03-13-2009, 12:06 AM | #391 | |
Sounds like a SWEET deal for $450. More updates plz!
03-13-2009, 10:16 AM | #393 |
Well I am having a whole 3.5 inch 1 piece aluminum shaft made, the other good thing about using the 350z rear end is it uses a bigger, beefier yolk than the 240sx so it will be less liable to break under alot of power.
Now metal fabricating, welding and powder coating. PM me with your needs! |
04-02-2009, 07:44 PM | #396 |
Intake manifold carnage!
Ok as you all know I decided to use a VQ30DET intake manifold on my VQ35DE(T). Well after weeks of roaming around the Maxima forum I found a guy willing to sell me one so I snagged it up. As you all know the plan is to cut the back side of the intake manifold off and re-angle it to come in through the passenger side rather than the drivers side, well I took it a little further than that, I got carried away with the cut off wheel.... Here is how she looked when she arrived: Bye Bye cable driven, dual inlet throttle body: Twin inlets...Dont need those anymore... Carefully marked for surgery: Picked up the cut off wheel and went to work, 30 mins later plus some grinding I came up with this: AICV Delete: Now for reconstructive surgery, picked up some Aluminum-num-num and went to work, came up with this: "Hey Mike can you weld this for me?" (It's not like I had to twist his arm aluminum is his favorite to weld, but he doesnt like welding cast aluminum to aluminum, welds dont come out as pretty) Here is the result of the button up, notice around the perimeter the welds arent as clean, or "stacked up like nickles" as Mike would say, because of the cast aluminum. Its dirty and difficult to clean. Evidently I didnt grind and clean the metal enough, because alumium is so soft even when you grind the metal clean its not completely clean. If that makes sense. The weld bead joining the two pieces of new, clean aluminum is perfect compared to the rest but its all good you wont see any of this when I am finished: Out comes the handy grinder and back to work I went, and I am pleased to show the results: Now I have to work on buttoning up the back side, I need to cut the aluminum and piece it all back together and Mike is going to get more gas for the tig since its running on empty. That is all for now.
04-02-2009, 09:24 PM | #398 |
Na, that would require spending money to have flanges custom made, I dont want to do all that. What I am doing is easy.
04-08-2009, 02:44 AM | #403 |
by AICV...do you mean IACV - Idle air control valve?
How does one go about deleting it (other than hacking it off like you did )....and will it affect the ECU at all? IIRC it's a passive system that just keeps the idle smooth by a solenoid that meters air into the plenum...correct?? What is there to be gained by ditching it other than a cleaner engine bay and sexy intake mani? |
04-08-2009, 02:59 AM | #404 | |
That being said, I don't see a "real" benefit there, unless yours is dirty and doesn't 'catch' the engine when it's comin down from high revs and your shit dies all the time...
04-08-2009, 06:01 AM | #405 |
cool thanks. by passive i meant it doesn't read a signal from it and adjust timing/fuel/etc accordingly....but that is probably the wrong word to use.
open loop?? doin physics homework all night is melting my brain away |
04-08-2009, 02:13 PM | #407 |
if he is using the stock ecu with DBW the Idle air is controlled by the ecu and the throttle body. On the VQ30DE with analog throttle there is an IACV.
Drives a BRZ and is building a V6 S12 coupe. |
04-08-2009, 10:45 PM | #409 | |
^^^you can shim it works great. ull do it up right dont listen to that kid which ever direction you decide to go
04-09-2009, 01:08 AM | #410 |
(ノಠ益ಠ)ノ彡
this thread rocks me... you can shim that vlsd and turn it into a 1.5 or 2 way...
might as well do it now that its out... EDIT:: im stupid and cant read the post right before mine. |
04-09-2009, 08:22 PM | #411 |
I have not done much to the car, been waiting on parts to come in for it. I have also been working on the SR16VE head with a GTI-R SR20DET bottom end motor build for my NX2000. Ultimately giving me one strong ass SR20VE-T. Waiting on my head bolts and headgasket for that. Then I just need a new oil pump, fuel rail, intake mani gasket set, AICV valve and MSD RPM switch and the NX will be alive!
I found out something interesting today which further makes me love Nissan, 350z/G35 brake booster and master cylinder go right into place on the firewall only two small issues I ran into. 1. The 350z/G35 brake booster is a whole lot thinner than the stock 240sx brake booster. No the MC wont bont up to the stock 240sx brake booster, designs are different. Being that it is thinner it is alot wider in diameter. This makes for a slight clearance issue with the stock 240sx clutch master cylinder. I found that where the brake booster was hitting the clutch master cylinder was so slight that all that is needed is to take a hammer and dent in the outer lip of the 350z/G35 brake booster and no more clearance issues. So I did and it worked out. Then I ran into problem 2. The studs on the stock 240sx brake booster are longer than that of the 350z/G35. No worries tho, I plan to shorten down the studs, install some rod couplings and then some longer studs to make up for it. Now I will have proper brake proportion for the ABS module and the calipers and it moves the MC closer to the firewall and not so close to the downpipe. Went home and found some goodies sitting on my porch. Energy suspension sub frame bushing set, (Since my stock rubber bushings decided to disintegrate when I removed the sub frame) had to wait 2 weeks for these bad boys since they were on back order, Differential mounts (Too bad I can only use one mount out of this whole set) and steering rack bushings. I originally wanted to buy all Nismo mounts till I saw their pricing. I cant see there being much of a difference in their polyurethane bushings and these and for the price you cant beat it. I got all of this for less than half of what I would have paid for just one set of Nismo sub frame mounts. So now I can finally get an accurate measurement on my driveshaft length and get it over to my driveshaft maker and finally have my 1 piece aluminum driveshaft made.
Now metal fabricating, welding and powder coating. PM me with your needs! Last edited by SinisterSntra91; 04-09-2009 at 08:53 PM.. |
04-10-2009, 12:12 AM | #412 |
im digging this project, just joined the forum and sat for an hour to read this whole thing.
i plan on doing this swap as well but havent decided if i wanna go standalone or use the stock ecu. Does anybody know if the vqswap.com version of the aem ems works with all the advanced cam timing or not? because on their site they mention the have it tuned for that but im not sure and dont want to ask them because last time i asked them a very simple question the guy was an A hole to me for no reason. I was wondering about the stock wiring, is there any way you could get the stock ecu tuned to eliminate all the bcm and nats stuff? so for the long post |
04-10-2009, 12:28 AM | #413 |
oh ya i also forgot to mention you said you would get the correct gearing when you added the g35 vlsd, all the z guys are swapping in 3.9 gears into their car, and a 240sx gear ratio is close 4 or something like that so you would have been quicker with the stock 240sx gear ratio. But i do see that you also swapped that so you can use the stock gauges with that speedo sensor mumbo jumbo
04-28-2009, 09:15 AM | #414 |
This is a very intense and awesome build. Most people would have quit a long time ago. Glad to see your goin the extra mile to perfect everything about this build. If you ever need anything Nissan related PM me. I work in the parts dept of a Nissan dealership. I would be more than happy to help you out any way that I can.
04-30-2009, 06:17 AM | #416 |
This is one heck of a project! Got me wishing I had half your fabrication skills! Got a question on the 350z/g35 brake booster setup, did all the stock lines screw right into the BMC or did you have to tee off the fronts or anything? I'm really interested as I am thinking of doing this mod when I swap on some larger brakes next month. Thanks and keep up the excellent work!
04-30-2009, 07:38 PM | #417 | |
05-02-2009, 04:40 PM | #418 |
any new mods to the body????
05-08-2009, 08:32 PM | #419 |
Well here are some pics I have for an acute update:
All of the turbo piping for the most part is complete, I finished the intake mani but it has to be ground smooth again. Then I will powder coat it wrinkle black. Looks like im smuggling an octopus under my hood with all the damn piping... And here is a pic I took today, Ill let you guys figure out what is next...
05-08-2009, 09:05 PM | #420 |
Maybe 4 Door??
