#481 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
LongJeeper Not sure if the OEM and JDM are compatible for a 1jz but if they are here is a link to someone selling the dipstick
SupraMania |
#482 |
![]() Join Date: Sep 2009
Trader Rating: (22)
![]() Feedback Score: 22 reviews
No lip for now. If it gives me any problems I'll put a bead around it. There's two s14's in my area with 1jz's, and they haven't had any problems with no lip, though I'm not sure what kind of pressure they're running in their cooling systems. My koyo cap is 1.3 bar.
#483 | |
#485 | |
Thanks for the link 2much! this is the info on the dipsticks that i have found. looks like the JDM is close to what i need 1JZ-GTE Dipstick Length |
#486 | ||||
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
awesome ![]() Quote:
you need one from a JZX81 (front sump) JZA70 & JZZ30 Rear sump ones are to short been doing alot of research on it
My Build: The "Coupe De Ville" 1JZ Build!! |
#487 |
Trader Rating: (79)
#489 |
Trader Rating: (22)
Not that you guys care, but I'm stoked! Finished building my jumper harness, and got my car to fire up first try! I still have to clean up the wiring and install my front mount and do a few small things, but I'm just glad it's finally alive. And also sorry for it being a shitty quality video haha, it was from my 3gs.
2jz coupe lives! |
#491 |
![]() Join Date: Jul 2009
Oh yeah, idk if anybody mentioned it earlier, but it needs to be well known that you gotta move the fuel lines from the passenger side to the drivers side unless going with a custom fuel system when you will still come up the drivers side.
I just spent half the day today doing this. |
#492 |
Trader Rating: (22)
Haha yeah it's on the first page. I used a set of chasebay's lines (they were free to me so I can't complain).
It'd be pretty easy to make your own set though, you'd need two lines ~54 inches in length, put a -6 end on the feed line, -6 fuel filter, female to female AN coupler (still -6), then a metric (m12x1.25) to -6 fitting to adapt to the stock 2j fuel damper. Return line will just be a rubber line with worm gear clamps on each end (also the other end of your feed line will also have a worm gear clamp, as these are being attached to your factory hard lines). I'll try and make a list of parts and prices tomorrow for someone who wants to DIY. |
#496 |
My booster isn't the issue.....its the master cylinder. I went with banjo fittings on my brake lines, spaced the line side of the m/c with a couple washers and took a grinder after the last 2 runners on the manifold
#497 |
Trader Rating: (22)
So how is your booster hose connected to the mani? I was figuring I could run some sort of banjo to barb fitting off the top port in my manifold, but can't seemed to find a suitable solution
#499 |
Trader Rating: (22)
Ah damn lucky! Looks like I don't have one because Aristo's came with some sort of electronic brake booster. The bolt is the same for the x8/MKIII chassis and for MKIV's it looks like, I just hope toyota still makes/sells them though! I'll find out tomorrow when I try and order, but for anyone wondering here's info I found on SupraForums
7m 90401-12012 bolt, list 8.63 cost 6.59 ea 90430-12005 gasket list 1.06 cost 0.81 ea x 2 90405-09119 union list 8.63 cost 6.59 2j 90401-12012 bolt, list 8.63 cost 6.59 90430-12005 gasket list 1.06 cost 0.81 ea x 2 90405-09174 union list 7.06 cost 5.38 |
#500 |
#502 |
Trader Rating: (22)
Yeah my GTE plenum isn't really close to my brake lines. And my upper plenum did come tapped from the factory for a brake booster fitting, it's directly on top of the plenum though, but it just had an m12x1.25mm bolt in it with a copper crush washer. Though I think some Aristo plenums did NOT have a factory port/fitting in the top, not sure which ones did and didn't, just glad mine has it. I just need to source that GE fitting haha.
#506 | |
Trader Rating: (22)
But if anyone is wondering, the parts exist! Ordered all 3 parts today, will receive them tomorrow. So if anyone needs a solution to a brake booster fitting like I did, there you go. It was right around $20 out the door. |
#507 | |
Trader Rating: (79)
If anyone is interested? http://zilvia.net/f/sale-items/46581...ml#post4804429
#508 | |
#510 |
has anyone corner balanced their car yet? has any one scaled their car to see what the added weight is with this swap? i plan on doing this, hope it helps at the autocross lol
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
