Old 04-17-2014, 02:35 PM   #3811
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
I would love to use the cd009 but the fact that the shifter sits (4in from my understanding) further back bothers me. I need to find out which years are the worst and how to identify by looking at the trans. Found this on the supra forums
Pro's are its a close ratio gearbox just like the v160. so acceleration will be far better than an r154 and RPM drop will be less than the r154 the getrag 6 speed gears are:
Supra MKIV
First gear: 3.827:1
Second gear: 2.360:1
Third gear: 1.685:1
Fourth gear: 1.312:1
Fifth gear: 1:1
Sixth gear: 0.793:1
350z 6 spd ratio's
1st 3.794
2ed 2.324
3rd 1.624
4th 1.271
5th1.000
6th .794
If anyone has an IACV for a 2jzgte I need one as mine is not working properly
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 04-19-2014, 12:50 PM   #3812
xoxide
xoxide's Avatar
xoxide is an unknown quantity at this point
Mark me down in the history books guys
xoxide is offline   Reply With Quote
Old 04-19-2014, 03:14 PM   #3813
ATLspeed
ATLspeed's Avatar
^^^Don't feel bad, I have one that is missing a small chunk out of the ring land. A fuel line popped off while I was doing a test run.
*I'll post mine when I get back home.
95 Supra Turbo
Old 04-19-2014, 08:43 PM   #3814
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Clicked off a 9.4 @ 148mph last night. Left off the footbrake @ 2psi. Can't wait to dump the transbrake on 18psi! haha
Deftec is offline   Reply With Quote
Old 04-19-2014, 10:27 PM   #3815
xoxide
xoxide's Avatar
I would've been fine w just a ring land lol, not so much the cracked piston.... Surprisingly enough the block is perfect.
Will be monitoring my afr's a hell of a lot closer from now on.
Old 04-20-2014, 10:45 AM   #3816
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
Throttle cable
Has anyone found a solution to a shorter throttle cable on a stock intake manifold?
RickS14 is offline   Reply With Quote
Old 04-20-2014, 01:34 PM   #3817
supercompact
supercompact is an unknown quantity at this point
I have been reading that a mid 90's Camry with 4 cylinder is the ticket. Not 100% sure on that yet though.
supercompact is offline   Reply With Quote
Old 04-20-2014, 01:35 PM   #3818
supercompact
That's moving out! Nice!
Old 04-20-2014, 05:42 PM   #3819
xoxide
xoxide's Avatar
So I have the opportunity to purchase a brand new AEM series 2 ECU setup for $900, for a 2jz-GE.... My wiring harness is already wired for using a 2j-gte ECU, so I believe it would plug in fine, my question however is would it be possible to run my 1jz off of the 2j-GE AEM unit?
Old 04-21-2014, 02:11 PM   #3820
Drink&Drift
Drink&Drift's Avatar
Drink&Drift is an unknown quantity at this point
Send a message via AIM to Drink&Drift
Mk3 Supra cable is perfect length, cant remember if turbo or non turbo though.
Drink&Drift is offline   Reply With Quote
Old 04-21-2014, 02:12 PM   #3821
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Does it bolt up? S13 or S14?
Just noticed CXRacing released a throttle cable bracket!
http://www.cxracing.com/mm5/merchant...gory_Code=OTHS
BiG MiKE86 is offline   Reply With Quote
Old 04-21-2014, 02:18 PM   #3822
EvilEgg13
EvilEgg13 is an unknown quantity at this point
I recently bought a MK3 turbo engine throttle cable and it was about 4 inches short on a s13
EvilEgg13 is offline   Reply With Quote
Old 04-21-2014, 05:10 PM   #3823
Drink&Drift
i wish i knew which one i used, a friend gave me 2 different Mk3 ones, and one fit perfect (S14)
Old 04-21-2014, 06:13 PM   #3824
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
such thick steel and bracing for a throttle cable bracket lol
Mr. Phonso is offline   Reply With Quote
Old 04-21-2014, 06:49 PM   #3825
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Anyone know of a sway bar that will clear a JZ Swapped S-Chassis with a Nismo Power brace? I can't see one working... considering selling the Nismo power brace and putting a sway bar on the car, and having a brace built using the stock parts.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 04-22-2014, 01:40 AM   #3826
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
is anyone here running a tial BOV? if so what spring are you running?
i'm running a 11lb spring i beleive and getting some pretty intense flutter..
https://www.youtube.com/watch?v=W2iS...hZXtWyZVQfc2hQ
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 04-22-2014, 08:17 AM   #3827
xoxide
xoxide's Avatar
Bump, anyone?
Old 04-22-2014, 08:42 AM   #3828
turbo-2ns
turbo-2ns is an unknown quantity at this point
The pinouts are not the same you will have to move some stuff around
turbo-2ns is offline   Reply With Quote
Old 04-22-2014, 09:37 AM   #3829
hockeyrules
hockeyrules is an unknown quantity at this point
Would the sikky clear?
I think im on the 8psi spring and I don't have any flutter, but I would probably need to double check that!
hockeyrules is offline   Reply With Quote
Old 04-22-2014, 10:38 AM   #3830
xoxide
xoxide's Avatar
such as? I have a chasbays harness I can send back to be repinned
Old 04-22-2014, 12:03 PM   #3831
turbo-2ns
Gte has a bunch of extra stuff for coil on plug and turbo stuff, and a few other things, best bet would be to compare the 2 pin outs from AEM and swap/rewire everything your self, Chase bays can't get a stock harness to work much less one not using the right ecu
I believe the oem replacement supra TT harness we used had 24pins out of place from Chase bays, sent it back still same problem, found pin outs and fixed it our self, s13/2jz swap harness from them had all the same problems, plus all the chassis wires where wrong as well ,a harness from them is about as usefull as tits on a duck and there customer service is about as good as a 4 day old tuna fish sandwich you forgot to take out of your car.
The jumpers in the ecu will also be wrong, you will have to change them your self or send the ecu to aem and have them change all the jumpers to run COP
Old 04-22-2014, 12:37 PM   #3832
erics240sx
erics240sx is an unknown quantity at this point
Damn. Lmfaooooo AMEN!!!
erics240sx is offline   Reply With Quote
Old 04-22-2014, 12:54 PM   #3833
BiG MiKE86
BiG MiKE86's Avatar
Thank god i went with wiring specialties for my S13/2JZ! Works perfect
Old 04-22-2014, 01:14 PM   #3834
turbo-2ns
Have had no problems with the wiring specialties or the tweek harnesses, have had problems with many Chase bays including one for a Honda which is the easiest harnesses in the world to make work, unless you forget to put in the power harness and install the wrong size pins in the ecu plug which is what they did.
Try figuring that one out, every thing pins out correctly, but nine of the pins in the plug make physical contact with the ecu only took about a month to figure out lol if you plan on buying a Chase bays harness send you your money Ti me and I will send you the stock harness out of my neighbors 93 Chevy astro van, it may not look nice buy will work just as well as the Chase bays
Old 04-22-2014, 06:02 PM   #3835
RickS14
RickS14's Avatar
I just order that..seems a little to thick tho for just a throttle bracket..
Old 04-22-2014, 06:29 PM   #3836
BiG MiKE86
BiG MiKE86's Avatar
Let me know how it works. I want to order it as well just not a priority
But then again neither were these headlight finishing panels, cooling panel, and wiper motor cover from Unique Auto Creations =]
Old 04-22-2014, 07:47 PM   #3837
RickS14
RickS14's Avatar
Makes it looks cleaner
Old 04-22-2014, 08:22 PM   #3838
xoxide
xoxide's Avatar
That's pretty funny, ive had 0 issues with my Chasebays harness or their customer service.... It was originally built for 1j/1j ecu, no problems.... then sent it back for 1j/2j ecu, ran for awhile no problems.... Broke a pin and wasn't sure where it went, they emailed me back within 4 hours....
Guess im lucky
Old 04-22-2014, 08:35 PM   #3839
turbo-2ns
Only seems to be a problem the last year or 2 at first they made an awesome product now I can't buy one that works to save my life
Old 04-22-2014, 08:58 PM   #3840
Silviacraze05jr
Silviacraze05jr is an unknown quantity at this point
any recommended brand for power steering conversion line and clutch linr for the r154?
Silviacraze05jr is offline   Reply With Quote
