#512 | |
![]() Join Date: Feb 2009
Is your starter shimmed? if so how much? thats kinda been my thing also. not sure if I can use the z32 na to tt shim or not. seems maybe its what im looking for. Starter Shim Plate
JUST A RED TOP SR |
#513 |
![]() Join Date: Oct 2011
wheels stayed on the ground, sparks flew out from the downpipe making contact with the ground. was at 80mph when it was put in first and dropped down to 42 in a split second. gave him slight wiplash.
#514 | |
![]() Join Date: Jan 2008
MunkyW3rkz Racing |
#517 |
Just out of curiousity, what rear ends are you guys running? I am worried that once my car is finished and I put some sticky tires out back that I am going to start snapping axles. My current set up is stock axles with a j30 diff. All input is welcome, thanks.
Sr22 in the works |
#519 | |
![]() Join Date: Feb 2003
I have a monetary switched wired to it, currently on the shifter. I plan on moving and rewiring the switch so I don't have to try to hold it down while shifting during a burnout. Plus I believe it was resetting my wideband, therefore fucking up my datalogs
S13 Fastback KA24DET - IG: @alonso240 AWS D17.1 Certified TIG welderIG |
#520 |
Does anyone on here have any experience with a q45 diff? I have been reading that they are pretty strong but the gear ratios kind of scare me. What would you guys recommend? My setup is mazworx 2.2 with a Borg Warner s366 and I am planning on making over 700whp and use drag radials. Thanks.
Sr22 in the works |
#523 |
Santos what do you reach full spool by (28-30psi) with your 6266? I went and did few logs tonight tuning and on pump 91 I'm hittin 11psi (lowest I can go) by 4700, which I'm figuring will put me in the 52-5300 range at 30psi.. Shud be even easier once I switch to e85 instead of c16.. At least I'm hopin. I'm really lovin this turbo so far, the wheels seem perfectly matched
#524 | |
on that 6266 what exhaust side your running. like ar and flange size?
JUST A RED TOP SR |
#525 |
#527 | |
yea i wish the 6266 had been out when i got my 6262. that way i would just put a t4divided .84 on it and have better spool and more mid range then the .63 t3
JUST A RED TOP SR |
#529 | |
Ya I was just goin to get a 6262 but he talked me into the 6466 and I couldn't be happier lol |
#530 | |
This was te 590whp pull ![]()
MunkyW3rkz Racing |
#533 | |
also, based on your dyno graph, what is the lowest AFR you ended up running? Last edited by blo0d; 10-10-2012 at 01:22 PM.. |
#534 |
Well me and some close friends have spoke about this several times they also have a SR Datsun that made 605whp stock sleeves similar set up to mine. we discussed is it the hp or psi that plays the factor. I have seen 650whp on stock sleeves also 37psi stock sleeves but tune and turbo size plas a factor.
On my current set up it seen 37 and 42psi spikes a few times when tuning and didn't show any bad signs so Ill see if there's hope later on Personally I will increase hp/psi until she blows. Lol Next on my to do list is a after to air Intercooler, q45 throttle body, sneak I will be making a intake manifold as well. With all that in i plan to push 35-40 is things look good but then I might have to upgrade my head studs we will have to see With a t76@28psi I lifted the head at 570whp on c16
MunkyW3rkz Racing |
#535 | |
I had asked about your AFR figures on your dyno sheet after. what was the lowest afr? the image doesnt show it. |
#536 | |
off memory i think the most rich we got was like 10:8 during ramp up and went to about 11:8-12:3@redline ![]()
MunkyW3rkz Racing |
#538 |
solid is the way to go but my current set up is still a bushing. if your bushings are shot then just replace with good poly ones or go solid if you dont mind a lil vibrating. Since my bushings are still good i havent swapped them out yet
MunkyW3rkz Racing |
#539 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
Well I do have a set of ES bushings but I have started contemplating solid in order to minimize wheel hop-->Axle/Trans/VLSD stress. I had been reading around about the vibration and extra noise that comes along with the upgrade so I wasnt sure if it would be absolutely necessary. But if it is then I dont mind spending the extra pesos and doing it right the first time.
#540 |
![]() Join Date: Sep 2011
![]() Feedback Score: 8 reviews
what injector sizes r u guys using and im trying to get 500 out of my forged block with gt35r and 9;1 comp pistons head studs etc.... think its possible with 91 pump octane and 750cc injectors or bigger injectors?
