered in the shifter hole you have to push the tranny to the right and that makes the R-engine rubber mount contort BADLY! The rubber mount sits at a ridiculous slant and not straight up like it should. So basically it will not work without cutting/welding and moving the bolt holes further back! If I wanted to do all that I would've made my own mounts already. Don't waste your money like I did ![]() ![]() Last edited by JZ13; 04-08-2014 at 02:53 PM.. |
#3773 | |
#3774 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
They do give you a problem with mounting and the rear of the motor/trans going to the right of the car giving it a nasty angle. I had worn shitty mounts so they just conformed to it. Eventually i will switch to DriftNutz or Ben Freed.
Been Freed mounts may sit too far back for my liking ironically.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#3776 |
anybody have any issues with cxracing s14 2jz manifold,downpipe, intercooler piping for single turbo? im thinking of going that route and i just wanna make sure they are direct fit as what they claimed to be
#3777 |
Alright guys I have a question I recently bought my buds 2j 240 off him as he is going into the military. the spedo and tach was never wired up and I know I need to wire it up using Dakota boxes but is their a guide out there on how to do it?
Sent from my iPhone using Tapatalk |
#3778 |
This is a decent looking guide I have found. Haven't got around to doing it yet though, so cannot verify.
http://zilvia.net/f/showthread.php?t=449651 |
#3779 | |
Alright thanks, one thing though this only discuses the spedo I also want a working tach Sent from my iPhone using Tapatalk |
#3780 | |
