#5161 |
#5162 | |
as for brakes, break them in the right way and it'll grip better
street dancer. GLEAM |
#5163 | |
I'm going to clean it as soon as i feel like buying all the gaskets lol - no vacuum leaks as far as i know but i did remove a bunch of vacuum lines this winter so i can double check
#5164 | |
![]() Join Date: Mar 2010
Trader Rating: (18)
![]() Feedback Score: 18 reviews
#5165 |
Trader Rating: (18)
I got another new question, did a bunch of searching on google and other forums but need PERSONAL EXPERIENCE, im thinking about seafoaming my car. Want to know if its safe to do on my motor. Im only going to do the 1/3 fuel system and than 1/3 in the brake booster vacuum line.
A little more info on the motor: no more than 120,000 miles, compression is roughly 165/170 all across, no smoke upon starting and running just normal condensation. However I heard it can potentially mess up gaskets? my valve cover gasket leaks thats about it, and also im about due for an oil change so i thought now would be a good time. Opinions please... and thanks |
#5167 |
![]() Join Date: Aug 2005
has anyone purchased a DME rear strut bar for an s14 and installed it? if so, how is it strut bar suppose to fit?
I already cut my backseat/strut tower cover, but it does not sit right.
#5168 |
![]() Join Date: Aug 2007
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
Has anyone shaved their front fenders rather than Roll them? If so, did you prefer shaving the lip off over rolling? Did it make the front fenders less rigid or no?
★ ★ GRANDMIGHTY.COM ★ ★ |
#5169 |
my oil pressure gauge has been working fine but today as i parked my car i noticed it was stuck past 10kpa. Like stuck maxed out, turned the car off, unplugged and everything but nothing did the job...
Its blitz so i doubt its the gauge itself but any ideas?
#5170 |
![]() Join Date: Dec 2003
Anyone know of 35 hole barrels in 17's with like maybe a +12/+15 offset?
Looking for new barrels for these ![]() ![]()
![]() **CoUpe LOve** Member #00 |
#5171 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
Run Seafoam per directions, change oil after. I'ts not gonna fix the leak, but will help. Just FOLLOW the directions. Can't hurt anything. I just use the vacuum method. Quote:
I've shaven quite a few porsches now, all without issue.
#5175 | |
I can get brand new fenders from a parts store for $130-150, that should give you and idea of how much a used one should be. Just lower the price accordingly based on condition.
#5176 | |
Trader Rating: (18)
![]() Oh and P.S. i still got an interior harness for you im gonna send you a pm in a min |
#5177 |
I just picked em up today, thats why Im looking for new barrels. Sorry broski, lol
Im just not trying to pay $300 a wheel to get them widened.
#5178 |
Hey guys,
I hope this is the right section. Feel free to move the post to the appropriate section if necessary. This is directed mostly at the Kouki 180sx Aero Thread/Early 2000's Japanese drift guru's. I am wondering if anyone might know specifically what issue/'s of HyperRev/Battle Magazine/Drift Tengoku/Option/etc have car features on the following: - Itai's blue HotRoad/Bronze TE37 180SX - Koguchi's black HotRoad/Blitz Z1 + Blitz Z2 + LMGT4 180SX - Ito's red kouki aero with R33 N1 vents/Bronze TE37 180SX - 'With Run' green kouki aero/Bronze Advan Model 5(I think) 180SX - 'Sexy Knights' black SexyStyle aero/Panasport C5C2 180SX Any help would be much appreciated. Cheers. |
#5179 |
![]() Join Date: Nov 2009
![]() Feedback Score: 16 reviews
I have a 96 240sx and my clutch works and engages and everything but i have a small problem it doesn't come all the way completely back up. I usually just tap it a few times when im in a gear to make the clutch pedal come all the way back up. Whats is the promblem? Should i get a new clutch cylinder?
#5180 | |
#5181 |
subframe side 51-65 ft lbs
knuckle side 57-72 ft lbs except toe rod knuckle side is 36-51 ft lbs
#5182 |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
what are the benefits of going with forged steel rather than going with chromoly sway bars?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
#5183 |
![]() Join Date: Apr 2009
Havent really found an answer, googled and even looked on here but just want a definitvie answer before i buy. Are the Blitz BLM gauges electric or mechanical?? Ive read that there electric, that there mechanical, that only the boost is mechanical. Someone who owns or has installed them please chime in, Ive had Defi BF's but dont really wanna run those again, so looking into the STRI gauges but really like these BLM's
#5184 | |
The gauge is literally brand new, i haven't had it installed for more than 5 days, so i have no idea
#5185 |
quick dumb question, when i bought my kouki s14 it came with an OEM lip not attached, the holes are basically torn up. how should i go about re-mounting? should i drill new holes through the bumper and lip (dont really want this)? what about plastiweld?
#5187 | ||
Trader Rating: (58)
Nope. Gotta take out corner lamp to gain access to the 2 nuts on the side, and take the grill out to get to the 2 bolts there.
#5190 |
The grounds are bullet connectors spliced and soldered to the stock harness (2 butt connectors/wires join to 1 wire which is soldered to the harness)
Blitz blm
