#511 | |
![]() Join Date: Apr 2004
I saw a guy with an R33(I think) RB26DETT in his 240Z(sweet car), and he ate an N1 oil pump. I think he was turning 9k RPM, making about 700rwhp. Thing was as fast as Star Mazda around TWS - shame to see him leave. |
#512 |
![]() Join Date: Apr 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
IT'S BEEN A WEEK ALREADY!
Anything new?? I'm almost obsessing over this as much as the Transformers and GT5 threads. hahaha
Pignose, biaaatch. |
#513 |
![]() Join Date: Jul 2006
Nice I need to get a collar for mine still.
Not a vibrations problem really just a small contact patch so eventually it stops spinning the pump which shears the pump from the heat. |
#514 | |
in the meantime, istarted uploading content to: http://onyxsyndicate.com/Newman/ i've got about 50% of the posts up.
RB26DETT BMW E30 BUILD: onyxsyndicate.com/newman/e30gtr/e30gtr_00.html |
#517 |
Updated! (i know it goes back to page 06 when you click next. that's because the link says 60, but since it corrects errors, it goes to 06 instead)
http://www.onyxsyndicate.com/Newman/...e30gtr_59.html ![]()
#518 |
I guarantee you the temperature the crank/oil gears run at doesn't reduce their strength any measurable amount. If you're shearing things off a rotating assembly after some period of time, it is 99.999999% of the time a vibrations problem. The load of spinning the oil pump isn't that much, the load of an assembly vibrating around against another piece can spike quite high and cause fretting and eventually fatigue failure.
#519 | |
Inline 6 cylinders are very well balanced.
#521 | |
http://www.onyxsyndicate.com/Newman/...e30gtr_46.html
#522 | |
Ehh, like you say live and learn, cage is a little low, but long as you fit with some clearence for your head shouldn't be too bad, right?
#523 |
Driver seat will have plenty of head clearance, passenger seat had to be kind of high due to tunnel interference. Anyone taller than I am (5'-9") will run the risk of having their head close to the cage.
#526 | |
The crank twists back and forth like a tuning fork vibrates, which is why the factory puts on a harmonic damper(i.e. the crank pulley). Let me put it this way, you externally spin the engine to 8000 RPM and the oil pump gears won't feel much load at all. You start running the engine and the torsional vibrations in the crank will rise and fall according to the 2nd order mechanical response of the engine's rotating assembly. This vibration GREATLY loads things. Yes, the structural design of the gear probably isn't ideal, but the reason why it is failing is because it can't put up with the stresses it experiences due to torsional vibrations. It's probably easier to calm TVs on the crank than to make things strong enough to deal with an unfavorable vibrations environment. |
#527 |
![]() Join Date: Sep 2005
Ok, back to the build enough with the sidetracked torsional vibrations stuff. It sounds like an interesting topic but, start another tread about it. I bet other on here will have good info to contribute.
#529 |
![]() Join Date: Mar 2007
cool.
u gonna paint the interior in some wackydoodle way that nobody else has tried yet? I can just see you finding a way to make heat resistant plush velvet spray on floorpan coatings, or astroturf is always a good thing, lol.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold |
#532 |
that's such a good idea.
http://www.mimousa.com/cii-lite.asp
#534 |
i was in houston for the past 7 days for work, and i'm relocating again... long story.
but expect paint on the car in the next 2 weeks.
#538 |
![]() Join Date: May 2006
^^^ I believe he sold the Lotus for the Range Rover.
#540 |
progress slowed, had to strip down my sti transmission:
http://forums.nasioc.com/forums/show....php?t=1497692 ![]()
