Old 12-24-2006, 12:43 PM   #1
rcantu
rcantu is an unknown quantity at this point
widebody GTS SMOG EXEMPT! OC, CA
car is off market. if I get an offer it has to be upper teens.
This is SMOG exempt so that means you will NEVER have to smog it again. You can do whatever you want to the motor. No more smog checks every 2 years.
here are the mods. I've only had it a couple months but I've started to mod it.
Exterior
New paint (Carrera white)
New OEM Sprinter Taillights
solex locks
New J-blood Replica (full kit)
New Wing molded to trunk w/ keyhole
NEW CBY Flares Replica from Modified inc. Custom install.
NEW Work equip 03 rims. Front 15*8 1/2 - 19 Rear 15*9 -25
Brand new Falken ziex 512 205-50-15 front 225-50-15 rear
Raybrig H4 Housings
Engine
Red top high compression.
New JDM Carbing Oil catch can
New belts
New master brake cyclinder
New Koyo radiator w/ TRD Cap
All new brake calipers front and back
New Brembo cross drilled rotors front and Bradi cross drilled rotors rear
New PBR brake pads
ToysNew braided brake lines, clutch.
Pacesetter header
New JGT500 Exhaust
New OEM radiator overfill tank
New Braille Ultra-Lighweight battery
New OEM plug wires
Drivetrain
New Stage 2 Exedy clutch and Lightened flywheel
New Cusco RS 2.0 2-Way LSD
One piece driveshaft by Illegal Garage
New OEM Toyota diff seals, gaskets, and bearings
New OEM Toyota Rear axle bearings and retainers
New Front Wheel Bearings
Suspension
Tokico HTS Short stroke shocks rear
TRD 5.5 rear springs
TRD Short stroke shocks front
Cusco front coilover sleeves, coils (8 kg), and upper mounts.
New Nagisa Shakito shock tower bars
New T3 Panhard bar with T3 4 Links
New Prothane bushings
New Tanabe rear and front swaybars
Front Cusco Strut Bar
T3 RCA's
Interior
pair Recaro Pole Position
Bride FG Bracket/Rails
New Sparco-Tom's pedals
Black OEM Carpet
New FET Quick Release
New Momo Boss
Nardi 350mm Deep Corn steering wheel
T3 Short shifter
Cusco/Safety 21 5 point rollbar
add up the mods and you know this stuff adds up!
remember the bonus is NO smog checks for life. I have CA plates and CA title.
car is in north orange county.
THESE ARE CLICKABLE THUMBNAILS
rcantu is offline
