Old 12-20-2013, 02:32 PM   #5551
ka-titties
ka-titties is an unknown quantity at this point
those collectors are pretty trick.
ka-titties is offline   Reply With Quote
Old 12-21-2013, 10:53 PM   #5552
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
Just ordered the ahp alpha. Hopefully a decent first tig/welder. Welded couple things, exhausts, diffs, random bits with Lincoln mig, with no argon. Really shitty. Lol. Hopefully will use this alot more, with argon. Lol.
Pretty much bought it for future employment and finishing up my car.
Will add some pics when I get it up and running.
turbob16ef is offline   Reply With Quote
Old 12-21-2013, 11:02 PM   #5553
fabman97
fabman97 is an unknown quantity at this point
You welded with no shielding gas? I really hope nothing structural, I wouldn't want spongea holding my stuff together. But good luck with your ventures with tig welding.
Sent from my SPH-L710 using Tapatalk
fabman97 is offline   Reply With Quote
Old 12-22-2013, 05:33 AM   #5554
ka-titties
i really hope it was at the very least flux core.
Old 12-22-2013, 07:07 AM   #5555
blockedwizard
blockedwizard's Avatar
blockedwizard is an unknown quantity at this point
The ahp is an awesome machine, good features much better choice than the Eastwood or other comparable tig welders in that price range. If you can't get a miller or htp than the ahp is a good choice. I love the damn thing
blockedwizard is offline   Reply With Quote
Old 12-22-2013, 07:09 AM   #5556
blockedwizard
Originally Posted by tauntdevil View Post
Ill try sitting lower. Normally my table is pretty low so I am always way higher. Trying to save up to buy a nice welding table.
Heres some welds from a few nights ago.
1/16 tungsten
3/32 ER70s-2 filler
1 1/4" piping with .120 wall (easy to work with but its all I have currently because its normally the only piping I work with.
In this photo, there is some blue on the weld which caught me off guard. These photos were taken by the end of the day so a lot of times I was trying to figure out how I got the blue in the weld but couldn't replicate it. Couldn't find anything online either, there isn't much information online for tig welding without everything going off subject or covering a hint of something.
At the beginning of this one, forgot to turn on gas and started with too much angle on accident. Clumsy.
Looking good taunt!!!!!
Old 12-22-2013, 08:05 AM   #5557
turbob16ef
turbob16ef's Avatar
Yes was using fluxcore. But still was pretty shitty. And no nothing at all structural. Other than I guess the diff. I didn't use it that often and always just asked my neighbor to weld anything I was sketchy of. And I was just to cheap to buy/rent a tank of gas.
I have heard alot of good reviews with the alpha. And once it's in possession I will be taking my time with that and the mig. With gas.
Old 12-22-2013, 08:06 AM   #5558
blockedwizard
Yes gas is a must 100% argon for the tig
Old 12-22-2013, 09:36 AM   #5559
fabman97
Or argon/helium mix
Old 12-22-2013, 01:55 PM   #5560
turbob16ef
turbob16ef's Avatar
I know that. Was more just stating because of what I said with the mig.
Hopefully within the next couple days I will have some pics of my new project(s).
Old 12-22-2013, 02:03 PM   #5561
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
Originally Posted by McRussellPants View Post
Tungsten too small
Filler too big
using a filler thats too big will cause all sorts of issues. plus you can't get your tungsten close enough to get any good arc focus so your haz will be huge and zero penetration.
Like the idea of that Tee fitting on the wastegate tube, looks pretty good, wonder if it'll flow enough to keep that turbo in check.
I appreciate the tip. Very helpfull. Just had time to pick up 1/16 filler and seems to work out a lot better.
I appreciate it bud.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 12-24-2013, 02:57 PM   #5562
SlydeHo
SlydeHo's Avatar
SlydeHo is an unknown quantity at this point
I would appreciate some comments on this manifold, praise or criticism. It was not welded by me
SlydeHo is offline   Reply With Quote
Old 12-24-2013, 04:29 PM   #5563
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
I dont like the welds between each piping, but I am not a fabricator just an admirer of the work on this thread...
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 12-24-2013, 07:10 PM   #5564
Not You
Not You is an unknown quantity at this point
That almost looks worse then that 500pnd piece of shit sidewinder RB2X manifold that one guy made awhile back. If that answers your question.... Would love to see the inside of those runners. Prolly looks like a coral reef.
Not You is offline   Reply With Quote
Old 12-25-2013, 03:20 AM   #5565
aga
aga's Avatar
aga is an unknown quantity at this point
i also am not a welder, but i gotta ask the knowledgable people in this thread, welding along the runners like that doesnt it make it prone to cracking?
My Build
aga is offline   Reply With Quote
Old 12-25-2013, 10:23 AM   #5566
ultimateforce
ultimateforce's Avatar
ultimateforce is an unknown quantity at this point
It makes it prone to being a piece of junk.
Assistant Fabrication Manager / Welder at Raw Brokerage
ultimateforce is offline   Reply With Quote
Old 12-25-2013, 04:17 PM   #5567
McRussellPants
What a mess
also lol at that egt bung on number one.
McRussellPants is offline   Reply With Quote
Old 12-25-2013, 05:29 PM   #5568
ultimateforce
I think that would be number 6, which on RBs is the cylinder that goes lean and gets the hottest.
Edit: Just another reason why V8s are better.
Old 12-25-2013, 07:55 PM   #5569
McRussellPants
That's a bottom mount? Wastegate top punching a hole through the hood. Haha.
Old 12-25-2013, 08:02 PM   #5570
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
The welds along each runner are what scare me the most there. Yikes!
Old 12-29-2013, 12:11 PM   #5571
Slims
Slims's Avatar
Slims is an unknown quantity at this point
Hey guys, i have a project going and wanted a little advice from a seasoned fabricator.
below is a new frame rails i sectioned in and im looking to support the joints. Fishplates were my only idea, but since all of the joints are at a bend im not sure if it will provide it with adequate support. I've also seen debates on which surface the plates would provide the most support (top/bott-sides) i always assumed the sides were the general rule. the only reason i bring this up is because the only good, somewhat straight joint surface i have are on the top and bottom. thanks for the input.
Slims is offline   Reply With Quote
Old 01-15-2014, 07:50 PM   #5572
ultimateforce
Just some dump tubes for our turbo kits we make in-house. Nothin' special.
Old 01-16-2014, 01:30 PM   #5573
ka-titties
das purty.
how do you do such a long weld on a pipe like that without stopping?
Old 01-16-2014, 02:03 PM   #5574
unwtdhero
unwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-known
Rotating table^
unwtdhero is offline   Reply With Quote
Old 01-16-2014, 02:17 PM   #5575
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
runners are all supposed to be equal in length. That's why they have to be bent and curve all "snaked" around each other for the single reason of all the runner being equal to one anothers length. Those welds along each runner has heat hardened the steel as well and will result in it being brittle which is prone to cracking like someone previously said above. Only car I know of top of my head that doesn't have equal length headers is are subaru's boxer engines. Honestly idk why they aren't equal and i don't know why they would want so much turbulence in the exhaust flow. Must be something to do with those flatties.
VinceDude is offline   Reply With Quote
Old 01-16-2014, 04:20 PM   #5576
pablito_s13
pablito_s13's Avatar
pablito_s13 is an unknown quantity at this point
Who is down to build this full wrap around drift bash bar ??
pablito_s13 is offline   Reply With Quote
Old 01-16-2014, 04:34 PM   #5577
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
Originally Posted by VinceDude View Post
runners are all supposed to be equal in length. . Only car I know of top of my head that doesn't have equal length headers is are subaru's boxer engines. Honestly idk why they aren't equal and i don't know why they would want so much turbulence in the exhaust flow. Must be something to do with those flatties.
Sounds like you don't know much in general, most stock manifolds are not equal length, SR20/Evo4G63/DSM4G63/SRT4 manifolds are all unequal length and tend to produce more TQ down low than equal length manifolds. Even a number of aftermarket manifolds are not equal length, such as the Tomei SR20 and KA24 manifolds.
hobbs is offline   Reply With Quote
Old 01-16-2014, 07:36 PM   #5578
ultimateforce
Originally Posted by unwtdhero View Post
Rotating table^
Something like that yeah. It's mounted on a bolt so it screws down as it goes. Quick and easy.
Old 01-16-2014, 07:59 PM   #5579
kingston240
kingston240's Avatar
kingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond repute
Cool idea.
I will likely use that!
www.facebook.com/HellaFab
kingston240 is offline   Reply With Quote
Old 01-16-2014, 08:08 PM   #5580
tauntdevil
tauntdevil's Avatar
If you have a spare house fan, put a controller in between the wires and a plug, then place a plate on the top of it so you can control the speed it spins at and weld on it.
