Old 12-06-2011, 03:08 PM   #451
90240sx07
90240sx07 is an unknown quantity at this point
^^^ what do you mean by s13s are limited by how low you can go?
is this due to the ridge up top on the wheel well?
90240sx07 is offline   Reply With Quote
Old 12-06-2011, 03:11 PM   #452
Kwolfe
Kwolfe is an unknown quantity at this point
Thank you 95ka
Kwolfe is offline   Reply With Quote
Old 12-06-2011, 04:22 PM   #453
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
S13s can fit less wheel/tire up front then S14s in both height, width, and offset, they are just smaller cars.
If you look through the 180sx Thread most of the guys in there are running 215/40s rather then 45s because of the rubbing issues with the taller tire.
I typically would pick a 215/45/17 for up font for 9" wheel, but I have a S14 and apparently there is a pretty big difference.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 12-06-2011, 05:11 PM   #454
Rsidesilvia
Rsidesilvia is an unknown quantity at this point
can i fit 18x10+5 square setup on my stock body s13 vert?
Rsidesilvia is offline   Reply With Quote
Old 12-06-2011, 09:59 PM   #455
95KA-Turbo
95KA-Turbo's Avatar
If you want to run loads of camber, super stretched tires, and a decent pull all around then yes.
Flush fitment with reasonable tire stretch on stock rolled fenders is 17X9 +12 all around with 215/40 and 215/45s. That still requires like -2.5->-3 camber out back.
Instagram - SJKnoop
Old 12-07-2011, 12:20 AM   #456
EhrikETFG
EhrikETFG's Avatar
EhrikETFG is an unknown quantity at this point
beat the shit out of that ridge man
EhrikETFG is offline   Reply With Quote
Old 12-07-2011, 12:58 AM   #457
90240sx07
well im cutting that ridge out and my friend is gonna weld the seam
Old 12-08-2011, 11:34 PM   #458
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
Hey, is anyone running 9.5" wide -3 mm. (or neg. offset that similar to it) up front on an S13 stock fenders? I'm eying on a set of 18x9.5 -3 all around with mid disk. Just wanna make sure the front will clear my coils. I know I need aggressive camber and to pull the front fenders and rear quarters but by how much??
Any fine example or pointing to the right direction is greatly appreciated. My car is stock body and I wanna keep it that way.
Old 12-10-2011, 07:38 AM   #459
cbcm2435
cbcm2435's Avatar
cbcm2435 is an unknown quantity at this point
what size overfender would i need to fit an 18x12 -14 in the rear of an s13?
cbcm2435 is offline   Reply With Quote
Old 12-13-2011, 11:04 AM   #460
il duce
il duce is an unknown quantity at this point
Newb here, but i am wanting to run 17x9 all around with a 245/40/17 tire. Would this setup work with a +25 offset? Will be dropped on a shock spring combo oh koni/h&r
il duce is offline   Reply With Quote
Old 12-13-2011, 12:50 PM   #461
90240sx07
17x9 +12 with a pull and roll would work
Old 12-13-2011, 12:57 PM   #462
95KA-Turbo
95KA-Turbo's Avatar
Big, probably a bowed out 50mm.
That will be fine for a shock/spring set up. You'll be rolling your fenders all around, but other then that your clearance should be fine.
Instagram - SJKnoop
Old 12-13-2011, 01:06 PM   #463
il duce
Thanks. I don't care about crazy low so i was hoping that would work.
Old 12-14-2011, 10:14 PM   #464
zo0d
zo0d's Avatar
zo0d is on a distinguished road
Do you need to pull your rear quarters to fit 18x9.5 +10 w/ 245/40/18 on a S14?
zo0d is offline   Reply With Quote
Old 12-14-2011, 10:42 PM   #465
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
^Depending how little camber you run. But to answer your question, yes.
For Sale #1 | For Sale #2
Old 12-15-2011, 08:18 PM   #466
cmilla
cmilla is an unknown quantity at this point
i got a s14 with the fenders rolled not pulled looking at work vs-mx in 17x8.5 offset +12 fit bbk and 17x9.5 offset +13 will these fit or no any help is appericated
cmilla is offline   Reply With Quote
Old 12-19-2011, 12:34 PM   #467
Spazegun2213
Spazegun2213 is an unknown quantity at this point
Here is probably an easy question for you. I'm on GC coils (iirc) and would like to put either 17 or 18 x 9.5 on the car all the way around. Would a +15 be safe, running 245's? would about a +30?
-2* front
-1* rear
Fenders are rolled, but not stretched.
This car is not going to be slammed at all, but I'd rather it not look like a 4x4.
Spazegun2213 is offline   Reply With Quote
Old 12-19-2011, 01:09 PM   #468
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
^I have 17x9 + 12 on maxed coils and my camber on the fronts is maxed so it doesn't poke I'd imagine if youre not low 17x9.5 + 15 would have considerable poke and look silly, there's a kid on here that has the same exact set uP on his black 240 search I think his build threa is "from rust to riches"
shalezzz is offline   Reply With Quote
Old 12-19-2011, 03:19 PM   #469
95KA-Turbo
95KA-Turbo's Avatar
Those will fit no problem, you'll probably want a 10 or 15mm spacer up front with 215/45s and 235/40s out back.
Instagram - SJKnoop
Old 12-19-2011, 09:12 PM   #470
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
I read the whole thread and got some good info. Great job guys. I need some help on my possible tire specs. Setup: S13 stock body, stance gr+pros, 17x9.5 (12) and 18x10.5 (15)
I'm thinking of running (F)225/40 and (R)235/40. Most likely 215/40 Feds up front because I guess 225/40 isn't too common. I will be rolling/pulling and camber of course. I want least stretch possible so what tire sizes would be decent? Any advice?
s13drob is offline   Reply With Quote
Old 12-19-2011, 09:19 PM   #471
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Go 215/45-17s, more common sizing and will be about the same overall diameter as 235/40-17s.
CLICK HERE!!!
Old 12-19-2011, 09:24 PM   #472
matt_240sx
matt_240sx is an unknown quantity at this point
Question. Recently got 17x8.5 wheels with a +4 offset on 225/45/17 tires for my S13. Will they fit with a minor fender roll and a little camber adjustment? I'm a newb to wheel fitment.
matt_240sx is offline   Reply With Quote
Old 12-19-2011, 10:07 PM   #473
shalezzz
shalezzz's Avatar
^Just do a full roll, borrow a roller make it flat, and I have 215/45 and I wish I went with a 40 up front cause I rub at lock... Depending how low you are
Old 12-20-2011, 06:30 AM   #474
Spazegun2213
so what about a +30? I worry about that on the rear.
Old 12-20-2011, 07:19 AM   #475
s13drob
s13drob's Avatar
Trader Rating: (29)
Thanks flip. Wouldnt 215/45 up front look pretty stretched? I think i want to get star specs for fronts, 225/40 should be ok right? Im going pretty low to have things sit flush....
How about my rear tires? 235/40 seems ideal from what I seen people running similar sizing. Any ideas? I need some assurance before I buy tires.
Old 12-20-2011, 08:00 AM   #476
95KA-Turbo
95KA-Turbo's Avatar
Well 225/40/17s are very limited in availability. I had a pair of the Nittos that are made in that size. I had them mounted on 17X9s and I also had some 215/45/17 Federals. They were almost the exact same size. The 215/45s were a hair taller and a hair narrower, but they will fit on your 9.5s like the 235s will fit on your 10.5s....they are also almost the same height as 235/40s so it will flow properly.
Instagram - SJKnoop
Old 12-20-2011, 09:08 AM   #477
s13drob
s13drob's Avatar
Trader Rating: (29)
Ok. I understand now. Sounds like I'll give it a shot.
Thanks FLIP and 95KA I appreciate your help.
Old 12-20-2011, 10:46 AM   #478
shalezzz
shalezzz's Avatar
Worry about it rubbin on your coils? If you plan to go real low get + 15, worst case scenario you get + 30 and need a spacer, if I were you just hammer it flat get ruca and lower it till it looks right
Old 12-20-2011, 11:59 AM   #479
Spazegun2213
nah, as I said I would love to run 245's or so all the way around. I'm not going to be slammed, but I want to make sure they will actually fit. I mean +15 should fit in the rear no problems, but I think the front will be an issue. Again, I'm not worried about looks, or any of that.
Old 12-20-2011, 12:09 PM   #480
shalezzz
shalezzz's Avatar
Oh than get +15 def, if you ain't worried about and if you ever wanna change wheels in the future +15 will def be eaiser to sell
