Old 05-01-2018, 01:45 AM   #5311
TheRealSy90
TheRealSy90's Avatar
IIRC the spl arm isn't as "bent" as others on the market.
Such a good signature.
Old 05-09-2018, 01:57 AM   #5312
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
^. If your ruca looks similar to this when it's on the ground, you're going to need to replace your RUCA with one that is angled.
Straight joint:
Angled/bent joint:
Try selling your current one if you can't return them and go with PBM rucas. https://store.partsshopmax.com/shop/...ct-description
instagram
1on1 is offline   Reply With Quote
Old 05-10-2018, 08:28 PM   #5313
relaxamigo
relaxamigo's Avatar
relaxamigo is an unknown quantity at this point
from last weekend
relaxamigo is offline   Reply With Quote
Old 05-11-2018, 08:55 PM   #5314
Bluejayde
Bluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond reputeBluejayde has a reputation beyond repute
Are there any other QUALITY arms out there with high clearance? I see SPL's RUCA is flat; Voodoo13 has some amount on theirs but doesn't say how much.
If I get drop knuckles will it eliminate the need for bent arms? Is having both "better"? I just have a low street car, no need for crazy angle or drift settings, I just want to be low and have suspension that works properly.
Bluejayde is offline   Reply With Quote
Old 05-12-2018, 12:21 PM   #5315
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
Yes even with drop knuckles u will still have this problem. The only thing that I have found to work is filp them from left to right and up side down. This is with any bent style arm. If u have sub frame risers they will make the arm contact even more, making u have to notch the frame pinch weld. It's just the way of the lo life
Bnr32gtr is offline   Reply With Quote
Old 05-12-2018, 12:43 PM   #5316
deolio
deolio's Avatar
i mean, it'll help... depends on how low the car is, but at that point it's cheaper to just get bent arms...
Old 05-12-2018, 01:29 PM   #5317
Bnr32gtr
It will help with the suspension geometry not at all with clearness on the ruca. I have pbm and gk rear drop knockles and have tryed every brand ruca other than the newest gk tech and pbm
Old 05-12-2018, 01:47 PM   #5318
deolio
deolio's Avatar
HUH? pbm is 25mm drop knuckle meaning at the same ride heigh, the outer mounting point of the arm is 25mm lower = more clearance. my ruca's used to hit when i had stock knuckles, but not anymore with drop knuckles. granted, my car barely tucked when i first did it. i'm sure if you're tucking like an inch you're gonna be fucked regardless.
Old 05-12-2018, 03:05 PM   #5319
Bnr32gtr
They move the hub Assembly. I had the exact same clearance with the pbm and the gk rear drop knouckles as the did with the stock knouckles.
Old 05-13-2018, 11:31 PM   #5320
deolio
deolio's Avatar
yeah, the hub assembly moves up, then you raise your coils an inch to put your car back at the same height... meaning the arms move down, become flatter, and should create more clearance. if that’s not what you experienced, i don’t know what to tell you...
Old 05-14-2018, 09:38 AM   #5321
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
TFW dude installed his bent RUCAs on the wrong side.
Old 05-20-2018, 07:00 AM   #5322
Bnr32gtr
I was under the car the other day. I flipped them for more axle clearance the arm kept making contact with the axle and tearing the boot.
Old 05-22-2018, 10:25 PM   #5323
1on1
1on1's Avatar
You don't need to flip rucas to get clearance. If they don't work for your preference, return them and go with a different brand.
I'm running pbm's old rucas (orange and when they were made inhouse) and I don't have any issues. In addition, I am running front shocks as rears and still have clearance.
The only other brand that has a gnarly bent/angle is 326power's shakotan ruca.
instagram
Old 05-23-2018, 08:36 AM   #5324
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Gk tech knuckles suck
jared420sx is offline   Reply With Quote
Old 05-23-2018, 09:36 AM   #5325
Bluejayde
What an informative post! Do you want us to beg you for more information, or were you planning on sharing your experiences in a future post?
Old 05-23-2018, 09:52 AM   #5326
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
I will guess this comment is because they don't have a camber curve.
Which sucks for great wheel fitment & functional driving.
Great for muscle cars though .. Lol
Jorgs_7 is offline   Reply With Quote
Old 05-23-2018, 03:12 PM   #5327
136baker
136baker is an unknown quantity at this point
if you aint tuckin you aint f*kin
136baker is offline   Reply With Quote
Old 05-23-2018, 03:21 PM   #5328
jared420sx
jared420sx's Avatar
Begging is always an accepted currency for information in my book.
And ive already shared them search ; )
But since im already here....
I had a fully adjustable rear end. I can list the build but its so much typing.
Anyways i was installing everything and they just wouldnt line up.
I also had to knotch them to even mount the hubs onto the knuckle.
All in all its a great example of really great idea poor execution.
Now i know they went through revisions and im not sure if they made new ones since i had my pair but the ones i had sucked. Big money for something that didnt even work. If i had to do it again i wouldve just went pbm through and through. Pbm is awesome stuff. And i know for a fact it was the knuckles fault because as soon as i put the stock ones on everything lined up perfectly.
Or you can do the spl monoball knuckle upgrade. Monoball for the win.
If anyone has any specific questions or anything on my setup i had feel free to pm. Not trying to clutter this thread
Old 05-23-2018, 03:36 PM   #5329
hrdprkin180
hrdprkin180's Avatar
hrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud ofhrdprkin180 has much to be proud of
Then you ain’t f**kin I guess. #notuckfoundsir
hrdprkin180 is offline   Reply With Quote
Old 05-23-2018, 11:31 PM   #5330
136baker
tucking tire at least! lol
Old 05-24-2018, 01:07 AM   #5331
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
[IMG]NOT_TUCKED_RIM.JPG[/IMG]
Smh try posting in the tucked tire thread ...
error 404 tuck not found
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 05-26-2018, 03:34 PM   #5332
Malik
Malik's Avatar
Malik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant future
Malik is offline   Reply With Quote
Old 05-29-2018, 11:45 AM   #5333
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
This generation's reading comprehension <<<<<
Old 05-29-2018, 12:14 PM   #5334
tacobellman_2007
tacobellman_2007's Avatar
tacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nicetacobellman_2007 is just really nice
I don't get it so do you only dry hump?
Amateur photography by me
tacobellman_2007 is offline   Reply With Quote
Old 05-29-2018, 04:50 PM   #5335
TheRealSy90
Sooo why did you post a pic of a car not tucking rim in the rim tuck thread?
Old 05-29-2018, 07:26 PM   #5336
R3b
R3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond repute
Hopefully going to be getting smaller tires up front soon, 215/35 should do the trick to tuck my 18s along with extended LCA. Then just need to drop the rear a bit more and take out the quarter panel dent from rolling the fenders. I need to figure out a new exhaust because the local "exhaust shop" keeps welding bushings to my subframe to tuck it and they keep breaking.... Just broke it for the 3rd time the other day and its not from scraping. Got my car tuned and made a nice 467whp and within 10 pulls on the way home the exhaust is already rattling.
R3b is offline   Reply With Quote
Old 05-29-2018, 08:09 PM   #5337
KevinEdgar
KevinEdgar's Avatar
Alright apparently this thread needs to renamed to “Almost Tucked Rim Thread.” I just don’t get what is so hard to understand...
If only this forum earned a dollar for every “but I’m almost tucking” post...
Old 05-30-2018, 12:00 AM   #5338
Malik
Malik's Avatar
not the biggest fan of this bumper but its ok.
Old 05-30-2018, 12:01 AM   #5339
Malik
Malik's Avatar
Old 05-30-2018, 01:30 AM   #5340
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
cause he's not fucking
turboshoebox is offline   Reply With Quote
