11-07-2015, 08:31 PM | #361 | ||||
You can fit a 7163 to one of these, which mean 500+whp. Anyone wanting to make more than that isn't even considering this manifold. Quote:
Not anymore. The crank and stroker kit are discontinued. Also, 8500rpm is attainable on the stock crank with an ATI damper. Quote:
9500 is silly. Not only is it ridiculously high piston speed, but you'd have to cut the crap out of the head to fit cams big enough to hold power out to that rpm. The KA literally screams torque, let it do it's thing. Long strokes spool turbos well. Quote:
Honda K-series bottom ends are massively superior to the 4G or KA bottoms. These engines designed in the late 80's aren't that great, but we've found ways to push them hard. Luckily the KA's oil pump is pretty awesome, which keeps these engines together.
11-07-2015, 10:59 PM | #362 |
Philosopher King
KAs running those pulleys don't last long at those RPMs. Those pulleys on fully balanced cranks might be the ticket.
G O L D E N B E A R R E P U B L I C |
11-08-2015, 05:20 AM | #363 | |
With the ati, and a gtx3071, the old redline whips by even on a stock head and cams. |
11-08-2015, 09:17 AM | #364 | |
Define "long". It all depends on how it's used. Obviously setting your rev limit at 8500 and banging it in a drift car is far different than a drag or street car. Road racing is probably the hardest on engines if you have a gearbox that keeps the R's up everywhere on track. kedbmx on kat.org has been running 800+whp and 8500 rpm for the last four years in his street car.
11-08-2015, 10:43 AM | #365 |
Philosopher King
All those nasty jumprope harmonics are still there. The damper is absorbing some of the vibration and canceling out some of the other.
My preference would be to totally eliminate the jumprope harmonics rather than mask or redirect them. Checkout this thread(and forum in general) http://www.nissanroadracing.com/showthread.php?t=3805
11-08-2015, 12:19 PM | #368 | |
Well maybe you can get BC to make you a crank, but they're discontinued on the site.
11-08-2015, 12:54 PM | #369 |
Philosopher King
They're all over the internet for about $1700 for the crank and around $3400 for the crank, rods, and pistons. They made a few hundred and seemingly sold them all to retailers.
11-08-2015, 03:56 PM | #370 |
When you need an aftermarket crank to use a motor for what you want to use it for then that motor is probably not the best choice for your desired application. Unless you are a factory sponsored race team.
11-08-2015, 04:18 PM | #371 | |
Bingo. Motors fail. I'd rather not be up shits creek when I lose one. |
11-08-2015, 04:24 PM | #372 |
This is my crank from... 5-6 years ago.
still haven't gotten a chance to finish the engine. The short block is sitting next to my monitor as I type. Even with the knife edge... I can't run the oem oil squirters.. Might try GTR dual squirters... |
11-08-2015, 08:55 PM | #373 |
In the Miata world, they are getting rid of squirters to accommodate beefier pistons. Flyin Miata for more info.
They believe the windage and consumption pose more of a problem then they are worth. In the D series Honda world, they are incorporated into the stock rod design, and excluded in aftermarket builds. The BC crank does not appear to be worth the fuss, what about the front sprocket anyway? The KA is a lot like the 7M, which are both a lot like Honda D series engines. |
11-09-2015, 12:05 PM | #374 |
Philosopher King
Maybe it's my background in old American muscle and trucks but a crank swap isn't s big deal to me. If you're willing to change out the entire induction setup on a turbo engine why not the rotating assembly too?
11-09-2015, 12:08 PM | #375 | |
I'm sure after all that the cost vs. benefit really goes out the window.
MRP Manufacturing |
11-09-2015, 12:11 PM | #376 |
Philosopher King
You have to clearance the block for the extra counter weights. Not a huge issue. Oil squirters are perhaps not an issue depending on a given build and the builders ingenuity.
11-09-2015, 02:22 PM | #377 | |
It's a cost issue. Doing crank swaps on Domestics is typically cheap. A Ford SVT 5.4 Forged Crank is $400. My issue is, when you dump tons of money into and engine, what are you really accomplishing? My "built" dream Ford 4.6 2V is $1,900 for a 800whp capable motor. If that motor takes a shit, I'm potentially out $1,900. If I build a "dream KA", with forged internals, crank, machine work, cams etc, it's sounding more like a $7k engine. If that pukes, I'm out $7k and that hurts. This goes back to that comment "if your swapping cranks, you have to wrong motor". If you want an engine that Revs to 9k with 2.4L of displacement, swap a K24. If you want a 3L iron block 500lb boat anchor that will make 4-digits, get a 2JZ. |
11-09-2015, 02:47 PM | #378 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
How did we go from talking about bolt on turbo kits to crank swaps and all sorts of crazy shit.
This thread is totally not about that. AT ALL.
11-09-2015, 04:07 PM | #380 |
Philosopher King
If we were concerned about money we wouldn't be in the hobby or business of modifying cars in the first place. It's a passion exercise not a cost benefit analysis.
Props to Tomei for keeping the passion burning.
11-09-2015, 04:13 PM | #381 | |
How is a crank swap not relevant? It is something that would really make that bolt on turbo worth the money...
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
01-05-2016, 02:55 PM | #383 |
01-06-2016, 01:01 PM | #385 |
01-06-2016, 09:23 PM | #387 |
You know jimmy, sometimes people think they are doing something good just as long as something is done. All you people in here wasting your damn time with this truck motor. This sh8ts trash. Take it out and either sr20 or jz. DONE.
01-07-2016, 09:05 AM | #388 | |
What makes the SR better than the KA, is it the aftermarket support? KA Max Power: 155hp @ 5,600rpm Max Torque: 160lb-ft @ 4,400rpm SR Maximum power: 140 hp-169 hp at 6400 rpm Maximum torque: 132 lb·ft at 4800 rpm Also, according to this site, the 'pros' seem to prefer the KA or acknowledges that it has potential. http://www.superstreetonline.com/how...issan-sr20det/
01-07-2016, 09:55 AM | #389 |
Super Moderator
Trader Rating: (73)
I have a KA-T and would go SR if I had the choice between an equally modified motor. Even if it had less power.
01-07-2016, 10:08 AM | #390 | |
hahahaha awesome obviously someone with a KA isn't really concerned about those jdm sweg brake caliper points shuebox-kun |
