05-24-2012, 11:56 AM | #4861 | |
ASD S13 4 Piston Rear Brake Upgrade Kit
NO HANDS IN PANTS!! |
05-24-2012, 12:07 PM | #4862 | ||
05-24-2012, 01:14 PM | #4863 |
Trader Rating: (18)
Feedback Score: 18 reviews
thats the point of using the stock handle instead of a normal hydro because you can use a drift button and the stock ratchet lock so you can still have a parking brake pretty easily plus it looks stock.
05-26-2012, 10:52 PM | #4865 | |
I want to go with square tubing my question is what thickness is a good enough size to support jacking the car up with? He said .120 which is about 8 gauge. Is that a good size to use? Can I go smaller/bigger easily? Thank you for you help.
☆ Panda Pirates ☆ |
05-27-2012, 01:04 AM | #4866 | |
so you are relying on hydraulic pressure over extended periods of time to keep your car parked.. thus the reason hydraulic lifts have locks. why leaving an engine hoisted overnight will be on the floor in the morning. OK man.. you got it... anyway .. sponsored a good buddy of mine. he races a 2001 e46 BMW with a 1JZ drivetrain. I fabricated the engine and trans mounts to make it possible. for free.. made of all 3/16 & 1/4" steel. fits perfect ! |
06-04-2012, 03:13 AM | #4873 |
One way to do your lexan/plastic windows ! ("How To Guide")
Tools: Jigsaw, finetoothblade, drill / screwdriver, 5mm and 4mm drill, razor knife, straight ruler! Material: Thicker paper as a template, Masking tape, Pencil, A pair of self-tapping screws. "80" Abrasives. Rivets ALU Steel Diam. 4.0mm 12.3mm length H12 Tip: Thinking before you act! Set the drill / rivet in a system, looks much nicer and thought trew. Make a template of the frame will be replaced. Please keep in mind that the panel covers a portion of the window, you may have to make a slightly larger window than the original glass. Cut out the window from the plastic sheet, preferably at some margin if something must be refined later. Apply the box to the car, use self-tapping screws to find the right position. Draw at the inside of the window and around each bodyedge, then put a masking tape stripe width to cut by. Then paint the black on the windows, scrub the surface a bit and use the paint that is a little "elastic" (plastic friendly paint that dont get bone hard when it dry) Drill the holes in the window to 5mm and 4mm in the body, to have some adjustment range. Good tip is to put every other pop rivets at the beginning to rub out the bumps that become. Measure it one time too much and test mount with self tapping screws preferably one or two times too much! Better to cut to little then to much, as the lexan is not "cheap".. ____ This is how i did, I dont say this is the only way, but its one way :thumbs: I Have been using google translate and fixed the problems i seen, but if you see anything thats not right or something (like grammar) please tell me so i can change it / D
C=(-_-Q) |
06-04-2012, 12:44 PM | #4875 |
dope how-to!
cONtRol FReAkS |
06-05-2012, 03:20 PM | #4876 |
WACHU know about this?
Customized my peace of shit oil catch can, hope it helps with blow-by because its driving me crazy trying to figure out a good system, so i'm hoping this works as a good breather
06-05-2012, 04:44 PM | #4877 | |
Trader Rating: (29)
Feedback Score: 29 reviews
06-06-2012, 01:22 AM | #4879 | |
i used 3mm thick lexan(swedish rules), and its pretty bendable.. maybe you need braces like nascar if its to "sloppy" but one piece i think would work..
C=(-_-Q) |
06-06-2012, 07:03 AM | #4881 | |
Depending on the tools you have access to, you could always look into going with a thicker sheet and forming it with heat. I've done 90* bends with .25" thick lexan with ~.25" internal radii with just a heat gun and some patience. |
06-06-2012, 02:19 PM | #4882 |
*The center is the size of my battery, the sides are 2'' to help battery stay centered, and a extra 4'' on one end to mount the breaker . .... Parts Used: -Small peace of 1/8 aluminum about 20''x20'' at the most. -150amp breaker from Auto zone. -Grip material -1/8 black pvc material to go under breaker, about 4''x4'' -15' Of 2gauge wire from Home depot -Positive and Negative terminals with plastic covers from Autozone -Battery hold down kit *just for the long screws -(4) 3/8 in. 2 gauge copper ring lug *
. Last edited by OutlawLui; 06-07-2012 at 10:01 AM.. |
06-06-2012, 04:59 PM | #4883 |
the rear jack point i made last night to finish off the rear bash bar. now bot front and rear bash bars have jack points ..
front bash bar i need to get a new pic i added some tabs and the jack pint.
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html Owner of NVS Fabrications |
06-06-2012, 11:55 PM | #4884 |
Anyone have any tips on figuring out angles for multi-plan bends of A-pillars for a roll cage?
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
06-07-2012, 08:38 AM | #4885 | |
Trader Rating: (29)
You might be able to download the trial and get what you need. |
06-08-2012, 06:12 PM | #4887 |
So I'm in sort of a situation and I'd like some input from the smart people of the fab thread.
I bought my car last year, didn't think to look under (well technically over I guess) the headliner. I noticed some leaking from the sunroof, took the headliner out and BAM, found out someone hacked in some sort of sunroof (non-oem). On top of that, it turns out they cut out a roof support. Forward to today, I took my car to a reputable body shop to see how much it would be to just pop out the sunroof and weld in sheet metal and put in a reinforcement bar where the old one was (you can see the spot welds that were plugged in the pic) Cut roof support in line with the b-pillar. roof by wilwmak, on Flickr You can see the flex in my roof. Roof by wilwmak, on Flickr The conclusion of the conversation with the body shop was that these are my options: -Replace the entire skin + support bar (pricey!!!) -Keep re-sealing the leaks Apparently if I just weld sheet metal back in place of the sunroof, the roof will sink. I let them know what I want to do with the car: -not have too much bodywork done because it's the car I'll be throwing around as a learning platform on the track -tracking -Daily What I was thinking was this: Keep re-sealing or pop out the sunroof and to counter-act the roof sinking/leaking, get some sort of reinforcement bars. I need to daily this car so I don't want to have a full out cage because they're illegal here. I've been doing some research and I think I need to take the direction of a half-cage, roll-bar, bolt-in half cage or a stealth cage. Something like this possibly. I like this one because I don't have to cut interior and there's no bars going across the back for cops to see and my best guess is the roof hoop will help with either sinking if I decide to pop out the sunroof either way will help with lessening chassis flex. (I can hear the glass crackling when I come down my driveway ) I know a bolt-in cage isn't the best for actual rigidity but this is a weekend track car/daily, so I'm doing the best I can... Any input is very much appreciated. |
06-10-2012, 09:07 AM | #4888 | |
Trader Rating: (31)
Feedback Score: 31 reviews
Built a fuel cell for my car. 17x24x10 baffled, with a VDO fuel level sender, and an aermotive stealth 340 with custom plasma jet cut flanges.
Slip Gypsies Blog Quote:
06-11-2012, 11:14 AM | #4890 | |
Trader Rating: (31)
Thank you, it is 15 gallons just in case i want to take the car on a long trip.
