#511 |
im lookin at some 17x9.75 +25 xxr 527s. i was talkin to someone that had them but he was extremly vauge with everything. that being said, im wondering how much fender work is going to have to be done to get everything to fit. and i gunna lose turning radius and shit in the front with that big of a wheel? he said they rubbed his coils so i know ill need spacers. no idea on what size. when i get them or whatever i get id like to lower the car a bit more. im ok with a stretched tire. i really would rather stay away from pulling my fenders that much.
current ride height: id like to go 1/2 inch to an inch lower maybe. ![]()
WTB: 1/24 scale chuki s13 model. |
#513 | |
Man w/ CTSV & a Car Seat
#516 | |
Just to give you an idea, 18x9.5 +14 with 13mm spacers 18x10.5 +1 rears on stock pulled fenders ![]() ![]() |
#517 | |
well thats pretty much what i wanted to hear lol ive got stances on it. any guess on tire size and camber id need to run so i could keep the body stock and not pulled? thanks for the reply!
#518 | |
Body. Even though I'd go with over fenders if I were you bc you'll need a huge pull. Good luck bro |
#519 | |
Personally, I dont like running staggered sizing tires on non-staggered width wheels. So its all up to you. Personally, I'd go 245/40-17 all around. Gives you the flexibility to rotate tires around and should fit under the stock fenders with just a roll and maybe a some camber. Heres a quick way to remember wheel sizings for S-chassis: 9J +10 fronts and 10J +10 rears. Perfect sizing for S-14s, need some camber and slight pull on S13s but looks awesome. |
#520 | ||
thanks for all the help so far guys i really appreciate it
#521 |
i have 17x9.75 isis coils used 7mm spacer up front didnt even have to roll the fenders just run some camber
IG=@gallo_915 |
#522 | |
#523 |
^ true statement i will be going w/ 225/45/17 as soon as i kill off these tires i have
IG=@gallo_915 |
#525 |
![]() Join Date: Nov 2009
![]() Feedback Score: 16 reviews
I have 17x9.5 with a +12 offset, will I be fine with a 5mm spacer in the front, I don't wanna pull the fenders. So just camber it and I should be fine right? Also I have eibach camber bolts and camber plates on my coils.
Sent from my SGH-T959V using Tapatalk |
#527 | |
![]() Join Date: Jan 2010
Trader Rating: (26)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 26 reviews
#528 | |
PM you wanna see more shots, I got a couple more with the setup. |
#530 | |
#531 |
Hopefuly this is the appropriate thread for this question.
How agressive can I go up front with out hitting the inner wheel wells and everything else while turning or anything (S13) I was lookin at x10 +15 but I think I still might need spacers and I'd prefer not to run spacers if I can get away with it. |
#532 | |
#533 | |
![]() Join Date: Oct 2003
![]() ![]() 18x9.5 +2 front R disk 18x10.5 +1 rear 0 disk camber was -3 front and -3 rear Stock metal at the time and pulled quite a bit all around rubbed pretty bad in the rear and it wasnt that low. Run 30mm fenders in rear and 20mm in front now tuck tire in rear. camber in front is at -5 and lots of clearance. Rear camber is at -2.75 and cant come out anymore as it will rub on the rear fender. If i did it over again 50mm in the rear and -1.5 camber then add a 10mm spacer or something |
#535 | |
Not only that, but on 17x10 +15, I was having issues clearing Zeal Coilover's. |
#537 | |
How much will camber effect clearence? Id like to get somewhere in the -5 or 6 range up front, by either slotting the coils or custom LCA's but Im not too sure how drastically I'll loose clearence. |
#538 |
Camber wont really do jack shit with the kind of issue's youd have clearance wise. S13 fronts just dont like that wide of wheels. You add camber to clear fenders, fender clearance would be the least of your worries with 10j up front. Full lock, you'll rub the crap out of the inside wheel well. You can beat the crap out of the front tubs but the back/firewall side is where it gets iffy, specially when you're super low. If the front tires touch the tubs/wall hard enough, might be enough to slow down the front wheels and cause you to spin out while drifting.
#539 | |
This one is a diamyo garage which is basically a Dmax rip off iirc. They were all the craze a few years ago then the dude making them started doin shady shit (other than copying products). Quote:
solution =tubs |
#540 |
Yes and No...tubs will only fix the front side of the wheel well but your tires will still touch the inside on the firewall side. Beating the crap out of that side and pulling the caster forward but thats another can of worms.
