Old 08-30-2009, 09:53 PM   #1
ashtonroche
ashtonroche is an unknown quantity at this point
Some FWD Nissan Love..B13 Sentra Big Turbo
Alright before i get any hate on this ill say ive been apart of this forum for a while now and have many buddies with 240's and ive fully built rwd sr20 motors just as much as fwd ones. Ive done s13 sr20 swaps in 240's and you name it, ive probably done it. Anyways here is the setup:
92 Nissan Sentra Se-r
Fully built SR20, all work done by me and noone else.
SR20VE block
SR20DE crank
ACL race rod and main bearings
SR20VE oil pump, pickup tube, spacer and aluminum underdrive pulley.
Eagle Rods
CP pistons 8.5:1X 86.5mm bore
Cosworth 1.1mm headgasket
Golden Eagle Honda B16A vtec head studs
JWT S4 cams
All new gaskets and seals
Walbro 255lph fuel pump
Venom 740cc injectors
Calum ecu tuned by me
Z32 fuel filter
RWD tubular t3 topmount manifold rewelded and braced
T3T04 60 trim turbo with the larger .82 turbine housing
Tial 38mm wastegate
Custom made by me 3" downpipe dumping straight down under the car
AEM wideband o2
AEM Truboost boost controller set to 18psi low, 26psi high
Autometer Oil pressure guage
Tial 51mm bov
Z32 maf
3" piping
32X12X4" fmic
Drivetrain
Stock b14 se-r transmission with stock axles
Fidanza 8.8lb flywheel
ACT extreme PP with 6 puck sprung disk
Cooling
Mezier water pump block off and electric water pump
Honda Civic single wide two core aluminum radiator
Flexalite 12" 1250 cfm fan
Custom aluminum crossover pipe
Suspension
Ground control coilovers
GR2 struts
ES bushings all the way around
Weight reduction
No A/C
No P/S
No front or rear bumper support
Nothing in the bay that isnt needed to run the motor
Nothing behind the dash such as all a/c stuff
Nothing behind the front seats
All tar and sound deadning removed
No exhaust or heat sheilds under the car
Car weighs in at 2080 lbs without me in it.
Here is some pics and vids of the car and PS: i daily drive this car every single day in AZ 120 deg summer weather 60 miles round trip to work and so far no problems other than the crappy stock trannies but next week comes a bullet proof P11 LSD trans
Car has gone a best soo far of [email protected] mph on bald slicks with no life on them in 90+ deg heat. Much more to come from this car when it cools down.
YouTube - Nissan Sentra Turbo runs 11.10@ 131.43mph vs mod GSXR 750 bike
YouTube - 700awhp Lancer Evo vs 500whp Nissan Sentra SE-R
YouTube - Turbo Sentra Se-r SR20 vs Mustang
Here is a vid of the car on 18psi street tires.
YouTube - Nissan Sentra Se-r build in action Turbo SR20DET
Enjoy and any comments appreciated.
ashtonroche is offline   Reply With Quote
