Old 01-07-2013, 02:14 PM   #481
PoorMans180SX
PoorMans180SX's Avatar
I sure hope that's not the dyno, the powerband looks terrible.
Old 01-07-2013, 06:04 PM   #482
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
That's a wacky graph, and judging by the lack of top end retention we can all easily see how it was overspun *the turbo* to make the inflated number (which you can see many a times, especially on v8 turbo cars where they spin the balls off the turbo only to fall falt on the top end).
I really need to get back to the same dyno in the spring as I went to for my 2871r setup, I know this turbo is certainly making more power. Love it.
Old 01-09-2013, 02:36 PM   #483
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Originally Posted by unijabnx2000 View Post
Think I found the dyno sheet of the car, they said 26psi instead of 28psi like Garrett said on their page.
This engine doesnt even have a powerband. It drops off harder than any T25 Ive ever seen.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 01-18-2013, 11:11 AM   #484
Rafa-Z
Rafa-Z's Avatar
Rafa-Z is an unknown quantity at this point
I'm going to run an external wastegate with the gtx2867r and a codyace modded stock manifold but I wanted your guy's feedback on 2 things. First is should I get a Tial MVS or MVR? and second is do you guys port out the inside of the stock manifold when using it like this? If so who do you guys recommend or how much should be ported out? is it worth it for around 350hp?
Rafa-Z is offline   Reply With Quote
Old 01-18-2013, 01:22 PM   #485
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
Both sizes will work fine, but the 38mm is cheaper and more compact, so why pay more for 44mm... unless you think you might still get creep.
another member on here said they still were getting creep w/ a 44mm on a oem sr manifold. anyone else have creep issue?
huffandpuff00 is offline   Reply With Quote
Old 01-18-2013, 04:48 PM   #486
cotbu
cotbu's Avatar
No creep here from v44 stock manifold
Old 01-20-2013, 03:24 AM   #487
Rafa-Z
Rafa-Z's Avatar
thats exactly what I was thinking why pay $100 or more and im sure even if it gave me some boost creep it would be way less than an internal one, I'm guessing. Anyhow im guessing that by the time I need to upgrade it will be for a twin scroll setup and it can always be sold.
Old 01-20-2013, 08:07 AM   #488
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
I would be surprised if a 38mm would creep on a gtx2867r. Heck, I ran a GT2871r at anything from 7psi to 20psi on the internal gate and it never creeped on me.
Seraphim38 is offline   Reply With Quote
Old 01-20-2013, 01:18 PM   #489
codyace
codyace's Avatar
Trader Rating: (58)
On my stock manifold setups, both the two bolt Tial 38, and V Band 38MVS do not creep with with the GTX 2867. 12 psi base springs in both, 12 psi to redline on the gate, 15 with the EBC and 20 with the EBC no issues.
Old 01-20-2013, 03:50 PM   #490
Def
I'd go with a MVS 38 for a turbo like this. Should be plenty fine.
As for porting the stock manifold - it needs it BADLY. I spent about 8-9 hours on my manifold and took off a little over half a pound of material. The tooling clearance bumps are ridiculous, so that's the first place to start. Then work on smoothing things out and gasket matching them. I also put anti-reversion port shapes on the mani (larger than head ports). Basically opened the ports out to the gasket on the mani with a good 20-30 deg taper into the port. That also helps with any mani to head alignment mismatch.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 02-05-2013, 03:52 AM   #491
huffandpuff00
anyone check this out...http://zilvia.net/f/forced-induction...ml#post5124337
Old 02-05-2013, 08:58 AM   #492
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
^Wut? Didn't know that was possible.
di-devol is offline   Reply With Quote
Old 02-05-2013, 04:58 PM   #493
S14DB
AFC #1
S14DB's Avatar
I have seen the option popping up with some re-builders now. Not a bad price for a wheel and balance.
I was quoted $750 for a New CHRA and GTX wheel installed.
Old 02-05-2013, 05:03 PM   #494
codyace
codyace's Avatar
Trader Rating: (58)
450 dollars for all that seems a bit on cheap end IMO, especially for a billet wheel. Still a nice price, but it almost seems too good to be true IMO especially when replacement wheels (non billet), the machine time, and the balance (for any turbo) would cost that much.
Old 02-05-2013, 05:12 PM   #495
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
Anyone running big boost with e85 on one of these??
I have a $12k sr20 that I'm about to sell in lieu of a stock sr20 with a head gasket, head studs, CodyAce mani, JWT s4 or c1 cams, and the GTX2867.
I would like to try for 475whp with very close to even torque at 25+ psi on e85.
Just wondering if anyone else has used this turbo with fuel.
ForeignMuscle is offline   Reply With Quote
Old 02-07-2013, 09:36 PM   #496
801nismo104
801nismo104 is an unknown quantity at this point
Ill be running 20+psi on ny gtx2867r with sunoco 104 not E85 though. What size exhaust housing are you going to use? I have the 0.64 but I might switch over to the 0.86 to get the max potential out of it.
801nismo104 is offline   Reply With Quote
Old 02-14-2013, 01:17 AM   #497
Rafa-Z
Rafa-Z's Avatar
Hey guys so I was going to run the cody ace manifold but got a great deal on a DOC race manifold with optional v band setup but Im still interested to know what mods do you guys do to the stock manifold? Do you port it or run it like that? How much is it usually to extrude and hone? Do you guys think the DOC racing one flows a lot more?
Also I got a great deal on a GT2871r .86 since I didnt have enough money to purchase the GTX2867r but to my surprise, the same day I got it Pure Turbos posted that they upgrade it to the billet gtx wheel for an extra 300 which saves me almost half of what I would pay for the other turbo. I plan on posting dynographs and everything once its all done. Let me know what you guys think.
Old 02-14-2013, 02:54 AM   #498
Croustibat
On a well tuned ca18det w/e85 i know, at 24psi, it makes around 430HP (not WHP). The boost starts to go down at 8000rpm (he is running 260/ 10.25mm cams and solid lifters, ported head and so on). I dont think it can make 70HP more.
That is the reason he is going for a big twinscroll turbo
Old 02-14-2013, 04:11 AM   #499
huffandpuff00
I ported my stock manifold to the best of my abilities, because extrude/honed is $495. Getting it E/H im assuming makes a big difference on flow of the eom manifold, but ultimately i ended up switching to a doc mani for the true collector and quality.
Old 02-14-2013, 06:55 AM   #500
ForeignMuscle
That's good power for the CA, but I wouldn't say the turbo is maxed out.
An sr engine has more displacement. I could use 12.5mm cams and I feel like I could push more than 24psi out of the gtx, but I could be wrong. Surely the thing is good for 450whp at least. If Codyace made 400whp with a 2871 and pump gas then I should be able to see close to 475whp with e85, 5 more psi, and the advanced timing that ethanol allows. No proof without puddin though.
I may just keep my big top mount setup and make 500whp with ease.
Old 02-14-2013, 07:17 AM   #501
Croustibat
The turbo is advertised as a "max 475HP" .
Check its flowmap:
I think it will overspin and still be out of puff at 30psi on an SR20. It will have awesome spool time though, seeing how reactive it is on that CA... basically, it has gt2871r/gt3071r power potential, with faster spool.
the problem is not knock, which e85 allows to get rid of, but the turbo ability to produce flow at 30psi. If it is out of puff at 25psi on a 1.8L @ 8000rpm, i really dont believe it will produce enough flow to get 30psi on a 2L (even at 7000rpm). I would not use that turbo if your power goal is 500HP (unless you dont care how long it lasts and you just need fast spool).
Old 02-14-2013, 07:26 AM   #502
ForeignMuscle
I might not have put the "5psi more" in best terms. I meant 25psi on an sr20.
It's not really a set number I wanted rather an itch to start over and build another engine to the max. I get bored easily I guess.
I may just keep my current setup and build a t2 powered engine on the side.
I believe my top mount, billet Precision 5858 actually spools faster than my 2871 did. I would love to have the torque of a t2 based turbo though.
Old 02-14-2013, 07:34 AM   #503
Croustibat
TBH that CA, while very efficient, is boring with that turbo. When it had a gt3071r it has some kick to it. Now it has a big fat powerband... but it is boring. It accelerates very fast fast, but there is no "turbo feel", no kick in the butt. I dont know how to describe it ... His owner agrees too. The replacement is a gtx3582r (yes, no typo here. yes, LAG, he knows ) , power goal is in the 600HP range (new gearbox is on its way too). His car is somewhat a demo car for the shop though.
It really depends on what you do with the car, or what you want from it. If you want low down torque, you cant go wrong with a 2867... i dont know how it compares with your current setup though.
Old 02-14-2013, 09:29 AM   #504
ForeignMuscle
You're probably right, Croustibat. I like the "violent" powerband of a large turbo. I probably wouldn't be happy with such a smooth and linear powerband as a t2 turbo would offer.
I guess it's a good ole case of wanting what I don't have. I know I wouldn't mind setting that 3582 on my manifold for the weekend
Old 02-14-2013, 10:43 AM   #505
Rafa-Z
Rafa-Z's Avatar
yeah that's what I was afraid of. I mean I really like the stock manifold set up that cody ace makes and was my original option for many reasons but I got a brand new DOC race manifold for 300 bucks and it came with the v band option. I was still hesitant since the cody ace one would be less than half of that without e/h.
Old 02-14-2013, 12:09 PM   #506
codyace
codyace's Avatar
Trader Rating: (58)
C1 cams are great, I just think they'd be better suited to a 30r turbo with less exhaust back pressure. Ttruthfull, that's the main detriment IMO with all of these T2 setups as it's such a fine line pushing these things with such high backpressure ratios. In this same regard that's why we see these setups often knock pistons out and or ruin headgaskets at the hands of inexperienced or aggressive tuners, as it's easy to keep dumping timing in them as they naturally are just going to keep spooling quicker. Torque onset is like herion to engines though, as they love it...but it doesnt' love them back.
I'd say 450-475 would be possible, but you'd certainly need S4 cams and some RPM to play with. Big intake manifold too. In that same regard, I'd be certainly using an externally gated/extruded (or ported) setup for sure.
Agreed there. Again we're at that fine line of backpressure actually hurting top end (albiet while helping spool up)....which stinks...but we can't have both unfortunately.
The doc is tubular, so I don't see the extrude being worth it as that pipework is already quite smooth. I'd certainly get it coated, and I'd even go as far as to brace the manifold too to help further prevent cracking.
In regard to the Pure turbo setup I'd be interested to see, but I'm not sure if proof is in the pudding yet...it just seems too cheap yet.
I strongly believe with my S3's that the GTX is an easy 415-425 whp car at 20psi just based on maxing out things that were not maxed before. It's a hell of a turbo.
It's funny you say that as I've had plenty of people say 'man this car doesn't really feel that fast' and I like to point them over to the speedometer racing the tachometer
Old 02-14-2013, 12:34 PM   #507
Rafa-Z
Rafa-Z's Avatar
Sorry I didn't mean porting the DOC race one I meant porting the stock one. I will definitely get it coated or wrapped. I had an Isis version 2 and it never cracked but I have the PBM cobra downpipe and it has a flex pipe. I use to daily the car in Mexico and drift it very often.
Old 02-14-2013, 01:09 PM   #508
Croustibat
That is exactly what happened. He wanted to demonstrate his new brake setup. I said "meh. Not impressed by braking power, and it seems you are locking the front easily". His answer was "ok, i will do it again, but look at the speedo this time".
In fact, he just accelerated to around 160mph like it was nothing, and then the brakes got the car back to 30 in what was a very very very short length of road. But the way the power was delivered felt like it was way slower.
This is a very efficient setup, for sure ... but it is no fun
Old 02-14-2013, 01:18 PM   #509
Slide~or~die
Slide~or~die can only hope to improve
Question: Can you run a twin scroll manifold with this EWG set up? (GTX2867)
My reason for asking is because i dont see why this wouldnt work, but im not an expert.
Slide~or~die is offline   Reply With Quote
Old 02-14-2013, 01:38 PM   #510
huffandpuff00
i dont think so, wouldn't be enough room for both wastegates. one is a tight fit.
gt2871, gtx, gtx2867r
