08-27-2014, 10:40 AM | #4321 | |
I will try to finish my dash repair and throw it back in the car. Install boost, oil pressure, water temp gauges and if time allows ill try to prime the oil cooler. |
08-27-2014, 12:37 PM | #4322 | |
What dash repair are you doing? Cracks?
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
08-27-2014, 12:59 PM | #4324 | |
Nice! What are using to fill the holes? Are you wrapping your dash or flocking it?
08-27-2014, 01:29 PM | #4325 | |
Its a combination of expanding foam to make a base for the bondo, sanding and a couple of layers of fiber glass. once smooth i will be wrapping it. I don't know yet with what though. Ill post some shots of my ghetto rig. lol |
08-27-2014, 01:51 PM | #4326 |
I will be installing extended studs in the front to get rid of the crappy Nissan 1.25 thread pitch, New front rotors and pads since its all apart 're pains and install all rear adjustable arms, roll rear fenders some more and possibly installing the buit auto trans and 3600 stall in the car, lot to do may need to take next week off lol
08-27-2014, 07:46 PM | #4327 | |
What built auto did you go with? Who built your converter?
08-27-2014, 08:24 PM | #4328 |
I bought it used converter is 're stalled and tranny has billett sprag and cages everything else is heat treated and hardened and upgraded clutches, "rated at 800whp" but we will see it was cheap so I picked it up, later on down the line I'll put a atf in it
08-28-2014, 07:45 AM | #4329 | |
My Labor plans are to figure out how in the heck to wire up Reverse light on my 2J swap so I can pass inspection.
BlackHand |
08-28-2014, 09:48 AM | #4330 |
Junkyard trip to find replacement power steering pump and an FPR. There's usually a bunch of GE's around here. I should also get around to hooking up my R154's reverse light indicator...
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
08-28-2014, 10:19 AM | #4331 | ||
I also need to hook up my reverse lights! Maybe I can look at that also...
08-28-2014, 08:04 PM | #4333 | |
I just want mine to work... No inspections or emissions in Oklahoma [emoji6]
08-28-2014, 10:40 PM | #4334 | |
The next task will be to find someone wh can tune a mapecu 3, I've been hearing mixed opinions from tuning shops in VA And MD about the, so AEM V1 might be my next move. I'll try to chime in on here about the mapecu to contribute my thoughts.
BlackHand |
08-28-2014, 11:50 PM | #4335 |
Map ecu is a solid piggy back, but going to a v1 will give you way more options but can be finicky at times, for the money a v2 is the best bet. Of you don't have the $ for a v2 and are good with wiring you can buy a v2 for a Honda and a plug and pin kit and wire it all in and save yourself about $600 over the supra box.
If you have and map ecu questions you best bet is to call Brian at powerhouse racing, they are the #1 us distributor and he knows it like the back of his hand |
08-29-2014, 07:38 AM | #4337 |
Tell me about it, I've had mine on a stand rebuilt for 4+ years. I'm just now getting ready to paint the engine bay of my S14 and hopefully have it in by end of 2014. Adult life problems.
08-29-2014, 09:08 AM | #4338 |
That's why I try to tell anyone contemplating any swap to just get it in stock and then go from there so you can enjoy driving the car.
08-29-2014, 09:10 AM | #4339 |
ImageUploadedByTapatalk1409325004.167699.jpg Where mine has been sitting for a year or so.
08-29-2014, 09:16 AM | #4340 |
For me I'm waiting on my motor mounts come in from Freed Engineering, which should be today, paint the engine bay and finally put the motor in after it being on the stand for over a year
08-29-2014, 09:34 AM | #4341 | |
Nice what turbo?
08-29-2014, 10:14 AM | #4342 |
I started my 1j swap around february, this does take forever haha.
Motor is in the car, but it seems like every little thing i have to do fights me. I should make a build thread. |
08-29-2014, 11:22 AM | #4344 | |
Trader Rating: (18)
Feedback Score: 18 reviews
I just finished wrapping my manifold and downpipe with the titanium dei heatwrap. Holy fckin shit I hope I never have to wrap another manifold for the rest of my life. My speedhut gauges came in as well as the spool for my differential so I'll be busy this weekend.
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
08-29-2014, 12:06 PM | #4345 |
I actually ended up doing this last night after work. It wasn't too hard at all to set up. I also finished wiring the relay for my A/C. Still need custom lines made though...
08-29-2014, 12:22 PM | #4346 | |
Yeah I've been lazy had today off and haven't even touched the car. I did get my AC working a few weeks ago, had a local shop make me custom hi and low lines for $78! I paid and got out as fast as I could! Charged it up and been nice and cool since.
08-29-2014, 12:29 PM | #4347 |
Did you keep the stock s13 evaporator (the bullet shaped thing near the fuse box).
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
08-29-2014, 01:13 PM | #4348 | |
I have an s14 do you mean the drier? Either way I am running all stock components other than the compressor and my two custom lines in and out of the compressor Here's a couple pics of my custom lines ImageUploadedByTapatalk1409339544.495204.jpg ImageUploadedByTapatalk1409339562.061209.jpg
08-29-2014, 06:01 PM | #4350 |
Yea the drier is what I ment *face palm*. How did you route the line coming from the firewall to the compressor? Normally its behind the head on the ka buuuut with the 2j its darn impossible unless you routed it above the head or along the passenger frame rail and then between the sway bar radiator.
