#5461 | |
![]() Join Date: Sep 2006
+1 rep ![]() |
#5462 |
![]() Join Date: Aug 2007
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
Do the eBay 5 lug conversion hubs and Ichibas, etc. Use the same size wheel studs as OEM? Are the knurls size the same (14.3 front for S14s for instance)?
★ ★ GRANDMIGHTY.COM ★ ★ |
#5463 |
What size/thread pitch are the 3 exhaust side bolts on a Megan SR turbo elbow?
Feel dumb asking but dont have any extra bolts lying around to try and turbo/manifold/elbow are locked on the car already |
#5464 |
When replacing my power steering line, one of the wires on the sensor broke.
It broke at the base of the sensor, so its near impossible to reattach. what does this sensor do? Am i screwed with it off while road racing? I will be at the track so PLEASE text me answers. *** *** **** thanks eric castro Also, tried to take that sensor out of the tranny, for the speedo, and some gear oil came out so i put it back in, but only a little dixie cups worth. does that mean my tranny fluid is low?? (i unplugged the sensor further up the line) Last edited by ericcastro; 04-10-2011 at 05:34 AM.. |
#5465 |
![]() Join Date: Dec 2003
dunno if youll see this eric but you should be good with the tranny fluid. I was gonna tell you not to take the VSS out, just disconnect it. You should have a CEL and no speedo but it should work for your purposes.
Also all that sensor does on the PS line is kicks up the pump at idle. You should be fine without it.
![]() **CoUpe LOve** Member #00 |
#5467 | |
![]() Join Date: Feb 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
I'm under lifetime warranty for a single cam alternator with my last car. Will a sohc alternator work with a dohc ka?
SPLparts.com * PoweredByMax.net Quote:
#5468 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
I know this may be late, but don't remove it, you'll spew gear oil everywhere. Just unplug it. Good luck PS Sensor wise, it makes no difference.
#5469 |
Is the reverse switch on the tranny pole sensitive? I had to solder mine on there but the reverse lights won't switch on.
Also is the FSM wrong in the labeling of the Tranny switches? It says reverse switch is 1st from bellhousing, but I'm working on the 2nd from bellhousing, when I short this one (FSM says Top position switch) Reverse lights go on. Do they both work in tandem somehow? My 2nd s13 also has the 2nd switch from Bellhousing torn off and reverse doesn't work. Last edited by chingon; 04-10-2011 at 12:47 PM.. |
#5470 |
![]() Join Date: Aug 2005
does anyone know if this will work on KA?
HKS 27006-AN001 Shift Return Spring Kit SR20DET or point me in the direction where I can get one for the KA. This will probably fix my shifter going in circles while in gear, lol.
#5471 |
yeah the power steering sensor pretty much functions as nothing
street dancer. GLEAM |
#5472 | |
![]() Join Date: Feb 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
#5473 |
My 3rd brake light on my hatch went out. i replaced both bulbs with some sylvania 921 from the local part store and they wont light up. I tried two new sets. I checked the plugs and they are getting power, just seems bulbs wont turn on. Any ideas?
#5474 |
thanks for the info!
another, I plan on purchasing a mishimoto rad this week and still run the clutch fan. Question, would the 3-row cause problems or can I only use the 2-row?
#5476 |
![]() Join Date: Jan 2008
I have a 5 speed swapped convertible. I came across information that stated that it runs a bit more rich when the car is wired into park (to make the top work). Any input into this? I had a manual hatch back that on a trip from oregon to colorado got around 385 - 410 miles to the tank while the convertible only gets 330 max on the same trip and the engine in the convertible has significantly less miles than the hatch. Im wondering if having the car wired in park is affecting its MPG?
#5477 | |||||
Trader Rating: (58)
In regard to fixing the shifter going in circles, what sort of shifter kit do you have in it. Those springs really aren't going to make it 'wobble' less, they just work on the detent areas and control it coming back to center. Wobbly shifter usually is in the shifter itself. Quote:
You'll need an intake that is turbo specific, than an adapter to the maf. Quote:
-Being in park shouldn't cause the ECU to be in any particular mode, as you can run Auto ECU's in Manual Cars and vice versa. It'll throw a cod ebut not cause fuel consumption issues -Different engines may simply run differently. To get that much fuel difference, I'd be looking into your o2 sensors, especially when cruising.
#5478 | |
![]() Join Date: May 2003
Trader Rating: (43)
![]() Feedback Score: 43 reviews
#5479 |
Just ran a compression test on my KA24DE...not good (55, 105, 100, 50). I want to swap a KA24DE back in. What years do I need to look for? Or is it even worth it to do a head gasket job and check the block for warpage?
#5480 |
You can spend as much buying a used running engine as you can fixing yours.
However I doubt its your headgasket causing low comp, along with that you need to get your head pressured tested and new piston rings probably.
#5482 |
depends on your skill level and how much you would have to pay someone else to do.
I can rebuild a motor myself (anyone can) but I still have to pay for machine work. so i can keep costs down somewhat. but if you dont have the skills and have to pay someone else to do then thats a whole nother story. In all honesty rebuilding a KA to brand new specs is gonna cost at least $1k. If you just want to take someones word for it and slap their used motor in your car for 300 bux by all means do it. Just dont be surprised when that one starts to fail also. Also depends on if you can take the downtime to rebuild your current motor.
#5483 | |
#5484 |
So today I notice a weird sound coming from my back passenger side rotor and i look at it to see it looks like:
But my pad appear to be fine, I'm lost as to why its grinding the outside edge of the rotor. Any ideas? ![]()
#5485 |
![]() Join Date: Aug 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
Could be one of the clips that holds in the brake pads (aka brake retainers I believe). Check to make sure its not poking out and scratching the rotor.
2016 Nissan 370z |
#5486 |
I thought about that and I'll have to look but the wear is pretty severe. Seems like a clip wouldnt be able to cause it.
Open to any and all ideas so I go in prepared!
#5489 | |
The shim is the noise reducer on the back of pads, happened to mine except it wore down the center part
#5490 |
does anyone know what Ecu Code 33 is?
I googled and just a bunch of TPS sensors came up i think thats what it is, i have a yashio factory coupler type gauge that flashed E-33 today
