Old 12-10-2007, 11:03 PM   #31
yokotas13
yokotas13's Avatar
well
cedric is getting push button start....becuase im bored
yokotas13 is offline   Reply With Quote
Old 12-11-2007, 08:59 AM   #32
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
Wow dude nice write up! Very detailed.
Giving you + rep for that, keep up the great work.
Originally Posted by g6civcx View Post
Equipment needed:
* 30A or higher 12V momentary switch
* 12gauge or thicker wiring
* 30A or higher 12V relay with 87a terminal
* other equipment necessary to connect wires
*snipped the pix*
The stock ignition switch works as shown in the chart. Constant power is delivered to the ignition switch via the White wire. When the key is turned to the first position, power is delivered to the accessories. When the key is turned to the second position, power is delivered to the ignition system. When the key is turned to start, power to the accessories is temporarily cut, and power is diverted to the two wires for the starter and the ECU.
*snipped the pix*
I recommend removing pins 4 and 5 from the harness. By doing this, you will no longer be able to start the car with the ignition switch. It is not necessary to remove these pins but I cannot guarantee reliability of the ignition switch because you have current flowing backward through the ignition switch. If you happen to press the push button and turn the key to start at the same time, I cannot predict what will happen.
As such, pins 4 and 5 can be cut and the portion coming from the harness should be insulated and tucked away. See below for how to wire the portion going to the components.
I also prefer to cut the Blue accessories and use a relay to turn off accessories power when the push button is pressed. This step is also not necessary. If you elect not to do this, make absolutely sure you turn off all your accessories before attempting to start the car. A weak battery may not have enough cold cranking amps to start the motor and power the accessories at the same time.
The Black/Red Stripe ignition wire will be tapped as well.
*snipped the pix*
Here you can see the circuit with pins 4 and 5 removed, as well as the open in the Blue wire and the tap in the Black/Red Stripe.
*snipped the pix*
This is pretty simple and self-explanatory. You don't need a fuse or a relay if the push button is rated for at least 30A or higher.
I recommend http://www.longacreracing.com/ for push buttons as well as complete switch panels.
projekt_s13 is offline   Reply With Quote
Old 12-11-2007, 09:00 AM   #33
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
remote start is so much cooler than push button
bigOdom1 is offline   Reply With Quote
Old 12-11-2007, 09:05 AM   #34
projekt_s13
lol, figuring out how to retain your remote start with a push button start is cooler then just remote start.
Old 12-11-2007, 10:01 AM   #35
g6civcx
g6civcx's Avatar
Thanks for the praise.
To the OP, if you want light for the push button, a slick way is to tap the illumination circuit if the light is a small LED bulb. That way, your ignition will come on and off with the rest of the instrument cluster when you turn the lights on.
If you hook the light bulb to the ignition wire the push button will be lighted all the time.
If you have a big ass light bulb then obviously what I said won't apply.
There's no reason why you can't do both. Just treat the push button as part of the ignition switch. You have constant power going in, accessories, ignition, starter, and ECU power going out.
Tap the appropriate wire for your remote starter and you're good to go.
You can even eliminate the ignition switch completely with a Long Acre Race switch panel. It's pretty simple.
Old 12-11-2007, 08:21 PM   #36
.:JD240:.
.:JD240:. is an unknown quantity at this point
that looks great I'll try it out when i get some more time Thanks a lot for the help I really appreciate it
.:JD240:. is offline   Reply With Quote
Old 12-13-2007, 07:27 PM   #37
g6civcx
g6civcx's Avatar
To put this issue to rest, if you have a momentary switch that cannot handle at least 30A, you'll need to put a fuse in front of the switch and use a relay to pull the 30A load.
Hook the output of the button to a standard 12V 30A relay with an 87 pin.
Old 02-24-2008, 02:00 PM   #38
djl601
djl601 will become famous soon enoughdjl601 will become famous soon enoughdjl601 will become famous soon enough
i'm trying to install the engine start with s2000 start button.....do i need to use fuse before the switch and 2 relays? or i can just use one relay and no fuse before button like the last diagram you had in page one....
thanks....
djl601 is offline   Reply With Quote
Old 02-24-2008, 02:25 PM   #39
g6civcx
g6civcx's Avatar
Again, verify with the manufacturer to see if the button can handle at least 30A. In this case you can check with the FSM to see if the buton has a fuse on it. If the fuse is less than 30A, use the same rated fuse. If the fuse is 30A or higher, you don't need a fuse. When in doubt, use a fuse and relays like pictured above.
Come on. I thought this stuff was laid out pretty thoroughly. All you have to do is read and go by it. It's not rocket science.
If you still can't figure it out then don't do it???!!!!!!! It's not something that's absolutely necessary like fixing brakes or getting your daily back on the road. For these issues I would have more sympathy.
There is absolutely no reason why anyone couldn't get it done by following simple directions. I thought I had broken it down pretty much for any brain dead person. If you feel my writeup is deficient then tell me why.
Old 11-08-2013, 08:07 PM   #40
elnino335
elnino335's Avatar
elnino335 is an unknown quantity at this point
Yea i know its an old ass thread but Its the only one i found with a diagram my question to the diagram above is where do i add the switches ?
elnino335 is offline   Reply With Quote
Old 11-08-2013, 08:11 PM   #41
oni jake
oni jake is an unknown quantity at this point
Wherever you want. Most switches are somewhere in the 5 to 10 amp range, so you will want the switches controlling relays. I made this diagram up for those attempting to create a harness from scratch. Hopefully it helps
oni jake is offline   Reply With Quote
Old 11-09-2013, 09:38 AM   #42
elnino335
elnino335's Avatar
Thanks Oni jake for the reply and diagram now i understand the diagram but will it work with an s13 chassis ?
Old 11-09-2013, 09:43 AM   #43
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
Holy old thread. lmfao best rival ever. Should work on S13 chassis no prob
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 11-09-2013, 04:14 PM   #44
oni jake
Well, you know, props to him searching.
This diagram will work for basically anything, as that is the bare minimum to get a car running and into a competition, NOT STREET LEGAL. The only difference you would have comparing that diagram to another chassis and motor is the amount of ECU fuses and harness connecters (lets say, an extra bumper light or another gauge/sensor). This diagram doesn't break down the ECU harness either, but all of the information needed can be gathered from your motor's FSM.
Old 11-12-2013, 02:24 PM   #45
elnino335
elnino335's Avatar
Ok i drew this up...
How i drew it in my head it should work theoretically speaking, can you guys give me some input i printed out the wiring diagram for the starting system and ignition system
Need some input if i drew this correctly or not
Thanks
Old 11-12-2013, 04:22 PM   #46
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
What do you mean, not street legal.... where are you, that they care if you change your ignition switch?
As long as it was sold new with the anti-theft devices mandated at the time, it doesn't really matter what condition they're in, so long as you don't sell something that doesn't work, as working.
mechanicalmoron is offline   Reply With Quote
Old 11-14-2013, 04:15 AM   #47
oni jake
I can't read your hand writing to make out what you are wiring in Elnino. Also, why are two relays connected together twice? How does power to get to the switch in the first place? I can tell you that pin 5 is in fact your starter signal switch.
It's not street legal as in there is no wiring to horns, blinkers, etc. I was simply stating the obvious... because this is Zilvia and if I don't say it, someone will and try to discredit the whole thing. I have no idea why you are talking about anti-theft devices.
Old 11-14-2013, 03:23 PM   #48
elnino335
elnino335's Avatar
I drew it wrong im missing a relay thanks for the reply i wouldnt of noticed it im going to re draw it more clearly
