#4951 |
![]() Join Date: Feb 2009
most of the cages are mig'd except for the t45 cages and back halfs are all Tig'd. tigin a cage isnt a pain in the ass, its the same process its just more time consuming to weld. the main thing id consider is which welding process are you more confident with and willing to trust your life with??? i dont know your welding skills but i never recomend someone try welding a cage unless they are insanely confident in there welds, but never overly confident or delusional. i consider myself a good welder and i even test my welds and materials regularly just incase!!! if your used to tig theres no point buying a mig to lay bird shit, but if your confident with mig then id say it would save you alot of time.
"Racing is life. Everything else that happens before or after is just waiting." ~Steve McQueen [Le Mans -1970] |
#4952 |
so its a good entry level tig cool it was in expensive so that's good. what did you mean stick and not mig? i have a mig and a stick welder why would i do that with a tig? little confused sorry
#4953 | |
![]() Join Date: May 2008
It cant do all three but it can do TIG and stick obviously. @ roco cool thanks, i just always see people MIGing cages and was wondering why. |
#4955 | |
![]() Join Date: Sep 2011
#4956 |
![]() Join Date: Apr 2011
![]() Feedback Score: 19 reviews
I don't have tube bending machines, or a welder, but i do what i can with what i have lol, even though its not really fab
Today i was looking up Radiator "Cooling Panels" or covers. And noticed they were over $100, and looked pretty simple to make So i took measurements and drew up a layout ![]() Then i used our router to make a vinyl cut out sample ![]() After some changes i finally cut it out of thin aluminum ![]() And finally painted it ![]() Ill post up the final pic wen installed Pics might take a day to work, i had more to post. but photobucket is giving me trouble. And here is it. Need minor little details ![]() ![]()
. Last edited by OutlawLui; 07-30-2012 at 11:12 PM.. |
#4959 |
![]() Join Date: Sep 2006
![]() Feedback Score: 23 reviews
looks good, jack. how did you bend the metal? brake?
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
#4960 | |
![]() Join Date: Apr 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
That car looks like the ones at my work, except we build Camaros and mustangs
I <3 jdmhookup |
#4962 |
![]() Join Date: Sep 2003
cage for S13 vert that Ive been working on. Dave Hodges is responsible for the engineering. Ive done all the TIG welding. turning out really really nice..
#4963 |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
Anyone thats into machine work or interested in getting into machine work take a look at this.
mrpete222's channel - YouTube I found this guy while looking for a "how to" on something but then just watched some other videos of his and he knows his shit. |
#4964 |
![]() Join Date: Nov 2005
Looks good, except you would normally have the x in the halo meet the little cross bars to the a-pillar. In a cage you want as many common connecting points as possible, it helps with load distribution in an impact.
#4965 |
this cage was custom built for an abnormally large man in a tiny car.. it was either this x brace or no x brace at all. its just how it worked out. once he gets the cage back in the car so i have weld that piece to the main hoop and rear bars you will see. Its a really interesting cage that has taken a LOT of time..
#4966 |
Damn some good work here the last few pages. Here is a TD06 manifold I built for an sr and a dinosaur greddy wastegate that is the size of a pineapple. Wasn't enough space to do the wastegate the way I wanted but this will do. Still a very large upgrade from what he had. Used the torch switch (using slopes) and no footpedal for the whole thing.
#4967 |
yeah that particular one is cf, but i not sure if the other two built were? they could be high grade fiberglass!?
#4968 |
ok here is an odd question.....subframe bushings....i know everyone makes theirs out of aluminum, but has anyone tried plastic of some sort??? ive been looking into mcmaster carrs website and looking into delrine to make bushings out of, they give alittle, but have decent impact resistance but will be alot better than oem bushings. any idea how it would work?? the other question does anyone know the dimmensions of s14 diff bushings? i just picked up a vsld and need to know how tall to make the top part of the bushings. thanks
#4969 | |
#4971 | |
@UpshiftEngineering |
#4974 |
My custom SR twin scroll manifold, downpipe and mid mount I/C set up. Only runs 3 couplers for entire I/C, 4th is vband from turbo to hot pipe. ImageUploadedByTapatalk1346163656.260203.jpgImageUploadedByTapatalk1346163670.399856.jpgImageUploadedByTapatalk1346163683.243876.jpg
#4975 |
Here's the rest ImageUploadedByTapatalk1346165101.749760.jpgImageUploadedByTapatalk1346165116.167858.jpgImageUploadedByTapatalk1346165132.602644.jpgImageUploadedByTapatalk1346165150.486971.jpgImageUploadedByTapatalk1346165169.302413.jpgImageUploadedByTapatalk1346165184.537431.jpgImageUploadedByTapatalk1346165197.978111.jpgImageUploadedByTapatalk1346165213.801181.jpg
#4976 |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Buying myself a Hobart 210mvp this weekend! I can't wait to start using it.
![]() ![]() Friends help you move. Real friends help you move bodies. |
#4977 |
My latest pick up:
![]() 1930's Canedy-Otto 21" box column sliding head floor drill. 16-speed (8 direct, 8 back-geared, range 82 to 2100 RPM) 1650 lbs net. Jacobs Num. 18n chuck on it as well. Swooped it for $175 at auction lol. Everyone was afraid of moving it.
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
#4979 | |
Also using a Lincoln electric 3200HD mig welder. It's a very good mig for a 110 as long as your plugged into a socket close to the panel. |
#4980 |
![]() Join Date: Aug 2008
DC5 i just did for Buddy Club Thailand
![]() My personal DD Galant VR4 (custom twin scroll evo 8 turbo set up i built while at Full Race) Personal s13 (custom manifold built while at FR) ![]() |
