Old 09-02-2020, 07:17 PM   #541
S14rebuild
Just asking cause in the pic poormans posted theres a headgasket betwwen the torque plate and block....
Old 09-03-2020, 05:45 AM   #542
PoorMans180SX
PoorMans180SX's Avatar
Originally Posted by S14rebuild View Post
Edit... any concern with reusing the headgasket since its already been torqued down on durning the boring/hone process?
That is an old headgasket. I definitely wouldn't re-use a stopper-type gasket.
Old 09-03-2020, 09:41 AM   #543
S14rebuild
True, kinda was expecting that answer.....
Nothing beats minty fresh machine work
Old 09-04-2020, 07:31 AM   #544
PoorMans180SX
Old 09-04-2020, 08:10 AM   #545
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
I second that. Minty fresh machine work and clean engine bits are always a treat to look at, ha
IIIXziuR is offline   Reply With Quote
Old 09-08-2020, 05:38 AM   #546
PoorMans180SX
Well I finished with the gold tape on the exhaust side. Started with DEI but bought some non-branded stuff on Amazon, hopefully it holds up. Seems quite similar.
Haven't gotten my THL crossmember, so I decided to just put it back together with the GKteck rack forward bushings for now. I don't want to wait to put the engine in. If it comes in the meantime well... That's life.
Fitment is on point, obviously need to mount the fenders and fine tune, and the front needs to come down two fingers.
I also need to get the inner tie rods in so I can see if this is realistic.
And what I'm going to have to do with the lock stops to keep the wheel off the LCA
Old 09-08-2020, 08:34 AM   #547
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
I used the non branded Amazon stuff and.......wasn't impressed
Old 09-08-2020, 08:39 AM   #548
PoorMans180SX
Lol, great! I was hoping it was a case of the same factory kinda thing... I could tell it wasn't by the different backing but... Should have just shelled out the cash
Old 09-08-2020, 10:08 AM   #549
RalliartRsX
Trader Rating: (32)
These cars already have shit all for insulation, so yeah. Shell out the bucks. Fatigue and heat related failures due to turbo heat is a real issue on any turbo track cars.
A similar situation saw a weekend go up in smoke at VIR a few months ago. Got like 10 laps total for the entire 2 day weekend because of inadequate heat management.....
Yeah, I have learned my lesson
Old 09-08-2020, 11:03 AM   #550
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
Looking good!
I had to switch over to the GKtech FLCA's because i had that same issue with the wheel contacting the lca.
Krusty_s13 is offline   Reply With Quote
Old 09-10-2020, 10:53 AM   #551
PoorMans180SX
UGHHH, now I'm seriously considering tearing it all off and redoing it haha. Just read about how the cheap stuff is basically party balloon foil . Might just get some of the heavier duty barrier stuff that has some thickness to it at this point. Do it once, do it right kids...fml hahaha.
Originally Posted by Krusty_s13 View Post
Looking good!
Yeahhhhh, I'm highly considering this. I was really trying not to "space ship" this build, but here I am...
In other news I'm picking up the block and head today!
Old 09-21-2020, 08:13 AM   #552
PoorMans180SX
Got the engine back from the machine shop last week. A couple of minor things up with the block, but nothing that should really affect performance at the power levels I'm looking to make. I need to take some pictures when I get to work on it today. Line hone has a nice scrape in it though, luckily it's a low spot and shouldn't affect bearing clearances when it's assembled.
Also discovered that a few of my head and main studs were stretched, probably because the previous engine builder had zero idea what he was doing. The headstuds were the old 8470 VW kit. While some stretch is okay on an ARP stud, I've decided to replace them with Mazworx studs due to the superior design and ARP2000 material. Even after the hot tank I had to rifle brush and blow out the main and head stud holes to get the ARP moly lube out of them :rollseyes:
Ordered a cleaning tap for the head stud/main stud holes and some other odds and ends, but I'll be chasing every hole in the block. This thing will be put together correctly!
Crossmember from THL supposedly shipped out today. I guess it's going to be four or more weeks until the fender braces are done. Still waiting on the turbo as well for some reason. This project has definitely stretched well beyond the original scope and timeline. I need to go drive!
I've been trying to get this Evo X wiring project done so I can concentrate on my car more, here's some shots.
Lots of tidying up to do in here. Don't ask me why he has the fuel tank in the passenger seat, IDK.
Old 09-23-2020, 05:31 AM   #553
PoorMans180SX
I guess it's harder to see in these pics than I thought, but here's my attempt at capturing the stretched studs and thread damage on camera. Anyone interested in a "how to assemble an SR20" write-up or video?
Looks like the Mazworx studs will be here on Friday. Have a few other things showing up this week too .
Old 09-23-2020, 10:34 AM   #554
TheRealSy90
TheRealSy90's Avatar
Wouldn't you want to use new studs when doing the torque plate and when assembling the engine? I'm on the fence myself currently over doing a headgasket and arp head studs on my sr that i'm prepping. I don't want to worry about pulling the block threads out lol. The gasket is fine but I suspect there's an oil leak at the front cover
Such a good signature.
Old 09-23-2020, 10:45 AM   #555
PoorMans180SX
Ideally yes, but as long as the studs torqued to the proper value then nothing should change dimension wise. I didn't know they were stretched (I've actually never seen it happen) until I went to re-assemble it. I guess that's what happens when you put ARP lube on both ends of the stud like a dunce. Honestly they'd probably torque fine again, I'm just wary of putting them in this rather expensive engine.
I've never seen someone pull the threads out of a block unless they installed things wrong.
There is definitely a bunch of junk in the bottom of the head stud holes I need to clean out (I'll try and get a pic). I have a tap coming to make sure the threads are nice and clean as well. The devil is in the details.
Old 09-23-2020, 11:18 AM   #556
TheRealSy90
I could have swore the ARP instructions said to put lube on the block-end of the threads also. Its been years since I last installed ARP head studs for someone. Albeit there were no issues it all went fine.
Old 09-23-2020, 11:50 AM   #557
S14rebuild
how many stretched? And was that pics of the headstuds, cause i know on my mains, beleve it was 2 or 3 were shorted, to clear the rwd oil pan...glad i checked instructions and saw that..
Old 09-23-2020, 11:59 AM   #558
PoorMans180SX
Negative. No lubrication on the block side. You can loctite them in if you want a permanent install hah.
https://tech.arp-bolts.com/instructions/102-4701.pdf
Two of the mains are much shorter than the others hah. Looks like two or more headstuds stretched (They are all at different levels in the block). Looks like 3 mains stretched. The pictures are of both.
Also, if you put main studs in your block, you need to align hone your crank main bore. Mine were .002" out vertically.
Old 09-23-2020, 01:40 PM   #559
S14rebuild
Was just checking...
Correct had mine lined honed with arp studs. Motors almost back together, turns over perfectly... super excited
Old 09-23-2020, 07:20 PM   #560
TheRealSy90
So i'm just trying to educate myself here. If you install ARP fasteners, the "correct way" is to install them using a stretch gauge, right? So they are supposed to stretch a specific amount. If you do that and then align hone it to set the mains, since the studs already stretched aren't those studs then no good to use for assembling the engine? And you'd have to use another set of new studs and stretch-gauge them again.
Old 09-23-2020, 10:12 PM   #561
PoorMans180SX
You can?t accurately use a stretch gauge on studs. Also, they?re elastic. The goal is to stretch them the right amount so you don?t permanently deform them.
Old 09-25-2020, 05:37 AM   #562
PoorMans180SX
These came in yesterday:
Old 09-25-2020, 09:00 AM   #563
TheRealSy90
They're a really great arm. I just haven't figured out how I want mine adjusted. And having to rearrange the shims on either side of the heim to make significant castor adjutsment is kind of a pain.
Old 09-25-2020, 09:47 AM   #564
PoorMans180SX
Yeah my good friend Joe had them on his car. It's definitely a pain, but I'm kind of a "set it and forget it" kind of guy with things like this. I'll probably shoot for 5-6* of caster and be done with it. Looks like my crossmember should be here in a week or so, so that'll be cool to setup.
Old 09-25-2020, 07:19 PM   #565
koukis13
koukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the rough
Duuuude, your building a beast!
koukis13 is offline   Reply With Quote
Old 09-28-2020, 05:04 AM   #566
PoorMans180SX
Got the new studs in on Friday and measured bearing clearances on Saturday. I got King racing bearings with .001" extra clearance, which turns out was not necessary on the mains. They were at .003" which is a bit big for my liking. So I'll be getting some normal bearings which will bring them down to .002" which is pretty golden. The rods are at .0022-.0025" which is right where I want them. This thing will always have 5w50 in it, so that extra cushion should provide some margin of safety.
One thing I did, which I would not recommend, is running a tap down through the headstud holes. I couldn't find a thread cleaner long enough anywhere, and after doing some reading, it seemed like it wasn't a big deal to run a tap down them. Maybe I should have used some tapping lubricant or something, but now I feel like I should have just rifle-brushed them out. Anyway, the result is that the studs have a very small amount of wobble when threaded all the way in now, which I don't like, but I'm just going to assemble and send it.
The mains weren't an issue since the thread cleaner I had was long enough.
And just some of the little detail work I've done radiusing or chamfering the oil drains and such.
Also took the dremel to the rough casting area at the water pump inlet.
Old 09-28-2020, 07:09 AM   #567
RalliartRsX
Trader Rating: (32)
There is so much core shift in the SR block it's rediculous. I could almost peel off some of the "slag" from the casting process just in the head alone
Old 09-28-2020, 01:45 PM   #568
S14rebuild
Hope those studs hold for u..... what u gonna torque them to, using the new evo washers?
Old 09-28-2020, 01:49 PM   #569
RalliartRsX
Trader Rating: (32)
^^ Should be anywhere above 80 ft lbs (if using the proper assembly lube)
Old 09-28-2020, 05:23 PM   #570
S14rebuild
i ran 85ft lbs..didnt know with the wider evo washers, but seemd to of worked.... been slackn off motor should be in the car by this weekend, running shortly after if i can figure out the power fc initial setup
