#4831 | |
The two options I'm considering are the panicwire that has been mentioned and Tweakd Performance (kind-of leaning towards them as they are fairly local to me). I have talked to panic wire though and they seem very knowledgeable and are very willing to help dial in your setup. DBW wise, the full drive by wire throttle bodies are labeled "ETCS-i". The other "ETCS" labeled throttle body on 1st gen VVTI's is still a semi-DBW setup, but can be bypassed into a normal throttle body setup much easier once you swap out ECU for an aftermarket setup. The OEM ECU monitors the throttle body and uses it for Traction Control, along with other small adjustments for fuel effeciency. From what I've read, sometimes wide open throttle can be slightly delayed on either TB because of this. One other note with the ETCS-i throttle body is that the throttle body is essentially the idle control, so if you swap it out, you will need to also swap out the intake manifold for older models with their own IACV. This is interchangeable with either first gen 1jz VVTI (ETCS TB models) or very 1st gen 1JZ (TT setup) intake manifold. If you intend to keep your OEM ECU and have a ETCS-i throttle body, this is one semi-pricey option: http://global.rakuten.com/en/store/p...GGZggIpHPYS9wA |
#4832 |
![]() Join Date: Oct 2008
Thats strange wiring specialties posted this up not too long ago
https://www.facebook.com/12990602369...type=1&theater I even ask if they would do a pro 1jz vvti they said 'it coming soon" |
#4833 |
Hey thanks guys for clarifying the DBW and harness options. This thread has cleared up so much for me.
That is odd Wiring Specialties would post that photo, especially considering they told me yesterday through email that they weren't interested. |
#4834 | |
No matter what, unfortunately it does get pricey just to get a regular cable setup. I'm using an AEM V2 and I still plan on trying to swap out the throttle body and intake manifold from a 1st gen 1JZ to get full control as I don't believe the AEM is capable of idle control via TB and I have the newest gen TB. |
#4835 |
![]() Join Date: Jul 2007
Trader Rating: (18)
![]() Feedback Score: 18 reviews
I've only ever had these mounts on my swap but they are great. The engine torques the slightest bit under WOT revving but there doesn't seem to be a lot of vibration transferred. I'm running open down pipe so it loud inside the car no matter what. Freed swears by them so I went ahead on got them (not from him though).
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
#4836 |
Alright, so I just finished installing this bad boys.
![]() ![]() ![]() https://www.youtube.com/watch?v=gL5898cdJ_8 Everything works as intended but, I do not know where to get the tach signal from. Any of you guys know and can guide me in the right direction? BTW, Big thanks to Broadfield for building me this sweet cluster. Need great looking gauges and custom work? Give the man a call. Awesome person/seller. |
#4838 |
![]() Join Date: Nov 2009
hey guys, posting from the uk here.
my 1jz s14 I've built has always had a temp issue when drifting, it's struggling to keep cool with both electric fans switched on (push fans) bonnet and front bumper off are the only way of keeping constant temps under 100 degrease Celsius I've done this lately after seeing the viscous unit done on a few jz swapped sbodies first of all, I got myself a gktech s14, these are excellent fans then I had a milling machine chop drill out the Toyota pcd into the Nissan sr20 gktech fan, they also took a little off the Toyota unit ![]() so I chopped out the front end, my friend paul is a tig welder and came and pretty much made all the front end tube moved the rad forward so that it's against the vehicle front frame lower parts (cross member in the uk) ![]() with moving the rad forward though the rad hose wouldn't reach he made up an extension pipe ![]() basically I'm now waiting to get the car back out and go drifing again, I'm desperate to know how much of a difference it'll actually make FAN SHROUD/COWLING will be on shortly, it's currently sat in my mate's workshop
http://zilvia.net/f/builds-builds-on...1jz-build.html |
#4840 | |
also the gauges look great. |
#4841 |
I found this picture:
![]() I am assuming the signal comes from plug A but, what pin is it? Thanks in advance.
"I thought what i'd do is i'd pretend i was one of those deaf-mutes" Last edited by kalel540; 01-11-2015 at 08:58 PM.. |
#4842 |
#4843 |
![]() Join Date: Oct 2010
Anyone know how this http://zilvia.net/f/showthread.php?t=544928 air intake kit fits with s14 vvti 2jzgte stock turbo setup?
1) Does hood close ok? 2) Do you have to move fusebox on s14? If you look closely on this pic, http://i1092.photobucket.com/albums/...psac237f32.jpg , there are 2 rubber hose barbs without the hoses connected. One is on the intake, and one is on the hot pipe. I wonder if they had to leave those off for fitment, or if they just forgot to put them back? cxracing racing actual product link. http://www.cxracing.com/mm5/merchant...ory_Code=AIKIT |
#4844 |
![]() Join Date: Nov 2008
![]() Feedback Score: 16 reviews
In the process of a 2JZ-GTE VVTi in my S13. My motor was missing the Throttle Position Sensor, and the vendor is out of stock currently. I know a US TPS will work, but I am not sure which one. Either
a) 1995 Supra GTE TPS or b) any VVTi TPS from a newer model IS300, GS300 (2JZGE) Can anyone confirm with one is interchangeable? FYI the coil pack wires are the same on US VVTi cars. |
#4845 |
I know the ETCS motor thing is compatible but might not be 100% drop in. IIRC you might have to take take off part of the cam and flip it upside down to match the IS300 one. AS for TPS, that should be interchangable. I have both an IS300 and 2jzgte vvti which helps for these situations. Let me know if you want any pics or anything.
#4846 | |
Those barbs are just the hoses between the Hot side and intake and the stock BOV goes in between. I am sure they just forgot to put them back on, that shouldn't affect fitment. As for the fuse box, looks like it would fit with some massaging
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#4847 | |
Did you ever get your car running?
#4848 | |
#4850 | |
Went and looked at my VVTi in the garage, hope this helps 89452-30150 ImageUploadedByTapatalk1421293811.991162.jpg
#4852 |
![]() Join Date: Sep 2013
who is need of getting their DBW (drive by wire) VVTi throttle body to work like a regular cable operated one?
this will only work with guys that have a standalone ECU and do not want to use the motor operation at all... I will need at least 10 people to make bulk CNC run. |
#4853 | |
i would be! around how much these will run? i have a new 2jzgte T4 twin scroll manifold dual gated for 38mm tials price is 900 + shipping + paypal ImageUploadedByTapatalk1421373219.471375.jpgImageUploadedByTapatalk1421373270.083692.jpg |
#4854 | |
#4856 |
I am hoping to keep the cost down, the first one is already made (mine of course)lol, labor was free on that one. I am talking with a CNC machinist about running a batch based off of mine. initial setup will cost, but i am sure i can get it down to 50-60ish shipped. depends how many is made in the first batch.
like i said, this will only be to make the throttle body cable driven. gears will be removed and tossed. I will later produce a kit for OEM ECU guys 3 guys interested so far |
#4859 |
![]() Join Date: Jun 2009
![]() Feedback Score: 7 reviews
For those of you with cooling problems, my setup works flawlessly and never goes over 200 degrees, even under hard driving and hot weather. so i figured i would share and provide some tips. i also highly recommend running a power steering cooler, the steering is much more responsive and smoother. you'd be surprised how high the fluid temps get without one under normal driving. same with an oil cooler, its almost a must.
2x SPAL 10" Puller IX-30100435 800 CFM Fans (No Shroud) Mishimoto KA Radiator Mishimotor 154° F (68° C) Thermostat Earls -10AN Oil Cooler & Thermostat Adapter Earls -6AN Power Steering Cooler w/ Chase Bays 2jz Power Steering Kit PBM High Mount Intercooler ![]() |
#4860 |
Trader Rating: (18)
Does anyone know what the alternator amperage output is on a 2jzgte vvti from Jzs161 Aristo? I've been searching and can't find a definitive answer.
