#5341 |
If anyone is interested I have a set of R35 570cc with 11mm hats to fit a JZ top feed rail for sale. I made 510whp & 462ftlbs at 23psi with them (stock ECU with AFC NEO). They plugged right up to my 2jzgte vvti harness. so for vvti engines they are practically drop in if you have a top feed rail.
price is $270 shipped for all six of them |
#5342 |
#5343 |
The stud issue is sort of normal for a top mount manifold. I think suprastore or a few places sell shorter studs. I would advise hitting up an ace hardware and getting something a little shorter for those bottom studs.
Sent from my SM-G900V using Tapatalk |
#5344 |
Was thinking maybe cut them or their some bolts in.
#5345 |
Ahh ok, so this is normal like was said above. I believe as another alternative you can call Curt@elmhurst and get some shorter OEM studs.
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#5347 | |
What's your setup? |
#5348 | |
![]() Join Date: Sep 2013
Borgwarner s360, driftmotion manifold, FIC fuel rail, 80lb siemen deka injectors, Aeromotive fpr, mac boost solenoid, megasquirt ms3x. I am fabbing the oil lines myself...I just got the adapters |
#5349 |
Honestly after looking at the picture of the manifold again. If the studs aren't touching I would remove all the other nuts pull the manifold back off some and slide those bottom nuts on first while you have the manifold pulled away from the head. You could grind a little material off them if they were touching.
This should give you the clearance to get them started. Sent from my SM-G900V using Tapatalk |
#5350 | |
#5351 |
2JZGTE Swapped S-Chassis thread
Got my Walbro 400 E85 pump, AN-8 outlet, and AN-6 inlet installed today. I will split to two AN-6 up to the rail after my AN-8 filter. This setup allowed me to keep the factory venturi to keep the tank evened out.
ImageUploadedByTapatalk1436124720.696645.jpgImageUploadedByTapatalk1436124735.694425.jpgImageUploadedByTapatalk1436124745.663585.jpgImageUploadedByTapatalk1436124756.161207.jpgImageUploadedByTapatalk1436124767.398743.jpg |
#5352 | |
#5353 | |
It's 8-AN split to 2 6-AN. I'm looking for 650ish. The -6 on the hat is for the return. I'm honestly not sure what it should be capable of. According to what I've been reading, I should be safe for a little more than I'm planning, even on E85. |
#5355 |
![]() a 2JZ VVTI we wired up in an Audi B5 S4. thought this a little different and extremely cool
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram ![]() |
#5356 |
Can some one please tell me what to do to the following ports ands how they might have blocked them off?
Coolant hose from the head to throttle body ![]() This and the remaining vacuum ports on the intake manifold ![]() Actually to make things simple what vacuums am I actually keeping on the intake manifold? Thanks in advance guys. |
#5357 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
DO NOT block off that rear feed from the head, it's needed to keep good circulation to the head.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#5358 |
This is common with any ebay manifold and some other name brands. I just cut the tip off and slid the manifold on while turning the nuts on. Mine has a exhaust leak. Wouldn't hurt to have the flange machined flat to be sure.
#5359 |
Yea, well it's in now ands hopefully all works out well
#5360 | |
Sorry for the multiple post, I'm at work and just skimming the thread lol
As for the vac lines (if single) you just need one for your fuel pressure regulator, MAP sensor, brake booster, and bov (if you have one)
#5361 | |
#5363 |
Please tell me I wasn't supposed to put rtv on the new usdm water pump for the 2J. When taking the old jdm one off it had no sign of old rtv on it and the FSM said nothing about rtv.
#5368 |
Hey guys, anyone have an IAT sensor for 1JZ? Would be part #89424-28010. Or where I could get it, local toyota dealership could not get them.
Also, what are you guys doing for powersteering into s-chassis? Looking to make my own but if there is a bolt in sort of kit, that you have tried and truly works let me know! Thanks all! |
#5369 |
![]() ![]() Mocking mine up right now too. Had same problem with the middle 2 exhaust studs. Will have to cut the ends off. Decided to go ahead and install arp's and new headgasket since I will be looking for more boost than my twins and stock injectors would allow me. This shit woulda been Hella easier when the engine went in the first time... |
#5370 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
I should have mine somewhere in the garage. I am going AEM and will be using their sensor. Sent from my iPad using Tapatalk
