#4141 |
You can have heat, I had excessive mounts with heat and stock twins, I'm out right now but will see if I have some pics when I get home
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#4143 |
Hey everyone, I need some wiring advice. I apologize in advance, since these feel like dumb questions, but searches didn't really find what I needed:
96' S14, Aristo VVTi 2J, Aristo Auto Harness/ECU, R154 1. How do you all have your starter hooked up? I definitely did it wrong, since I'm blowing starter fuses like bubble wrap. 2. I also missed a step in getting my factory fuel pump working during ignition, since it'snot coming on at all. 3. On the F60 ECU pin, there's a relay for the M-REL and +B2 pins. I know one's the trigger and one gets battery voltage, what kind of fuse do I need for this relay (If I do need one)? Any input on this would be greatly appreciated.
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
#4144 |
![]() Join Date: Oct 2010
I can help, I have figured out the vvti wiring with lots of help. For the starter, splice from the ka lower harness starter solenoid wire, which is heavier gauge near the passenger side engine bay fuse box. Mine was black / yellow wire. Run that to the 2jz starter solenoid. You can also split off the other start signal wires needed for the 2jz harness from this same wire. I can help more late. Out of town.
#4145 |
![]() Join Date: Sep 2010
![]() Feedback Score: 11 reviews
Your starter doesn't need a fuse. Just run proper gauge wiring from the battery to the starter. For your fuel pump, make sure your fuel pump relay wire is a switched ground
Follow me on Ig- Andydennington |
#4146 |
I have a wire to the battery. I'm referring to the signal cable that tells the starter to engage when the key goes into the crank position.
#4149 |
R154 shifter extension ?
Ok guys so I read about 5 pages just need more time this thing is great, my question is do I really need a shifter extension for the r154 into s13? Any pics of it without it ? Thanks guys
#4154 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
That's Brian - legit guy he's local to me and he brings in the CLEANEST things you'll ever see.
#4155 |
#4159 | |
![]() Join Date: Jun 2012
Im looking to get a Drive shaft made for my car with a W58 Trans.
I searched through this thread and found this: Quote:
Dont want to go through fixing it if its too long/short. Thanks in advance for anyone that can shed a little bit more light on this topic! |
#4161 | |
I've measured once and got close to those same measurements. Unable to get down to the specific measurement and found that while searching. Trying to find if anyone else has a driveshaft they could measure or has had one made with the same measurements with the exact application as mine. Thanks for your input though, but it didn't help much. |
#4162 |
I'm sure you'll be fine if you followed what I said earlier. If you are confused, just call up thedriveshaftshop (800) 564-2244 and ask how to measure. They know what they are doing. If you aren't buying from them, then callup whatever shop you are using and follow their measurement instructions. If you can't get that puppy within 9/16" ish you really need to google how to measure!
#4163 | |
#4164 | |
I've contacted both David from Shaftmasters, And Robert from ZeroLift. I was hoping one of them would have the measurements on hand. Both have the access to parts and capabilities to make the shaft, but both representatives asked for the measurements. Hence why I'm asking to make sure that is the measurement everyone is getting, or if someone had the shaft made with that measurement. Thanks for all the replies but still looking for an answer. |
#4166 | |
![]() Join Date: Jul 2007
Trader Rating: (18)
![]() Feedback Score: 18 reviews
These are all done by them. ![]()
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
#4168 |
![]() Join Date: Aug 2012
![]() Feedback Score: 6 reviews
i just swapped my r154 bellhousing from a 7m to a 1jz. does anyone know the torque setting for those bolts?
follow my build on instagram: s14project |
#4169 | |
Geez I am so sorry man, I have been swamped lately. This is the first time I have ever attached photos from the mobile app so let me know of you can see them. Basically what I did is bought new hoses from Oreillys (get those part numbers in a min) and cut them to fit. The outlets of the heater core I also took off from inside the car and shortened them with a dremel until they were even with the firewall. Then I crawled my ass under the dash while my buddy used some curved 12" needle nose pliers and fed them thru and I put worm clams on from the inside. Hope that makes sense. Here are some pics ImageUploadedByTapatalk1406168382.290378.jpg ImageUploadedByTapatalk1406168424.364926.jpgImageUploadedByTapatalk1406168560.264010.jpg
#4170 |
2JZGTE Swapped S-Chassis thread
The first and second are kinda from above the third from below. The hose looking thing in the third pic from below is just the o2 sensor wire
