10-01-2015, 06:44 PM | #5581 |
10-02-2015, 08:58 PM | #5582 |
Hey guys wondering if someone had any experience with this,so i just did a compression test on the 2jz vvti engine that arrived at my house and all the cylinders were fine reading 145-150 psi except for cylinder #5. When i first took off the coil for cylinder 5 i noticed there was oil pooled up inside and with the spark plug still in place but no evidence of a leak from the valve covers or anything around it so I that worried me a bit. So when i did the compression on cylinder #5 the reading was 100 psi
I went ahead and dropped some oil into the cylinder and than the reading jumped to 180-200psi. Does that mean the piston ring is bad?I got about 10 days to return it so just wondering i should do a leak down test or stop any testing now and just take it back for an exchange or money back. Thanks guys |
10-03-2015, 07:30 PM | #5583 |
So I have a little dilemma .
I have 3/4-distance from the water pump pulley to the radiator and my intake inter cooler coupling just fits when I trim it as much as I can while still retaining a (90°) angle. Is anyone familiar with the z rad support ?I do have the condenser still in there since I want to run ac, but would like to gain an inch or so. Anyways here's pics. Also what's the slimmest 4"intake filter available? |
10-03-2015, 09:05 PM | #5584 |
Sent from my SM-G900V using Tapatalk
"I thought what i'd do is i'd pretend i was one of those deaf-mutes" |
10-04-2015, 07:49 PM | #5585 |
Hey guys , got another question . What have you guys been doing for the throttle cable. Can you use the stock cable and stock cable bracket ? Pics would help too thanks.
10-04-2015, 07:52 PM | #5586 |
10-05-2015, 09:47 AM | #5587 |
Not sure if you found one yet, but I have seen this one before in my searches on summit before, pretty cheap too http://m.summitracing.com/parts/spe-8161 Also I agree with everyone else, shorten the throttle body and get rid of the trac unit
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
10-05-2015, 09:51 AM | #5588 | |
10-05-2015, 09:53 AM | #5589 |
Also speaking of throttle body cables, I have my old one for sale now that I am on true DBW. Nothing wrong with it, perfect length.
Fits S14 with VVTi GTE Stock S14 gas pedal Shortened throttle body cable to perfect length CX Throttle bracket for VVTi $60 shipped/PayPal'd PM me for more info
10-05-2015, 05:56 PM | #5590 | |
Custom catch can, going to fit perfectly |
10-07-2015, 06:32 PM | #5597 |
I only use mobile so I can't load pics of my build 2jzgte s14.I have it all on my Instagram
It's Rick_s14. I would like to see what other people are doing build wise. so If you have a Instagram let me know. |
10-07-2015, 10:20 PM | #5598 | |
im looking to buy a intake manifold like this was looking at the ebay one. any info like fitment and is there any modding needed for this to work in the car like custom throttle cable adptor like the sr20det intake manifold? also can I get some info on that chrome piping for the upper water neck that connects to the rad? any info at all will be great guys thanks!! Last edited by BadazzSr20; 10-07-2015 at 11:13 PM.. |
10-08-2015, 06:17 AM | #5599 |
[QUOTE=Reddrum13;5953776]Just want to chime in and recommend Lucas at Dukefab. He is awesome and makes quality stuff. I have his catch can on my S14.
[/QUOTE Looks sick man.just out of curiosity, how did you get the water neck on the driver side of the motor? |
10-08-2015, 07:27 AM | #5601 |
10-08-2015, 08:32 AM | #5603 |
10-08-2015, 05:08 PM | #5607 |
I haven't driven mine in almost 2 months. Somehow the cylinder 3 ringland gave up causing me to lose compression. Swapped my gsc s2 cams out, put in the stock cams, tried starting and just kept cranking. Prob washed out the walls.
Was putting the car back to stock to sell it and then it does this to me lol. Will prob part it out or sell as is, even though it's somewhat apart.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
10-08-2015, 05:47 PM | #5608 | |
Why do you want to sell it? Stick with it and get it running good.
10-08-2015, 07:31 PM | #5609 |
Just lost interest and taking priorities right now (paying down loan and going back to school). Trying to increase my yearly pay and may relocate to a different state. Would like to start over when the time is right and do things differently.
10-09-2015, 02:01 PM | #5610 |
Power steering reservoir hose
Hi guys, thought I'd post some helpful info about the power steering reservoir hose needed to hook up your power steering with a VVTI 2jzgte.
Some people use any hose for this, but you should only use the proper type rubber hose rated for power steering fluid. You dont want the wrong type rubber breaking down and possibly ruining your P/S pump and steering rack. Parts required: 1 Gates 350030 Power Steering Reservoir Line Hose - Cut To Fit. This is 5/8" hose and is the right size. 2-3 barbed 90 degree brass elbows ( I only needed 2 elbows for the hose routing I chose ) 1 box of Breeze Stainless Steel hose clamps Made in USA You need the elbows because the straight hose will pinch. I bought 3 elbows for more flexibility in how I run the hose, but 2 elbows may be enough. If anyone knows of a pre bent power steering reservoir hose that fits this setup please let me know because less failure points is always a good thing! Last edited by rswails; 10-14-2015 at 11:15 AM.. |
