Old 03-21-2011, 06:28 PM   #5191
h2v7
h2v7 is an unknown quantity at this point
I would say pump. Or if you have a auto it may be your cooler.
thanks, guess ill start looking for a new one...
new small question
anyone have a power stearing pump for sale?
and are s13 and s14 interchangable?
what about sohc and dohc?
h2v7 is offline   Reply With Quote
Old 03-21-2011, 06:37 PM   #5192
Wake
Wake's Avatar
look in the for sale section I see em there all the time, bu I would personally just buy a new one. you dont want to start with someone elses problems.
Remeber to take the old one in with you if you get a new on because there will be a core charge.
and.....
s13 dohc/s14 are interchangeable.
I dont think sohc will work since its on the opposite side of the engine
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 03-21-2011, 07:26 PM   #5193
S14DB
AFC #1
S14DB's Avatar
Originally Posted by h2v7 View Post
when car is cold i feel like im fighting the power stearing.
kinda locks up at points
once it warms up im fine...
Ps fluid is full?
my pump bad?
Drain all the fluid out and put new ATF in.
Old 03-21-2011, 07:33 PM   #5194
Wake
Wake's Avatar
Yes do what he said first ^
I always assume people have already done shit like that before posting and asking for help. Sorry
S.P.P.S. Member #00
Old 03-21-2011, 09:18 PM   #5195
h2v7
word didnt think of that but i like the idea thxxx!
Old 03-21-2011, 09:41 PM   #5196
JKL1031
JKL1031 is an unknown quantity at this point
Originally Posted by JKL1031 View Post
anyone ever jumped timing or broken the timing chain before? whats the chance of valve/piston damage? Car killed over at about 2.5k leaving a light. I try to crank, and all i hear is i guess the starting spinning. sounds like an electric can opener.
Originally Posted by codyace View Post
I've personally never heard of it happening, but it's possible. Pull off oil cap, have a friend crank it, and see ife the cams move.
Not the same. IIRC you can make KA24E ones work, but I've never personally done it. If you're looking for an alterantor with better output (125 amps) you can use one of my conversion kits with a Quest Alternator.
I look through the oil filler and the cams are still turning, so the chain is not broke?
Ill take off the valve cover sometime and get another look. Right before what ever it is happened, the idle was bad, and the car was bucking holding a steady RPM in a fixed gear, but no bucking for acceleration.
JKL1031 is offline   Reply With Quote
Old 03-21-2011, 10:49 PM   #5197
DS562
DS562's Avatar
DS562 is an unknown quantity at this point
ok, i confirmed my "volks" arent volks. im now thinking they are the Varrstoen reps. how can i tell if they are in fact Varrstoen?? i did some research but found nothing of use.
Zeeeeeeeee32
DS562 is offline   Reply With Quote
Old 03-22-2011, 07:12 AM   #5198
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
THink about it...the chain goes around the crank shaft, and the cams...if the chian is broken, and you spin the engine over, only the engine will turn...the cams need the gear to turn. So yes, if you see the chain moving then you can be assured the chain is at least still in tact. Could it have jumped a tooth? Sure...but that would mean that the tensioner has failed completely or is missing.
Did you check over vacuum leaks and the sort? Nothing else broken?
-CA
Old 03-22-2011, 07:21 AM   #5199
Origin
Origin is an unknown quantity at this point
Is there a way to get rid of all that shit under the stock intake manifold? Theres way too many wires and what not. If I buy a new manifold does all that (or most of it) disappear? Currently looking at Excessive for a replacement.
Origin is offline   Reply With Quote
Old 03-22-2011, 08:39 AM   #5200
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
i tried googling but came up with tooo many answers. none thast answered my question.
what are the benefits of going with forged steel rather than going with chromoly sway bars?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 03-22-2011, 10:28 AM   #5201
JKL1031
-CA
yea its just that everyoen was telling me that, and the car sat for 3 weeks at the shop, taht told me the same, but they didnt even bother to really check anything out. The engine isnt turning over, all i get when i turn the key is electric can opener noise.
Old 03-22-2011, 08:37 PM   #5202
obsolete
obsolete is an unknown quantity at this point
do you have to remove the cams to replace the valve stem seals on sr20?
obsolete is offline   Reply With Quote
Old 03-22-2011, 10:44 PM   #5203
jamg
my goal power is 250whp to the wheels.
what KA-t options do i have to get there? because ka-t is the cheapest route, and swapping the motor is out of the question.
also, my car has a starting delay problem.
i will press the clutch in, start the car, and nothing happens. at times, i have to pump the clutch over and over and over again to get it started. other times, i only have to pump the clutch a few times. and sometimes it starts right up.
Old 03-22-2011, 10:57 PM   #5204
BLKTOPSR20DET
BLKTOPSR20DET's Avatar
BLKTOPSR20DET is an unknown quantity at this point
check your neutral safety switch or you have a bad starter relay.
BLKTOPSR20DET is offline   Reply With Quote
Old 03-23-2011, 02:31 AM   #5205
CrazyIvan
CrazyIvan's Avatar
CrazyIvan will become famous soon enoughCrazyIvan will become famous soon enoughCrazyIvan will become famous soon enoughCrazyIvan will become famous soon enough
What flares?
powder-coated.com - I do Custom Powder Coating
CrazyIvan is offline   Reply With Quote
Old 03-23-2011, 07:06 AM   #5206
chiboy002
chiboy002 is an unknown quantity at this point
Originally Posted by CrazyIvan View Post
What flares?
http://zilvia.net/f/chat/174916-identify-thread.html
street dancer.
GLEAM
Old 03-23-2011, 10:56 AM   #5207
CrazyIvan
CrazyIvan's Avatar
Hoe big are the lips on xxr 521 18x10 +25???
Old 03-23-2011, 11:37 AM   #5208
tx240ss
tx240ss is an unknown quantity at this point
the 350z seats are really nice, has anyone tried them in a s13? I know its a dumb question, but when I seaarched seats and Zs, I got nothing..
tx240ss is offline   Reply With Quote
Old 03-23-2011, 12:48 PM   #5209
axiomatik
axiomatik's Avatar
yeah, people have installed them. IIRC, 3 out of the 4 mounting holes line up, you have to modify the mounting brackets to get the 4th hole to line up.
Old 03-23-2011, 01:30 PM   #5210
nothix
nothix's Avatar
nothix is an unknown quantity at this point
I think it requires more work then that.
I have a set in my hatch, but they were already "rigged" up when I bought them.
Previous owner attached stock s13 seat brackets to Z33 rails. Just needs to be lined up a little bit and welded together, then they should fit good.
The way mine are mounted, they dont slide far enough back.
'89 Sil80, SR20DET, GT2871r .64
nothix is offline   Reply With Quote
Old 03-23-2011, 01:31 PM   #5211
nothix
nothix's Avatar
What should my FPR be set at for this setup:
Walbro 255 lph, stock rail, 550cc injectors, nismo FPR
S13 SR Blacktop GT2871r .64
Old 03-23-2011, 02:22 PM   #5212
iRONDONkey
iRONDONkey is on a distinguished road
it will work.
you have to weld on the brackets from teh stock s13 seats onto the 350z seats.
Z33 Seats into a S-Chassis How-To : 240sx General Discussion
iRONDONkey is offline   Reply With Quote
Old 03-23-2011, 03:02 PM   #5213
obsolete
Anyone?
Also, anyone know where the ambient temp switch is mounted from factory?
Old 03-23-2011, 03:05 PM   #5214
codyace
codyace's Avatar
Trader Rating: (58)
Just evaluate what you need/don't need and clean it up yourself. You can hide or delete whatever you want.
They all will work the same for a street based car.
Ever try checking the see if the starter itself is good? What about putting a 1 1/16 socket on the crank, and spinning it over by hand?
You gotta get a little more proactive with the problem instead of searching online.
Yes.
If you're modding your car 'the cheapest' way, I'd suggest to not modify it at all until you can afford to do it right, or afford major parts in the event of a disaster.
Nuetal Safety Switch
Old 03-23-2011, 03:09 PM   #5215
codyace
codyace's Avatar
Trader Rating: (58)
Anyone?
Yes you will need to also take out the springs too.
This I don't.
Old 03-23-2011, 04:43 PM   #5216
S14DB
AFC #1
S14DB's Avatar
Hood latch support.
Old 03-23-2011, 05:28 PM   #5217
xnissan240sx
xnissan240sx is an unknown quantity at this point
Hey guys I want to wrap my interior tomorrow. I am doing the headliner, the door panels, glove box, and shift boot. I have the shift boot done and it looks awesome! Now my question is. How do I do the door panels? Meaning do I have to cut the panel out, and then glue it back in? Please if anyone has any information site or anything from personal experience please PM me about it!
Thanks a lot!!!
xnissan240sx is offline   Reply With Quote
Old 03-23-2011, 06:18 PM   #5218
TheQ
TheQ's Avatar
TheQ is an unknown quantity at this point
Exclamation
Hey guys I have a question and can't find anything anywhere on it so ill ask it here. I have a vlsd from a j30 but it did not come with a pumpkin. I am thinking of using my old open diff. pumpkin with j30 output flanges and j30/z32 axles. Do you guys see any problem with this? would the output shaft even fit onto the open diff pumpkin?
TheQ is offline   Reply With Quote
Old 03-23-2011, 06:27 PM   #5219
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
NOOB QUESTION
What happens if i dont run a boost and A/F gauge for awhile?
Im swapping to an SR btw.
jdmjap808 is offline   Reply With Quote
Old 03-23-2011, 06:50 PM   #5220
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Originally Posted by jdmjap808 View Post
NOOB QUESTION
Depends how far the car is modded, you should be fine cause it is just a "stock" swap. those cars came factory in japan with them and i dont believe they have a boost gauge stock there, and i KNOW they dont have a a/f gauge.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
