#31 | |
![]() Join Date: Mar 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
#32 | |
![]() Join Date: Jan 2003
#33 |
Right. FIA is an international race sanctioning body which creates regulations and safety standards particularly for race series which span many nations, e.g. F1, WTCC, and WRC. They can also offer approval of a company's manufacturing process for safety equipment, e.g. welding, materials, etc. Since one particular rollbar will obviously not be approved for every kind of race out there, you'd need to contact Cusco for specific questions regarding whether a particular cage meets criteria for a particular racing series, whether FIA-certified or not. Obviously, for higher-level professional racing a pre-manufactured bolt-in cage will not pass muster regardless of who makes it.
SCCA and NASA on the other hand are local (i.e. US) autosports business-clubs. They put on club-level (amateur) solo and racing events, and they are not under the auspices of the FIA nor are they required to follow its guidelines. They have created their own safety regulations for their events, and that's why they can turn up their nose at anything that doesn't follow their criteria including rollcages and even vehicles produced in other countries. IMHO, the U.S. just likes to do things its own way in spite of what's going on in the rest of the world (see: metric system, Kyoto accord, U.N. resolutions, KA24, NASCAR, etc). |
#36 |
read this http://www.cusco.co.jp/english/e_cont.html dont say anywhere fia cert
#39 | |
Anyways to clarify, I wasn't trying to say "all Cusco cages are FIA certified." FIA doesn't slap their sticker on pre-manufactured cages. It doesn't work that way. But Cusco follows a lot of the common standards required by FIA and JAF, so contacting them would tell you which might meet requirements for a particular race (e.g. Safety21 works type may be a good candidate for N1/N2 enduro, etc). Just PM me if you want to keep arguing. It's obvious nobody here agrees with you or wants to keep hearing about this topic. |
#40 | |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
off the top fo my head the worst welding ever horrible door bar (too high cut out the door which didndt hvae to do) blew out his rear speakers (welding debree/sparks whatever) worst welds wrong piping iirc and bad bends overall a total pos. we'll rip it out and redo it later mine is going in this coming week thru garage works 6 point side beams and thru the dash on the front points. |
#41 |
![]() Join Date: Apr 2004
You may want to keep in mind that for best results, the cage needs to come as close to the body as possible. That means you have to strip the interior or run a little gap between the body and the cage (which isn't ideal but is still doable).
Also keep in mind that ideally the main hoop will run as close to the B-pillar as possible. This means that you will lose your stock 3-point seatbelt. You can keep your 3-point but the main hoop won't be ideal if there is a little gap. Not a big deal really if you have run harnesses, but it's going to bump up the price a little bit if you want the best design. And ideally weld-in is much better than bolt-in. Plus it's really important to determine where you mount the cage as these are the stress points. Put them on the floorboard and they'll go right through a rusty unreinforced floorboard. A good shop should be able to weld in a standard 4-point that will pass SCCA tech inspection for low teens. Figure that if you want to run new seats and 5-point (or 6) harnesses and you're looking at around $2k for the pop. If you look below at how the stock power seatbelt runs, the main hoop has to run as close as possible to that. So you'll have to rip out the motor and wiring. ![]() |
#42 |
I have safety21 7 point bolt in. The backing plates are 6" square with 3 12mm bolt holes in each of them. The bars running up the pillars are mashing the foam covering all the way to tubing. The bar running across roof in the front is also pushing against the roof.
When I was installing the cage I had lay on my back and use my legs to push the bar up to mount it to the roll bar. I am very happy with the rigidity the cage has added. Here are a few shots of mine. ![]() ![]() ![]() ![]() ![]() ![]() Last edited by lok; 02-12-2006 at 01:40 PM.. |
#43 |
Oh well...this is for the guy who started this post: I paid $22 grand for my roll cage. Jk! Actually did mine at Wyotech, West Sacramento. The material only cost me $230, but the timing was about two weeks. So ten days about 6 hours a day. A little long considering we the students sharing tools and this was my first roll cage. You can learn how to weld almost like a pro...see for yourself.
It's a 6 piont rollcage made with 1_1/2 DOM tubing. I read NHRA, SCCA, D1GP, and Formula D rule books carefully before starting this project. So I'm certain that my rollcage will pass inspections along with my welds. |
#45 |
what is the advantage to having a "roof hoop" and "front bars" as opposed to "side-front bars" and a "upper windshield bar"
for imports i almost always see sides and upper windshield. every nascar i've seen has the roof hoop. what the advantages of each kind? |
#46 |
I think the "roof hoop" or halo bar as most people call it allows you to tuck the cage up higher because you have a little more access to weld on the bottom of the hoop, rather then weld the windshield bar up and around the top. I'll be making my cage soon and I think I'll do a hoop for this reason.
