Old 04-17-2018, 05:05 PM   #3811
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
Originally Posted by slider2828 View Post
No that hole is way too big.... It should be closer to a pin hole size unless you have a fitting on the block that restricts oil.
Agreed, make sure the bottom male end (mounted to turbo) has pin sized hole.
GT2871r .86
1000cc ID
S3 cam
BC springs
forged internal 8.5:1 compression
stock exh manifold with internal gate
freddy manifold
aeromotive 340 pump
350hp dynapack (unmodified dynapack)
330hp with hood closed w/heatsoak
tuned on CA 91 oct by Koji @ Autotalent
instagram : battery1882
www.sterculture.com
battery1882 is offline   Reply With Quote
Old 04-17-2018, 06:37 PM   #3812
Driftaholic84
Driftaholic84 is an unknown quantity at this point
The block end, has the oem banjo fitting on it.
Where do I get said restrictor?
Driftaholic84 is offline   Reply With Quote
Old 04-17-2018, 09:37 PM   #3813
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
So the consensus for a solid reliable det head setup seems to be.
B15 Roller Rocker Lifters
dual rocker arm guide conversion
jwt cams and springs
Correct?
Will this setup allow you to spin to 9k rpm safely?
Anything else we should add or modify while in there?
e30gangsta is offline   Reply With Quote
Old 04-17-2018, 10:42 PM   #3814
slider2828
slider2828's Avatar
You can get any where... ATP Turbo, FRSport, Enjuku.. just remember its the smaller diameter restrictor, not the big one you have....
Turn and Burn!
Old 04-18-2018, 03:40 AM   #3815
derass
~0.030" for ball bearing turbos
Old 04-18-2018, 07:01 PM   #3816
Driftaholic84
Ordered one from enjuku today for like $14.. thanks everyone.
Old 09-17-2018, 08:45 AM   #3817
Bleakley
Bleakley is an unknown quantity at this point
Not an SR, but curious what some of your guys' input would be...
KA24DE-T, 360-375hp (preferably whp) with the supporting mods. Note on cams --> Only will play around with mixing / matching stock cams.
GT2871R/GTX2867R? Or GTX2871R?
Or GTX2971R (84 trim) due to being 2.4L?
If GT2871 or GTX2867 I'd have to run boost ~21.5+.
If GTXxx71R I'd only have to run boost ~18psi.
Bleakley is offline   Reply With Quote
Old 11-26-2018, 11:40 AM   #3818
JacksonBrown
JacksonBrown's Avatar
JacksonBrown is an unknown quantity at this point
GT2871R .64 AR
S14 SR
Pro EFI 48
Stock head
Stock block
Stock exhaust manifold
Sard 550cc Injectors
Sard Fuel Pressure Regulator
Nissan OEM N15 Pulsar 70mm throttle body
Tomei throttle body adaptor
Stock intake manifold - port matched to 70mm throttle body
FMIC
3" exhaust from turbo back
91 octane pump gas
17.8 psi boost
318.81 whp / 281.17 ft/tq
Tuned by Justin @ Black Market Racing, Phoenix Arizona
JacksonBrown is offline   Reply With Quote
Old 01-04-2019, 10:18 PM   #3819
DoingOK
DoingOK is an unknown quantity at this point
I bought an SR20DET motor for my son to build for Christmas. He currently has a 1991 180SX which has a stock SR20DET redtop in it which will be replaced with this "built" spare. We are reviewing turbo upgrades to go along with his build and happened upon this thread. So far, we've had the block pressure checked, bored (86.5mm) and decked 10 thousandths. I already purchased BC 264 cams, BC springs, titanium retainers, SuperTech inconel oversized valves with all new guides and seals, BC forged rods with JE forged pistons, King bearings and a new HKS tubular exhaust manifold. Right now we are going to use the stock intake manifold with a Radium fuel rail, 750cc DeatschWerks injectors and an Aeromotive FPR. The head is going in to get cleaned up and a port/polish/valve job will be accomplished. He's looking for 350-400whp to be used for some road course racing @ VIR. He's been eyeing the GTX 2867 Gen2 series. With the current parts list he has, would the 2871R be a better choice for his desired output?
DoingOK is offline   Reply With Quote
Old 01-05-2019, 08:13 AM   #3820
e30gangsta
If you have the money to spend on a gtx2867 gen 2, might as well buy their new g550. The 2871r is old tech. The new one has insane amounts of response and great power. Also ditch those bc 264's and run some jwts4hl's.
Old 01-05-2019, 09:09 AM   #3821
DoingOK
Thanks for that info....I'll check it out. I didn't realize people are not fond of the BC cams.
Old 01-05-2019, 04:34 PM   #3822
e30gangsta
Ehhh they're not horrible. But jwt s3, s4, or s4hl is the much better choice.
Old 01-06-2019, 11:43 AM   #3823
JL240
JL240's Avatar
JL240 is an unknown quantity at this point
https://c1.staticflickr.com/5/4847/3...78bc57_o_d.png
Dyno tuned 2 days ago 391hp 436tq. Stock bottom end
Sr20det black top, gt2871r .86, hks bottom mount mani, nismo740 inj, Jim wold s4 cams, and water meth kit
These torque #s don’t seam right to me wouldnt mind someone’s opinion on why the two # is so high
JL240 is offline   Reply With Quote
Old 01-07-2019, 01:43 PM   #3824
fatduece
fatduece is an unknown quantity at this point
Lol you got those feel good numbers bruh!
fatduece is offline   Reply With Quote
Old 01-07-2019, 02:16 PM   #3825
ultimateirving
ultimateirving's Avatar
All that should be more than enough to support your power goals and then some. The 2871r is tried and true for this power range, but is at about its limit.
Z32 with lq4 swap
Old 01-07-2019, 06:04 PM   #3826
derass
That thing is spooling nicely. I assume that's around 20 psi. So full boost at 4300 RPM is really good, especially since it's a 0.86.
Old 01-07-2019, 07:51 PM   #3827
JL240
JL240's Avatar
Yes you are correct great combo .86 with the s4
Old 01-14-2019, 01:14 AM   #3828
SidewaySSS
SidewaySSS is an unknown quantity at this point
Used a 2871 with Jun 256/10,5 cams on an otherwise stock motor, very impressive in a 800kg car.
No Dyno graphs but made 215kw atw at 15psi, messed around with higher boost & e85 with some good results but this is a daily driver & needed to have it super reliable.
I craved a little more power but wanted to stay at 15psi max so I opted for a GTX2976r, as I had no interest in going high on the boost, I ordered it with a 0.63 housing & T04B comp housing, capped it off with a SS bottom mount equil length manifold.
The results were more than exceptable 15psi by 4100rpm, 243kw @ 7100rpm.
I am thinking of maybe doing a cam change to the s4 perhaps or Tomei Pro 260/12 Hyd.
SidewaySSS is offline   Reply With Quote
Old 05-10-2020, 12:41 PM   #3829
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
Swapped out the stock exhaust manifold for a jazz manifold and picked up 30hp with the retune.
https://youtu.be/6QdBJtoyxYo
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 08-11-2020, 12:21 PM   #3830
TheRealSy90
TheRealSy90's Avatar
Has anybody actually installed the AGP 2871r turbine housing that has the Tial MVs external wastegate flange? I have a manifold that I don't really want to modify with a gate. Would love to run the external gate off the turbine housing.
I'm skeptical that it actually clears the strut tower and brake components on LHD? If anyone has photos of the AGP external gate turbine housing installed i'd love to see it.
I picked up a 2871r, first time owning one. Has an HKS actuator already. I'm tempted to try porting the internal gate, but I know nothing will work as good as external.
Such a good signature.
Old 08-19-2020, 09:16 PM   #3831
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Like this?
lexus baby
5t341tH is offline   Reply With Quote
Old 10-04-2020, 09:47 AM   #3832
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Sorry for the big photo but s14 Sr20det
86.25 wiseco pistons 9:1 compression
Eagle rods
Acl race bearings
750cc injectors
Gt2871r .64 ar
Tomei expreme manifold
3 inch full exhaust
Mac boost controller
Made 290hp and 257 tq at 14 psi
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 10-04-2020, 03:38 PM   #3833
TheRealSy90
Originally Posted by 5t341tH View Post
Like this? [IMG][/IMG]
Yes exactly what I said.
Old 03-26-2021, 02:38 PM   #3834
spools420a
spools420a's Avatar
spools420a is a well-known jackass
Hey what size oil restrictor do we run with a redtop sr and 2871r journal bearing 2871r ( NON ball bearing)?
I have a rev9 2871r and the specs are
Compressor Wheel Diameter: 71mm / 52mm Trim
Turbine Wheel Diameter: 53.85mm / 76mm Trim
Exhaust Trim: .64 AR
Cooling Type: Oil and Water Cooled
spools420a is offline   Reply With Quote
Old 03-26-2021, 09:22 PM   #3835
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
lok is offline   Reply With Quote
Old 05-04-2021, 02:24 PM   #3836
spools420a
spools420a's Avatar
Hey all what psi would be recommended to make 300whp with this common setup of
redtop sr20
2871r - 64
z32 maf
550cc inj
freddy fmic
enthalpy ecu
91 oct and base timing program
basic bolt ons like
megan 3 inch test pipe
megan turbo elbow
mbc
though oem exhaust piping and muffler test pipe back.
Old 05-04-2021, 02:27 PM   #3837
spools420a
spools420a's Avatar
Originally Posted by lok View Post
Thanks!mines a little larger at 1.8mm but should be good.
Old 05-04-2021, 04:50 PM   #3838
slider2828
slider2828's Avatar
You guys still runing BOVs on this? Everyone says they are useless.... what you guys think?
Turn and Burn!
Old 05-10-2021, 10:12 AM   #3839
TheRealSy90
I assume if i'm using the oem s15 bb restricted banjo bolt in the oil feed line to the block, then I shouldn't use the restrictor fitting on the turbo end?
Old 05-19-2021, 11:43 AM   #3840
jr_ss
Correct. One or the other, not both.
