Old 11-21-2017, 08:39 PM   #3961
outfronts13
outfronts13 is an unknown quantity at this point
I recently got a S13 what is the best size for running the stock camber set up
outfronts13 is offline   Reply With Quote
Old 11-22-2017, 08:57 AM   #3962
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
this should be good.
jumpman2334 is offline   Reply With Quote
Old 11-27-2017, 02:50 PM   #3963
hotrodv
hotrodv's Avatar
hotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfectionhotrodv is close to perfection
Big question!!
I'm buying wheels for an s15, it has R33 brembo caliper on the back, do you think work sp1 3pc in O disk will clear it?
hotrodv is offline   Reply With Quote
Old 11-27-2017, 07:16 PM   #3964
marveluz
marveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enough
Originally Posted by hotrodv View Post
Big question!!
Yes
marveluz is offline   Reply With Quote
Old 11-28-2017, 01:08 PM   #3965
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
Hello, I just ordered some 18x9.5 +12 Square G8s, for my stock bodied Zenki. I'm wondering if you think that 18s will be too big for the stock body, especially in front. Also does anyone have some pics of this setup? All the cars I've seen with 18s have some sort of aero. Also will I run into binding on the wheel well with stock angle?
Thanks
apex128 is offline   Reply With Quote
Old 11-29-2017, 08:53 AM   #3966
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Thanks
You're talking about S14 Zenki, right? 18's are fine on the stock Zenki. Aero is a plus though. Just pick your tire size carefully. Wouldn't recommend anything over a 40 profile.
What's your suspension setup?
"Simplicity is the key to brilliance." - Bruce Lee
simmode1 is offline   Reply With Quote
Old 11-29-2017, 09:40 AM   #3967
apex128
Thanks for the reply. It is an s14 Zenki. It just has coilovers right now, but I will probably end up needing rear upper control arms. For tires I was thinking about 235/40/18. Do you think I will have any clearance issues with tires rubbing the front wheel well?
Old 11-29-2017, 11:02 AM   #3968
simmode1
simmode1's Avatar
^^^That's the same tire size I ran on my Zenki with Z33 Anniversary wheels. But I was only on drop springs.
You might encounter some rubbing if your fenders aren't rolled. You can also minimize rubbing by dialing in a little negative camber.
Old 11-29-2017, 12:35 PM   #3969
apex128
I am definitely rolling the fenders (fronts are already done), and I don't have a problem with 2-3 degrees of camber in front.
Old 12-07-2017, 08:00 PM   #3970
alwaysnboost
alwaysnboost's Avatar
alwaysnboost is an unknown quantity at this point
Question:
Looking to purchase a set of 18x9.5 et22's.
will these sit flush on the car without having to run neg camber? I believe so but don't want to purchase them if they will poke past the factory body.
Thank guys
alwaysnboost is offline   Reply With Quote
Old 12-07-2017, 08:01 PM   #3971
alwaysnboost
Question:
Thank guys
Old 12-08-2017, 09:07 AM   #3972
apex128
Originally Posted by alwaysnboost View Post
Question:
Thank guys
On an s13 it might be hard to fit those with stock fenders. On an s14 they should fit good with a roll.
Old 12-08-2017, 09:14 AM   #3973
alwaysnboost
Thank you sir !!
Old 12-10-2017, 07:37 PM   #3974
apex128
Thank you sir !!
I also want to mention that you might need a small spacer to clear the coilovers in front depending on what you have. 22 offset should fit with no spacer, but there is still a small chance that you might need one.
Old 12-10-2017, 07:38 PM   #3975
alwaysnboost
Excellent!!! Thanks again!!
Old 12-11-2017, 01:10 AM   #3976
slider2828
slider2828's Avatar
Hey Guys,
Just got some new rims for the track s13 for grip driving. 18x10.5 all around. Rears are fine
Right now I got some RSRR 275 35 18, but the front is hitting the inner well (already hammered the lip).... I know my caster is around 7.5 to 8 (forget stock).... 2.75 camber up front and 0 toe.
Should I decrease the caster? Trying to keep it around stock...
Should I hammer more? OR
Should I go with a 255 35 or 245 35 to gain more clearance? I am trying to run as much tire as possible without compromising too much...
Much appreciate it!
Turn and Burn!
Old 12-11-2017, 09:56 AM   #3977
evildead138
evildead138 is an unknown quantity at this point
Would a 15x7.5 -5 fit nice and flush in the rear on a s13 coupe at -3 camber? Would fender pull be required?
evildead138 is offline   Reply With Quote
Old 12-11-2017, 09:41 PM   #3978
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute
Feedback Score: 24 reviews
Won't need a pull or be flush with -3
My car with stock arms on it when it was still on 15's cleared a 15x8.5-6 with just rolled fenders and was around -2.5-3 camber with a 205/50 and 195/55 tire
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 12-19-2017, 08:22 AM   #3979
dreaMervaj
Trader Rating: (18)
dreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-knowndreaMervaj is making his/her stupidity well-known
Feedback Score: 18 reviews
Has anyone ran 18x10, 18x9 +45 on a S14? I tested fitted the 18x10 +45 in the rear and I may need a spacer to clear the coils. I wanted to run maximum tire size hence the high offset.
https://drive.google.com/file/d/1V3Q...w?usp=drivesdk
dreaMervaj is offline   Reply With Quote
Old 12-19-2017, 12:11 PM   #3980
dreaMervaj
Trader Rating: (18)
Double post.
Old 12-19-2017, 03:57 PM   #3981
humancola
humancola is an unknown quantity at this point
Stock body S13 on coils.
17x9.5 -18 RPF1's all around.
235/40R17 fit without drama?
General searching seems that it should work, may need some rolled fenders?
humancola is offline   Reply With Quote
Old 12-20-2017, 10:45 AM   #3982
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Depending on tire size it wan work with 15mm spacer in the rear and 25 up front. Bigger spacers will be required if you run a smaller tire size and you're going for cooler fitment.
In my experience with an s13 recently 18 9j +45 up front; in order to make it fit and look how I wanted it to I utilized a pair of 50mm spacers I had laying around and wrapped the tires in a 205/35. Opted for a bigger spacer rather than extending my FLCA this time around.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 12-20-2017, 04:39 PM   #3983
dreaMervaj
Trader Rating: (18)
At what point will I need extended studs? I prefer to run spacers and not resize the wheels as these will be going on my Supra/MK4 sooner or later too..
Honestly don't want to run stretch tires if I dont have to.. thanks for replying! I didn't think anyone would... it seems the forums has been quiet these days.
Old 12-27-2017, 09:09 PM   #3984
da_crew10
da_crew10's Avatar
You do not need extended studs if you buy bolt on spacers. Once you decide what tire size you want to run which will be dependent on what ride height you plan to go with that will help narrow down the size of the spacers you will need to utilize.
Old 01-11-2018, 10:03 PM   #3985
cole d
cole d is an unknown quantity at this point
What body mods are required to make a set of SSR professor SP1 17x9.5 +6F/18x10.5 -3R fit a s13 convertible ?
cole d is offline   Reply With Quote
Old 02-04-2018, 04:14 AM   #3986
AnnaKendrick
AnnaKendrick's Avatar
AnnaKendrick is an unknown quantity at this point
Anyone running a setup close to 17x9.5 +18 with ZERO camber in the rear on an S13?
AnnaKendrick is offline   Reply With Quote
Old 02-06-2018, 08:02 AM   #3987
eagleeyes221
eagleeyes221 is an unknown quantity at this point
hi, I am currently running 20mm origin over fenders in the front and 30mm origin over fenders in the rear. With my setup will i be able to run a set of RPF01's in 18x9.5 +15 without the use of any spacers?
suspension is KYB AGX struts with eibach sportline springs. i am also running Z32 brakes front and rear with the possibility of upgrading the fronts to CTSV brakes in the future.
any help would be appreciated, thanks
eagleeyes221 is offline   Reply With Quote
Old 02-06-2018, 08:41 AM   #3988
simmode1
simmode1's Avatar
18x9.5 +15 would fit under stock fenders depending on the tire size you used. What are your tire sizes?
Old 02-06-2018, 10:31 AM   #3989
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
There are so many unanswered questions about this post... I don't even know where to start.
Old 02-06-2018, 11:25 AM   #3990
eagleeyes221
Im sorry, your right i forgot to add in that i have a S13 using S13 subframes with stock length lower control arms. Im not very good when it comes to suspension and the like. what other information would you need to know aside from tire sizes? as far as that goes Im not quite sure what my options are yet. All i have right now is a idea that i wasnt sure if it would work with my setup.
thanks
