Old 11-03-2007, 09:36 PM   #1
mrpeepers
mrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nice
Ok just changed my spark plugs. plug 1 was good with a little burnt oil on the threads and it got worse through 4. Plug 4's threads were soaked in oil. I started the car and it idled fine, but i dont think i solved the problem. Ill check the injectors tomorrow
mrpeepers is offline   Reply With Quote
Old 11-04-2007, 08:50 AM   #2
mrpeepers
hmm i remembered a while back when i was a car noob that i painted my valve cover, but i dont know if i tightened it back per FSM.... ill give this a try
Old 11-04-2007, 09:45 AM   #3
jilo
jilo's Avatar
jilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of lightjilo is a glorious beacon of light
make sure the injectors arent leaking - take the fuelrail off the engine but leave the fuel lines connected. turn the key to the on position (dont start the damn car) and see if the injectors leak.
"just throw in like 8 packs of BBs and do a burnout.
DIY shot peen, done and done."
jilo is offline   Reply With Quote
Old 11-04-2007, 02:52 PM   #4
mrpeepers
I retightened the valve cover today per FSM and found a bad ground so i changed that too. If it starts running rough again i will go with the injectors. Thanks everyone, i guess it wasnt the oil viscosity. Oh and when i pulled off the valve cover there was NO SLUDGE WEEEEEE!
