Old 10-02-2008, 06:24 PM   #31
youngbrazee1
youngbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choicesyoungbrazee1 has made poor choices
My car has been sitting for over 9 months when i finally tried to get it running it would turn over(belts moving)like it wanted to but did not, also the windows or cd player will not workb, but my headlights do. i accidently put the negative on the positive on the car battery. i checked my fuses and the FL100A was blown. i read on how to set my cas and it still wont start. and i replace the spark plugs with ngk ones.
Questions
#1.is my ecu fried?
#2.could it be the starter?
#3.where would i get this fuses from(it doesnt even look like a fuse)?
#4.could the fuse FL100A keep my car from not running?
#5.how do i test the spark plugs?
PLEASE HELP ME
youngbrazee1 is offline   Reply With Quote
Old 10-02-2008, 06:44 PM   #32
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
hey whats up i got a lil problem prolly an easy fix im doing the 300zx brake conversion and was up to where i needed to put a flare fitting inside the bmc in the middle fitting (i have the biggest one from a 300tt). well my friend ruined all 3 fittings on my stock bmc trying to cut it out. is there a way i could just buy a flare or do i need to find a whole bmc and cut that out thanks in advance!
lazysk8er2 is offline   Reply With Quote
Old 10-02-2008, 08:21 PM   #33
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
Originally Posted by blu808 View Post
Sounds like you need something to control those injectors. Like a AFC or emanaage, or some baller setup using a standalone.
Yeah i have an safc2 i need to install, but i think the n62 maf i got might be bad. Ill try testing with a voltmeter. and their were no rags stuck in intercoller
WangonwWarrior is offline   Reply With Quote
Old 10-02-2008, 10:49 PM   #34
blu808
blu808's Avatar
youngbrazee1: I have had that happen a few times. Sometimes it just burns out some fuses, other times it wipes out the whole cars electrical system. I would suggest getting a new car. Or at least a new ecu, engine harness, chassis harness. Sorry but it is really a pain in the ass. Also check all the fusable links.
lazysk8er2: It really depends how bad it got messed up. I would really have to see it. Sorry. Maybe post up a picture?
WangonwWarrior: Well you have to consider that the ecu has no idea that you changed the injectors in the first place. I would hook up that AFC and set the correct values.
Let me know guys.
Manji Parts : Home
Old 10-03-2008, 11:01 AM   #35
blackcoupe
blackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the roughblackcoupe is a jewel in the rough
Here's one. I have a s14 SR motor in an s13. It has random issues starting. Doesn't crank just clicks and all electricals work fine (lights, radio, interior lights). To get it started I have to just flip the ignition on and off until it catches and starts. Basically the car starts first try when it wants to.
Battery tested - Good
Starter tested at Kragen - Good
Ignition Switch - Looks fine, I was able to replicate the issue using a screw driver, so it's not getting worn down or anything like that.
blackcoupe is offline   Reply With Quote
Old 10-03-2008, 11:23 AM   #36
xsublimefrekx
xsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choicesxsublimefrekx has made poor choices
I have one if you can help. I have a 98 s14 with a ka-t in it and I'm having problems with my speedo. I lowered the car a the harness got screwed up but I fixed that and checked and replaced blown fuses. Now the only thing that doesn't work is the speedo and odometer and I'm stumped on what it can be. Any help would be awesome. Thanks
xsublimefrekx is offline   Reply With Quote
Old 10-03-2008, 11:52 AM   #37
Def
Make sure you still have the nub which presses down on the clutch safety switch.
Old 10-03-2008, 12:18 PM   #38
blu808
blu808's Avatar
Cold start wire is not hooked up. On the s13s with s14 srs you need to find the cold start wire and put it to the cranking + signal.
Old 10-03-2008, 12:18 PM   #39
blu808
blu808's Avatar
Did you replace your cluster?
Old 10-03-2008, 12:37 PM   #40
xsublimefrekx
no i didnt try that yet, i was hopping it wasnt that. At one point the tach, temp and fuel gauge didnt work and i replaced the fuse and all that came back on. Ill try to replace the cluster
Old 10-03-2008, 12:44 PM   #41
blu808
blu808's Avatar
Well the problem with rubbing your harness on the left front wheel is that it can just completely short everything out. You are lucky that those still work at this point. You should try swapping the cluster.
Luke
Old 10-03-2008, 01:31 PM   #42
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
I have a problem. Wrote in tech help section, but about two months ago after finish swapping my brothers sr motor (had been sitting for about 5 months) into my shell. It ran perfectly before we stored it (due to college).
After swapping it, and test driving it around the block maybe 4 times (under 2 miles), it started squeeking and then tapping (sound like its coming under the valve cover but not sure). The oil pan is just barely dented where the drain plug is and thats all. I've had people tell me its a rod knock, rod bearing, and/or cam shaft and HLA's because oil pump could be dead.
Tried switching to thicker oil and it got quieter, drained it for a week and added same oil and it got loud again. What do you recommend i do first, new rods, rod bearings, oil pump, or HLA's? If you were closer to 209 area, i would pay for gas and then some you to come check it out.
bl3ujay07 is offline   Reply With Quote
Old 10-03-2008, 03:52 PM   #43
Def
Bang out the oil pan and see how it does. It doesn't take long at all to take it off.
Old 10-03-2008, 08:10 PM   #44
WangonwWarrior
Master blu808 i need you again. I installed my SAFC2 and came up with a default setting that i have seen others run and it has smoothed out the revs a little bit but my big problem is whenever i crank the car it idles fine at about 1k rpm then after about 5 sec it slowly dies. I just put a N62 maf on and i triple checked and search and it is installed correctly. But me and a few people think the maf could be bad. Do you think it is the maf or is my BOV causeing this? Thanks -Mike
Old 10-03-2008, 08:37 PM   #45
90drftsx
90drftsx is making a name for him/her self90drftsx is making a name for him/her self
I tried taking out the oil pan but it was hard as hell. Mallet, flat screwdriver, blade to get in between the oil pan but still wouldnt budge. I dont think it would be the oil pan because it was dented when it was on my brothers car and it ran fine.
Shit, just posted using my brothers accounts. Sorry about that
90drftsx is offline   Reply With Quote
Old 10-03-2008, 09:14 PM   #46
blu808
blu808's Avatar
Well not only do Oem SR pans suck on the track, but if they get even a small dent, they can block the oil pickup tube.
The first sign of oil not circulating through the engine on a sr20det will be the squeeking sound you heard. That is actually coming from the cams. If you have heard that noise and it is now making a tapping sound, then your motor is most likely a paperweight now.
Possible things that can cause oil pressure failure:
Oil Pump broken
Oil pickup broken (common on srs)
Oil pickup blocked
loose oil line
low oil level
Old 10-03-2008, 09:16 PM   #47
blu808
blu808's Avatar
On the setup page where it says in1 out1 what do you have it set too?
Try setting it to in5 out1
Old 10-03-2008, 09:22 PM   #48
blu808
blu808's Avatar
It only takes about an hour using jackstands.
Steps.
Put car up on jack stands using proper lifting points.
Remove the 10mm bolts that hold the pan on.
Break the seal using either a putty knife, screw driver, and a rubber mallet.
Romove oil pan
place oil pan on sand bag, and beat the dent out.
Check the condition of the oil pickup to ensure its not clogged up with rtv.
Remove all RTV from upper oil pan and lower oil pan. take your time do it all.
Reapply a minimum amount of rtv to the oil pan. (i see sr's blow all the time bc of too much rtv getting stuck in the oil pickup.
Reinstall oil pan, and enjoy!
If it still makes noise and is not leaking you should replace the oil pump and oil pump drive gear.
I suspect that you have caused terminal damage to your engine at this point though.
Old 10-03-2008, 10:08 PM   #49
WangonwWarrior
Everyone says to run 2 in and 5 out but their is another setting page asking the same thing so i put 2 in and 5 out that setting as well. Im reading 0 air flow on the safc. I read that when installing the z32 maf the white z32 wire must be soldered to the white ka harness and not just crimped. I will try soldering the two together and see what happens. Ill do some more research and make sure i have the safc wired properly to the ecu. Thanks again i wish i could posi rep you
Old 10-03-2008, 10:31 PM   #50
proxy0000
proxy0000 is an unknown quantity at this point
Wow I should've read this before I wrote up that thread...
Uh... this isn't really an emergency but whenever you have the chance to do you think you could help me? Thanks .
LINK
proxy0000 is offline   Reply With Quote
Old 10-03-2008, 11:06 PM   #51
S14Jer
S14Jer is an unknown quantity at this point
I am debating on whether to pay a shop to do this or have my friends dad (a mechanic) help me with this but Ide like to know what im dealing with first.
Here is my problem, whenever i push the clutch in and put the car in gear it makes a horrible whining noise but when i let the clutch out and its all in gear its fine, no noise. I found this on youtube and it is the exact same noise and time that mine happens
YouTube - Clutch Noise?
I also noticed recently that If have the clutch pushed in and the car in 1st it will randomly barely start to grab and move the car little bits at a time even though the clutch is to the floor.
Any ideas on what could be wrong?
Thank you in advance for any help
S14Jer is offline   Reply With Quote
Old 10-03-2008, 11:26 PM   #52
WangonwWarrior
Throw out bearing, maybe even old pressure plate about to pop. Nothing to be too worried about but fix it sometime
Old 10-03-2008, 11:33 PM   #53
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
does that PP have Springs?
TOB
Pilotbushing/bearing?
importdude is offline   Reply With Quote
Old 10-03-2008, 11:46 PM   #54
WangonwWarrior
TOB
M bad i got these mixed up with my chevy. Its probably the throwout bearing, correct me if i am wrong but im 95% sure
Old 10-04-2008, 12:15 AM   #55
blu808
blu808's Avatar
Replied to your thread.
LINK
Old 10-04-2008, 12:17 AM   #56
blu808
blu808's Avatar
Throwout bearing would be my guess.
Old 10-04-2008, 06:35 AM   #57
WangonwWarrior
What ya think?
Old 10-04-2008, 07:55 AM   #58
S14Jer
Thats what I am thinking, thanks for the help. I wonder what a mechanic would charge for that... I dont really know where to go to get it done either there are NO good performance shops anywhere near Grand Rapids MI. I dont know if I trust a regular shop to work on the SR20
Old 10-04-2008, 08:54 AM   #59
S14Jer
Oh hey one more quick tech question. I bought this car from someone else and he had the BOV hooked up wrong so I connected it to the intake mani. Its a Greddy type R, no matter how loose or tight I make it the thing doesnt work, I still have compressor surge. Any ideas?
Old 10-04-2008, 12:02 PM   #60
lazysk8er2
lazysk8er2's Avatar
heres the pics for my ques on the flare fitting on the bmc can you tell me what my options are thank you
