#5191 |
![]() Join Date: Nov 2005
This just makes your tie rod longer, and does nothing for angle. I guess it could be a "fine adjustment spacer" If you needed a couple more threads for your outer tie rod to thread on...
#5193 |
![]() Join Date: Jun 2010
If those GKTech spacers are anything like the ERA-1 that I have (they look very similar) they add 42mm per side, I dont know where they get that 18mm measurment.
I extended my LCA's 40mm to match and still ended up having to extend my adjustable outers by ~10mm to reach. I figured that the forward relocation of the inner (via spacer) would cancel out the extra tie rod length required when using modified knuckles, but apparently not. In regards to wheel size, in order to keep the wheel off the tension rod at full lock, you will need maximum inboard clearance. You can squeeze 17x9 +0 with 215/40 under stock fenders, but if you run LCA's any longer than S14, you can forget about that. At that point, go with 17x8 +0, otherwise you will need wider front fenders. |
#5194 | |
![]() Join Date: Oct 2010
So 45mm RC drop and 5-7 or 8-10 degrees of Ackerman. I have not finished reading this thread but does the more angle the knuckle produce, the more quick steering it is? Or does the degree of Ackerman generally imply quicker steering? Where can I find Information about the Cor integration knuckles |
#5196 | |
![]() Join Date: Apr 2011
As for wheel sizing I run 17x9j -11 up front right now with the ability to go lower offset if I add even more camber, which will be done with the extended LCAs anyways.
☆ Panda Pirates ☆ |
#5197 | |
![]() Join Date: Jan 2011
#5199 | |
Ackerman is the difference in steering angle between the inside and outside wheel. From the factory, there is greater ackerman to allow for smooth turn in at lower speeds. In drifting, minimal ackerman is beneficial because both front wheels will be pointed in the same direction at full lock as opposed to the trailing wheel scrubbing speed. Maybe someone can chime in as to ackerman and road racing, but i believe less than stock ackerman allows for greater speed in mid to high speed turns. |
#5200 |
has anyone on here ran the abercrombie motorsports full kit (subframe knuckles extended lca and tierods) and a ackerman setup trying to find a good setup for relatively cheap at the moment while still be quality or know if i can run the wisefab ackerman setup with other knuckles
Abercrombie Motor Sports |
#5201 | |
I'm not sure what you mean about running the "wisefab ackerman setup" with other knuckles, the wisefab knuckles and ackerman adjustment kit are far different from most knuckles on the market, and is not compatible with any kind of stock knuckle. I guess if you really wanted to you could make your own adaptation of it.
#5202 |
![]() Join Date: May 2009
Here it is i wanted to share this thanks for any comments or advice i found i need longer tie rods other than that evrything looks fine imo maybe the 225/40R18 wich are tight tight tight fit
#5203 |
Nice setup, do you have any idea on the angle? Looks good just the angle doesn't look all that amazing for the money I know you spent on it..
☆ Panda Pirates ☆ |
#5204 |
i should try to mesure the angle it doesnt look that crazy to my eyes also but its on the point where the knuckle hit the stopper on the lca so it should be the max angle their kit provide
#5205 | |
I am running 1.5" longer s13 lcas, ikea formula inner tierods with no slip on spacer, moog s14 outer tierod ends, and i moved my steering rack 1" forward. using PBM 1st gen max angle kit. Tein super drift coilovers and rotated my top hats to be camber/caster correct (positioned so the strut is slid as far towards the front of the car and with as much camber as i can). I can see a difference from mine to yours even tho the angle of the picture is different. I am almost over centering the rack with it moved forward. <---front of car, taken looking down on the drivers side front wheel. ![]() ![]() ![]() can see how I have my top hats positioned in this pic. ![]() |
#5206 |
my top hats are almost that way but only caster oriented, i got the steering rack moved a bit with pbm eccentric bushings thats it ,
-tein s14 inner tie rod ( too short) a34 maxima tie rods on order, megan racing outer tie rods, 6mm tie rod spacer, 30mm wheel spacer, track widened a bit over an inch i dont see how it can provide more angle than that... and dont see any bigger angle on your pictures either |
#5207 |
You can take off the bump stop on the lca if you are not over centering yet. Also, moving the wheel back in the wheel well will reduce over centering and increase angle.
#5209 |
That wisefab knuckle looks kind of rad, would be interested to see what it actually has built into it other than some RC correction... Adjusted toe & camber curve too?
Somewhat related, I am convinced that every car with wisefab parts has to look weird. |
#5211 | |
#5212 |
![]() Join Date: Nov 2009
wow lots has happened since i was not around for quite some time! Hmmm! What's new? I see there's some other kits being made and def tearing them apart. Any grip specific ones, I see a double wishbone conversion if im not mistaken?
Someone give me the cliffnotes for last 5-6 months lol |
#5213 | |
![]() Join Date: Dec 2009
Sent from my SCH-I535 using Tapatalk 2
MAddDsBRO LEHDABIHLOO |
#5214 | |||||
Yeah this looks pretty sweet, I saw it on facebook this morning. I'm interested to hear the breakdown when they release the explanation video. Quote:
Yeah that's now his demo car, so looks are probably less thought of than function. Some flares in the front and overs in the rear and it would look pretty normal. Quote:
GKtech has started production, and has several steering arms, two of which are grip specific. They are listed in the first posts. PSM has released their forged Pro Drift knuckle, but can still make the Pro Grip knuckle if you'd like. Wisefab is about to come out with a complete rear kit (see video above). I think that's about it. Here's some random pics of TDP's kit in action. The front wheels are 18x9.5+0 (spacers), they poke pretty far on this car. I spoke with him, he's running that much camber on purpose, not because you have to with the kit. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#5215 |
wow ridankulusssss lol
thanks for the update. So as of now TDP and GKtech are the ones that have the most serious grip oriented/billet/light/etc... setup? The rear kit video got me excited then it just goes to "coming soon" LOL well i guess its coming soon ![]() |
#5216 | |
Yeah they'll release the video shortly I'm sure.
#5217 | |
i get pretty lost with making corrections to fix my suspension geometry as im still learning and researching anyone have any suggestions on a reasonable priced good quality and good for drifting with a good amount of angle |
#5218 | |
#5219 |
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 2 reviews
The factory designed the suspension to toe IN on braking, have you slammed yo sheet? Also the thing with traction arms is that they imo they must be fitted together with camber arms and be lengthened as much.
