#31 |
Ill be contacting The driveshaft shop for some beefed up hybrid axles, corvette inner and s13 outers
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 |
#32 |
The plan is ducatti 999r throttle bodies with cnc machined intake flanges and custom runners. talked to one of my coworkers a bit and he suggested 3d printing. So im going to look into that as well. Not sure how comfortable i feel casting my own metal in my garage. Casting seems much more techincal and precise vs the 3d printing.
#33 |
If your interested in casting aluminum, watch myfordboy on youtube. He does a ton of aluminum casting and also some machining. He usually is thorough on his video's and also answers a lot of questions in his comments.
Have you thought of machining instead of casting? Im sure if you design the file and go to a shop with a 5 axis CNC mill they could easily take care of this and have high tolerances. |
#34 | |
#35 | |
If your looking for quality and something repeatable with high precision then machining would be the way to go IMO. If your looking for "cheap" customization then its all about 3D printing it. Personally though, I would not have anything 3D printed in my engine bay unless it was your standard clips and things. |
#37 | |
Thanks!
#38 |
![]() Join Date: Jan 2010
Awesome build! Definitely never seen anyone do something this intensive to a 240 before haha. There wont be much of the car left when you're finished! Just one question, why did you go with an iron block? Seems like you're putting in an awful lot of work in terms of optimum weight distribution to go with this option.
Sent from my iPad using Tapatalk
#39 |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
I subscribed right when I read "180 header". I've been waiting for someone to do a 180 header LS swap. Only way I'd do an LS swap is a high revving 4.8 and either 180 headers or an 8-1 collector setup.
If I may make a recommendation, Villains makes solid steering rack mounts that will save you from the heavy factory mounts and brackets, and you can weld them wherever you want. http://villainsdrift.bigcartel.com/p...relocation-kit ![]() |
#40 | ||
PS Just checked out those steering raack mounts and def going to order a set. Cheaper than the solid bushings i was going to get, les cubersome to mount on the subframe, and as you said less weight. Thanks again for showing me those.
#41 |
Yeah that's what I meant to imply, you save on having to buy bushings and these could be more easily welded wherever you want them it seems. Hope they work out for you!
Sent from my iPhone using Tapatalk |
#42 |
Got home from a weekend getaway down in New Orleans, think i almost went broke on food, and id been perfectly happy if i had.
Ok, so enough about the food. Started cutting up the front subframe to allow the motor to sit a bit lower. Before i could measure for notching the subframe, i had to remove the factory corvette shifter mounts. They were hitting the trans tunnel and not allowing me to get the trans setup to sit where i wanted it to. I also removed the front suspension as it was getting in the way with measuring and what not. ![]() ![]() ![]() With everything out of the way i cut off the flange that jutted out from the subframe that the steering rack mounted it. I decided to not use the standard mounting brackets and ordered a set of Villains drift solid mounts, which are weld on replacements. This allows me to have free reign of where I'm going to mount the rack. The rack will be moved forward, forward, and to the lt side compared to factory location. ![]() ![]() ![]() With the subframe notched i was able to see how low i could get the motor and how the rear diff would sit, after some more minor trimming of the rear subframe. If i had to guess id say the motor is proly sitting close to 2'' lower than a typical ls swapped s13. ![]() ![]() ![]() ![]() Bad news with motor sitting so low i ran in a bit of a problem. The bell housing is sitting an 1" below the framerails. To remedy this i need to get a flywheel and see how low it sits in comparison to the bell housing so i can see how much i can chop off of it. Also thew in my make shift strut brace to see how much room i had gained. Should have plenty of clearance to build the its now. ![]() ![]() ![]() ![]() Also threw up a piece of piping to check exhaust clearance, driver side, GREAT, passenger side, not so much, some clearancing will be required for sure. ![]() ![]() With the motor sitting about where i wanted it to, i realized this thing is going to look like it will be sitting on the ground once its at ride height. ![]() ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:40 AM.. |
#44 |
![]() Join Date: Apr 2010
Not sure if its been cover yet but your subframe bushings are in wrong. Id hate for you to get everything lined up and the rear be 3/4" to an 1" off. Just a heads up
#45 |
Yeah im going to flip them, just havent done it yet. Will be soon tho as i need it at the correct height to weld on the the trans mount brace. Thanks tho.
#46 |
Don't think ive logged on in 2 1/2 years... This was a nice build to come "home" to..
Trade my Rb25 for some wheels. Buy my Sc300. Last edited by josephin510; 02-02-2016 at 01:24 AM.. |
#47 |
#48 |
Small update. I FINALLY BOUGHT A WELDER. Now thats out of my system. Finally bought a welder after wanting one for so long. Been using the one at the shop for small projects here and there. But not having one here at home as really hampered me and what i could do.
Also picked up a few other things. Saw someone else using this speed blaster, and figured i could def use that on my car, anxious to try it out and see how it does! Also picked up a drill press and a belt sander. Anyone knows, if you have tried drilling through anything thicker than a thin body panel with a drill, its a major, slow, pain in the fucking ass. Also got some ITB's in. They are Ducati 999R items. If your not familiar with ducatis, they are 2 cylider motors. Basically what that means for these its is that they are larger than the 4 cylinder bike its such as gsxr and hayabusa's which are in the 46-48mm range where these from the ducati are 52mm. Still need to order 3 more pairs for a full set, but i just ordered this first set for mock up and test fitting. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Also got some ITB's in. They are Ducati 999R items. If your not familiar with ducatis, they are 2 cylider motors. Basically what that means for these its is that they are larger than the 4 cylinder bike its such as gsxr and hayabusa's which are in the 46-48mm range where these from the ducati are 52mm. Still need to order 3 more pairs for a full set, but i just ordered this first set for mock up and test fitting. ![]() ![]()
#51 |
Speaking of itbs, ive been doing alot of thinking on how i want to make them. Thought about making them cross each other and what not like the jenvey and kinsler setups, but that seems extremely difficult and is much more common route on LS motors. So i think i am going to do the vertical ibs like the link below. With how low the motor is i think i will have plenty room. Need to find a cheap s13 hood to throw on and check and see how much room there actually will be under there.
http://i.ytimg.com/vi/Ba8sT2BQ4uc/hqdefault.jpg
#56 |
Just now seeing this. Thanks!
#57 | |
Thanks guys!
#58 |
So, seeing as i had the day off today, i piddled in the garage a bit. Had a buddy come over and help wire in a few new plugs. Needed a 220v of course for the welder, and also added a standard 110v plug on this wall. For whatever reason when the house was built there wasn't a plug put on the far side wall of the garage. Anyway, got that wired up and working good, just need a bottle of gas now and I'm ready to start the fab work. I also mounted some hooks so that i could store metal tubing and other materials on the wall, as well as taking down my subaru flag and hanging a few things I've had lying around for a while.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Currently the front end is surround by stuff while I've been busy the last week or so :/ need to change that asap. Still have yet to pick up a daily. Hopefully once that happens ill get back into my routine and get some parts ordered, start some fab work, and get the ball rolling. In the meantime, i decided to clean up the wheels a bit so that i could remove the faces in an effort to be able to sell the barrels and make some more space in the garage. Anyone want some lmgt2 barrels?? It was a pretty day today so the wife and pup joined me outside. He loves the hose.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() It got a bit chilly and windy after the sun went down so i resorted to closing the door and doing what i could inside. Decided to start planning out the front tube work and how i wanted to do it. Not sure how feasible my ideas are but that is what I'm leaning towards. Still need to order the front body work to mock up before the first cuts made, which should be very soon. Also received my new steering rack mounts from Villains. Need to mock those up and see what needs to be trimmed and cut to make them fit my modified steering rack ![]() ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:41 AM.. |
#59 |
So last night i did a bit on pondering on the front end air management. Since i had made the decison to run the itbs verticaly through the hood, i was wondering what i would do with the top opening in the rocket bunny front bumper which ill be running. The oroginal plan was for the itbs to do the traditional criss cross and the trumpets over the valve covers, being fed air from that top opening on the bumper i just mentioned by making a divider to plit the air side to side. Downside to that was more air in the engine bay and more importantly the intake sucking in super heated air that resides in the engine bay.
I want to keep that center upper opening as if i were to blank it off i think it would be too plain. So i came up with the idea to channel the air through the center hood vent and make it swirl with the air coming from the radiator to help cool it off a bit before getting sucked into the itbs. Its still warmer than ambient air, but its the lesser evil compared to the super heated air of the engine bay. Excuse the crude paint drawings ![]() ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:42 AM.. |
