Old 08-29-2014, 07:03 PM   #4351
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
Originally Posted by Sky80 View Post
Ok, so let's see where everyone is at:
Post up your plans for your 2jz/1jz car over the Labor Day holiday this weekend.
For me it's gonna be checking contacts/replacing the starter since it likes to not work when I drive the car on really hot days.
I have a starter with new contacts and it does the same thing! When that happens I have to hold the key and bump the clutch while the car is rolling down a slight hill and it will work.
Mr. Phonso is offline   Reply With Quote
Old 08-30-2014, 11:17 AM   #4352
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
So that sounds like it's almost in a bind. Which is something else I thought could be happening. Only problem is I don't know how to fix that problem
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 08-30-2014, 11:45 AM   #4353
ThanatosG
ThanatosG is an unknown quantity at this point
It's likely the contacts on the cables and connections power & ground. Buy a terminal wire brush, and a copper brush. Hit all contact points.
My friends evo had a similar problem. He left his car apart for a month and it wouldn't start. Took me 5 minutes to fix it.
due to the poor power and ground the starter wasn't getting enough power to turn over. It seemed to be weak or as if the battery was dead, but it was fully charged. The starter was also bench tested good.
ThanatosG is offline   Reply With Quote
Old 08-30-2014, 01:15 PM   #4354
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
I had a problem with mine where i had to rock it when I had a drift motion flywheel. Now the problem is just the starter solenoid being finicky and it does nothing from time to time. Going to take my started off and take it apart on Monday even though its new/remanufactured.
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 08-30-2014, 07:16 PM   #4355
bkg775
bkg775's Avatar
bkg775 is a well-known jackass
Originally Posted by turbo-2ns View Post
Map ecu is a solid piggy back, but going to a v1 will give you way more options but can be finicky at times, for the money a v2 is the best bet. Of you don't have the $ for a v2 and are good with wiring you can buy a v2 for a Honda and a plug and pin kit and wire it all in and save yourself about $600 over the supra box.
If you have and map ecu questions you best bet is to call Brian at powerhouse racing, they are the #1 us distributor and he knows it like the back of his hand
Thanks for the input, I bought the mapecu 3 and then two of the shops I thought could tune for it stopped so guess I've gotta learn it until I can go aem v1 or v2.
BlackHand
bkg775 is offline   Reply With Quote
Old 08-30-2014, 09:02 PM   #4356
jubee
jubee is an unknown quantity at this point
so question for you guys who have done the na-t route what intake mani would you all recommend going with?
jubee is offline   Reply With Quote
Old 08-31-2014, 07:29 AM   #4357
Mr. Phonso
It also only does it on hot days as well lol
Old 08-31-2014, 03:53 PM   #4358
Sky80
Sky80's Avatar
Originally Posted by ATLspeed View Post
Yea the drier is what I ment *face palm*. How did you route the line coming from the firewall to the compressor? Normally its behind the head on the ka buuuut with the 2j its darn impossible unless you routed it above the head or along the passenger frame rail and then between the sway bar radiator.
Mine is routed just like stock, there is maybe 1mm of clearance back there but it worked!
Old 08-31-2014, 04:03 PM   #4359
supercompact
supercompact is an unknown quantity at this point
Installed these on the sway bar for clearance.
Put the brake and clutch pedal along with the master cylinder and braided line in.
Installed the BC 264 cams and BC cam gears. All clearances checked. Making progress!
supercompact is offline   Reply With Quote
Old 08-31-2014, 05:38 PM   #4360
kalel540
kalel540's Avatar
kalel540 is an unknown quantity at this point
Got to work on the car early this morning. Finished a couple of things here and there also got the radiator/ clutch fan mod done, oil cooler primed and the dash in. looks alright.
Now I can relax tomorrow lol.
Till next pay check.
kalel540 is offline   Reply With Quote
Old 08-31-2014, 05:39 PM   #4361
ThanatosG
What did you cover the Dash with?.. I'm looking to do something similar.
Old 08-31-2014, 05:40 PM   #4362
kalel540
kalel540's Avatar
[QUOTE=supercompact;5713091]Attachment 75331
Do you use the nismo brace? I would go this route if it clears the brace. other wise sikky would be the next choice.
Old 08-31-2014, 05:42 PM   #4363
kalel540
kalel540's Avatar
LOL I used fleece. I tried fake leather and that shit was a PITA.
Fleece was more stretchy and glued better.
Old 08-31-2014, 05:43 PM   #4364
supercompact
It's dealer installed stick on wood grain.
Old 08-31-2014, 05:45 PM   #4365
supercompact
[QUOTE=kalel540;5713139]
Originally Posted by supercompact View Post
Attachment 75331
Just factory sway bar. I don't have a brace at all.
Old 08-31-2014, 06:09 PM   #4366
bkg775
bkg775's Avatar
I've got a weird problem that I'm hoping you all might be able to help me with. I've got a single turbo 2jz 4" straight pipe exhaust running NGK bkr8e plugs i believe. No factory IACV or IAT sensor due to atermarket intake manifold.
For some odd reason my car smokes grayish and I smell gas out the exhaust like its rich but my afr reads 15.8 to 17 at idle.
I've got the iat sensor for my mapecu 3 plugged in and I plan to install the piggyback soon but I'm stumper.
BlackHand
Old 08-31-2014, 06:15 PM   #4367
supercompact
Oops, I thought you meant my fancy wood grain. Lol
Old 09-01-2014, 05:29 AM   #4368
stevecorrado88
stevecorrado88 is an unknown quantity at this point
1jzgte there's a brown 2 connector sensor under the center if the intake mani that has 2 vacuum line going into it, what is that for and does it need to be there ? Got a wire harness made but had no connector for it.
stevecorrado88 is offline   Reply With Quote
Old 09-01-2014, 11:14 AM   #4369
Sky80
Sky80's Avatar
Why don't you finish installing everything then look into getting it tuned. Then see where you stand?
Old 09-01-2014, 11:39 AM   #4370
bkg775
bkg775's Avatar
Yea that's what I did and it solved my problem, I kinda posted a little preemptively.
BlackHand
Old 09-01-2014, 07:50 PM   #4371
Club 1JZ
Club 1JZ is an unknown quantity at this point
Is Megan racing catback type 2 midpipe for s14 fit to cx racing 3" down pipe in s13?
because I need midpipe to connect to cx racing down pipe from 1jz vvti s13
Club 1JZ is offline   Reply With Quote
Old 09-01-2014, 08:04 PM   #4372
matts13dood
matts13dood's Avatar
matts13dood is an unknown quantity at this point
Originally Posted by DallasTXjdm View Post
Thanks for the tip bro. Keep us updated on the new times! Have you beefed up your rear?
Good job man! From far away it looks like an aftermarket IM.
Beautiful engine bay! Which radiator did you go with? I like the way the radiator hose is setup compared to the "S" setup. Also which turbo are you dropping in her?
Just curious, what outstanding issues was he experiencing with the CB harness?
I am in the same boat as you SinCityS14. Looks like there's a USDM water pump already on my engine too. I am not going to take any chances. I haved ordered a new one for just piece of mind.
As far as my 2JZ project.... I am still piecing it together. Right now I am focus on trying to locate a driveshaft. Can you guys recommend a reputiable shop? I have a Getrag 6sp mated with a Q45 rear.
Hey guys I believed the usdm Water pumps delete the hydro fan setups
matts13dood is offline   Reply With Quote
Old 09-01-2014, 08:33 PM   #4373
matts13dood
Use Nissan temp sensor
Old 09-01-2014, 10:03 PM   #4374
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
Those are some pretty cold plugs man. What fuel/power are you running?
'92 HB HX35 rb25 - sold
'89 Coupe GTX35 VVT-I 2JZ - yeah buddy
AS240 is offline   Reply With Quote
Old 09-01-2014, 10:05 PM   #4375
turbo-2ns
turbo-2ns is an unknown quantity at this point
8s are fine
turbo-2ns is offline   Reply With Quote
Old 09-02-2014, 03:08 PM   #4376
SinCityS14
SinCityS14's Avatar
SinCityS14 is an unknown quantity at this point
Is anyone running a stock 2jvvti on stock twins and ecu? What did you guys do about the drive by wire throttle? Do i have to change it out completely to a mechanical?? Gonna be starting my swap soon any info would help thanks!
G37s - Dropped on DPE 20's - $old
S14 - Bone stock
SinCityS14 is offline   Reply With Quote
Old 09-02-2014, 07:39 PM   #4377
Sky80
Sky80's Avatar
I am running a 2j VVTi and on stock ECU, yes stock throttle body and all. Works just fine, no need to change it.
Old 09-02-2014, 09:24 PM   #4378
ehp
ehp is an unknown quantity at this point
you only have to swap it out if you wanna use a standalone that does not support drive by wire
follow my build on instagram: s14project
ehp is offline   Reply With Quote
Old 09-02-2014, 10:27 PM   #4379
SinCityS14
SinCityS14's Avatar
Sky80 what did you do for wiring? You did it yourself?
S14 - Bone stock
Old 09-03-2014, 12:47 AM   #4380
AS240
AS240's Avatar
Trader Rating: (18)
8s are fine
The colder the plug, the sooner they tend to foul out, which could contribute to the past problem or be an issue later down the road.
I've only ever seen people go to that cold of a plug in a 2J when they get into the 700+hp range which is why I was curious about the fuel he's running and what kind of power he's making. Just something to think about if the misfire issues resurface.
