Old 05-29-2007, 08:55 PM   #1
250sxdet
250sxdet will become famous soon enough250sxdet will become famous soon enough250sxdet will become famous soon enough
I had the same problem when I first did my swap. Did you swap over your stock temp sensor? I was running dual 12" fans with the stock s14 rad and a nismo thermo it was no good. So i upgraded to an n1 water pump with a greddy radiator. I've had no problems with heating what so ever since then, even at the track. If youre going to track the car, i recommend you upgrade the radiator.
250sxdet is offline   Reply With Quote
Old 05-29-2007, 09:27 PM   #2
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
Make sure the rad fan is pointing the right way.
If yes, then throw another one on the inside to increase the air. Make sure the fan doesnt cut out on you, i'd keep it on all the time, or wire it on a separate switch if you wanted manual control.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 05-29-2007, 09:43 PM   #3
Blackparade
Blackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfectionBlackparade is close to perfection
Griffin radiators are the shit! Defenitly look into that option. Im running a koyo right now due to the fact that it was taking my griifin forever to get here, and my stock rad exploded! grrrrr... had to get something, and every shop i know carries koyos. so....yea. Adress the fan situation!!!!!!!!
Blackparade is offline   Reply With Quote
Old 05-29-2007, 09:49 PM   #4
LB.Motoring
LB.Motoring's Avatar
my Koyo worked Fine.
Just have a nice pair of fans, and a good shroud,
mine are both custom
Robby Leuer
Old 05-29-2007, 10:15 PM   #5
moonshinekouki
moonshinekouki's Avatar
moonshinekouki is an unknown quantity at this point
any tips on making my own shroud ?
thank you
if worse coems to worse ill invset in a good set of fans even tho i spend like 350 on these fans.
thanks guys keep the oipinions comming in
mikey
moonshinekouki is offline   Reply With Quote
Old 05-29-2007, 10:25 PM   #6
bardabe
bardabe's Avatar
thank you
mikey
damn that sucks dude, I spent like 150$ on my fans but they push 2000cfm's each (4000 total) and I'm running a sucky ass S13 KA radiator right now. soon when i get my job I will pay off robby, get me an S14 ka radiator, and go to home depot and make a write up on how to make some good shrouds, I can;t stress enough what Dave said. Ducting will make the biggest difference.
Review Thread
bardabe is offline   Reply With Quote
Old 05-29-2007, 10:31 PM   #7
moonshinekouki
what kind of fans did u get?
what is need to make the shorouddd
lol HELLLLPP
Old 05-29-2007, 10:42 PM   #8
bardabe
bardabe's Avatar
PM Sent. ha ha RB owners trade secret.
Review Thread
Old 05-29-2007, 10:55 PM   #9
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
yeah i tried some high rated 10" fans with my swap... they didn't work. went with FAL dual pushers with should and it was allot cooler.
and i if you find a place that sells griffin S14 KA radiators be sure to let me know. i think that griffin does 1-2 runs of those radiators a year. and the most i have ever seen them ship to a business if about 5 of them (when i got a hold of the company and tracked down a shipment to a reseller en route).
Tenchuu is offline   Reply With Quote
Old 05-29-2007, 10:59 PM   #10
LB.Motoring
Just made one from an aluminum sheet,
cut slits, bent it so its like a tray, then cut the 2 large holes for the super CFM fans, and done.
Robby Leuer
Old 05-29-2007, 11:08 PM   #11
moonshinekouki
ok im going to try this out
Old 05-30-2007, 12:49 AM   #12
coreansurfer
coreansurfer's Avatar
coreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfection
add a second relay to the fans, it'll majorly increase their output and help cool your car. that's what i did to my rb25, and i'm still running stock ka radiator.
Originally Posted by avs0730 View Post
if I stupid why is people pm about the car
coreansurfer is offline   Reply With Quote
Old 05-30-2007, 01:48 AM   #13
moonshinekouki
plzzz moreee detail
Old 05-30-2007, 08:48 AM   #14
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
He is saying to wire your fans properly.... As in, for each fan use thick gauge wire, ~10ga straight off the battery, through a ~20a fuse, through a relay, to the fan motor. Then you wire the relays to be triggered with a manual switch or however you like (ACC relay for on-with-ignition, etc). Make sure your fans are grounded with the same size wire you use to power them with. This will ensure your fans have enough juice for optimum CFM.. But even with proper wiring the fans might still be too small.
How do you have them wired up now? I don't think your wiring is the culprit unless it's some janky ghetto fab.
Step up to some 12s...
MELLO*SOS is offline   Reply With Quote
Old 05-30-2007, 11:28 PM   #15
moonshinekouki
^ u mind telling ur coooling set up
like duccts fans w.e ur running?
thanks
mikey
Old 05-31-2007, 02:03 PM   #16
Rezlo
Rezlo is an unknown quantity at this point
Send a message via AIM to Rezlo
2X 12" CSR fans on a stainless shroud i made that sits about 10mm from the core,
I use an electronic CSR fan controler to turn the fans on at 165f
Apart from that nothing, i dont have the AC condencer though, but i run a 100mm thick intercooler.
Rezlo is offline   Reply With Quote
