01-14-2010, 07:10 AM | #33 |
probly around the $200 ballpark for the extrude hone from the local machine shop. i was also looking at the tomei expreme manifold because its basicly the same thing as a ported out stock manifold since its based on the same design.
I also found this flow graph on the web: |
01-14-2010, 08:34 AM | #34 |
i am using an extra t3 flange on my civic to space the comp housing away from a runner. Seems to work for me, just make sure and use new gaskets and studs so you can really get a good seal.
01-14-2010, 05:28 PM | #38 | |
But if it does take a shit, I will just order darton sleeves and 90mm 9:0:1 pistons along with other goodies. thats my .02 on it. |
01-14-2010, 05:42 PM | #39 | |
01-15-2010, 03:38 PM | #40 |
Update the Megan manifold works my friend just didnt clock it in the right position.
Had some more things to pick up that were at the shop for a while... Tial V44 AEM EMS And the MYSTERY BOX Inside: Origin Stream Bodykit 20mm front fenders 30mm rear over fenders Ordered an ACT Extreme pressure plate from FR Sport yesterday should come in aprox a week and a half I will get more pics of the other parts etc boost solenoid and map sensor , flywheel and others. ^^was alot of money^^ |
01-20-2010, 12:12 AM | #42 |
I have tuned a couple of T28 Turbine equipt cars to hi 400-430 whp, which on my dyno is A LOT. thats around 475 on a dynojet!
I know... Both cars used GT3071R and GT3076R with T28 flanges
Like Me on FaceBook ! |
01-20-2010, 12:16 AM | #43 |
Trader Rating: (58)
Feedback Score: 58 reviews
With E85 and boost you should have no issue. High 300's are possible with smaller compressors on pump gas, so with the addition of a MUCH larger compressor housing, and the fact you are running race gas, i would say that if you don't hit that power, I would be upset.
Good luck, and damn you for having easily accessible E85 hehe
01-20-2010, 12:22 AM | #44 | |
Trader Rating: (58)
I put forged CP pistons (86mm stock bore, 8.5 compression stock) in the motor now for 3 years on stock rods. I melted a hole in a piston shortly after those first video'd dyno pulls lol. I was WOT, 20 psi, going from 3rd to 4th when it felt like an intercooler coupler popped. Did some quick troubleshooting on the side of the highway, and then drove it off (shitty, sputtering, crappy) to an exit where I was seeing if a coil died. Everythign was workign, so I knew something BAD happened. Drove it to eat, drove it home (35 miles), and beat the fuck out of it as it was fubar by my book. Ripped the head off that same night to find the 'wussiest' blown engine ever. My 'theory' of to why it exploded was that the big intake gromets popped up around the injector, causing it to go lean. Wideband was perfect mid 11's all the time. I ended up getting a special cover for the greddy rail and haven't had an issue since. What I did to fix the gromet The new (well not new, as it's got near 18,000 miles on the motor) motor has been fine since, and this was the motor I went 11.65 @ 120 with (1.88 60'). I wish I had more practice and more than 3 runs as I know I'd have that 60 into the low 1.6's, and have the times in the damn low 11's. Aside from that, it's nothign fancy. Jim Wolf Tune, Jim Wolf S3 cams, and the basic bolt ons. No headwork, no fancy bottom end work either, as I do all the work and don't have the tooling or the knowhow to get fancy with anything.
01-20-2010, 12:27 AM | #45 |
Trader Rating: (58)
why a kaboom? With E85 detonation should be easily controlled. The stock parts strength isn't the question, it's always been their detonation resistance.
01-20-2010, 02:42 AM | #46 | |
i got a s13 sr that im building right now which is sitting in my room almost assembled. bottom: 86.5mm 8.5:1 CP pistons eagle rods apexi HG arp mains arp headstuds block decked, honed, bored align hone mains grade 2 OEM main bearings grade 1 OEM rod bearings crank poilished and balanced ATI damper (whole assembly balanced) top: BC springs and retainers BC 1mm+ intake and exhaust valves supertech valve seals and valve guides JWT s4 cams new OEM rocker arms new shims and guides apexi HG the turbo that im going with is a turbonetics t3/t4, stage 3 wheel, .63 AR, 57 trim compressor wheel. its going to be a journal bearing turbo and it comes with log manifold, wastegate, dumptube, all lines and hardware, intercooler and piping, etc. i have a good idea what my power is gonna be but i would like your input on it cody? |
01-20-2010, 04:54 AM | #47 |
i just dont think 740cc injectors would cut it for that much power for e85. just remember you will need approximately 30% more by volume to make the same amount of power as you would if you weree running pump gas. I would go 1000cc injectors and run dual walbro pumps and hardwire them with seperate relays so you dont get voltage drop and run a nice aeromotive FPR. I just believe that you would be running too high of an injector duty cycle to be safe and reliable. Im sure you can make the dyno say 429hp for a few pulls with the setup you would like to run but thats just maxing out everything you got and not even safely, like a ticking time bomb. lol thats just my personal opinion. I also would run E98 instead and buy a custom top mount manifold from me ill cut you an awesome deal for something like a peakboost one that will accomodate that turbo and wastegate configuration, A one off peice constructed by my best friend who builds manifolds for a living. i know the motor itself would be able to handle 400hp as long as you have headstuds and a headgasket its just a matter of how long. Maxxing the setup out like you are tryign to do does not leave any room for error. The slightest lean condition caused by a loose vacuum line and you overboost will DESTROY your motor. I as well want to make about 400whp on a stock motor, if you search for my for sale ad you wil see what i have for a car. 740s as well but with pump gas and i would like to do water methanol injection. i will post dyno results soon. Oh btw, intercooler cores make a HUGE difference. A cheap core versus a nice core will allow you to flow to make mroe power. a buddy of mine was running an ebay core with a nice setup similar to yours and it couldnt hit overe 360hp and when he swapped to a nice kit he made 30rwhp right away. Precision and spearco make great cores as well as most name brand bar and plate style intercoolers. anyways this is just MY OPINION so if you disagree lemme know what you think and why.
01-20-2010, 05:29 AM | #48 | |
Before i converted to E-85 i was going to do meth injection. meth injection is good for about 30whp or some more and you can run the boost even higher as it puts the air temp way down. As of now im waiting on my buddy to do a mock up of the turbo set up so i could supply pics for the members on here that are interested in the fitment of the turbine housing. My ACT Extreme pressure plate is supposed to come in tomorrow from FRSport then the tranny can go back on. |
01-20-2010, 08:38 AM | #49 | |||||
Trader Rating: (58)
In regard to my detonation comment, with a Forged piston in there, some detonation isn't going to 'melt it' or chip it nearly as easy as it would with stock. Quote:
Sounds good on paper, but I'm unsure about mixing a tad bit of e-85 with regular gas (as in, is this possible without negative mixing effects?) Quote:
01-20-2010, 08:53 AM | #50 |
just in case u need some 1000cc injectors i have 4 for sell....pm me
TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
01-20-2010, 07:44 PM | #51 |
with my setup im using 740cc injectors. ive seen some videos of guys running them on 400whp+ applications with acceptable duty left for error.
what clutches do some of you guys use/recommend for street/daily use on a 400whp sr with 320-350wtq? |
01-20-2010, 08:48 PM | #52 |
yea exactly my point about the Ebay intercoolers. they work but not WELL. yeah you can get 400+hp on 740s with pump or race gas, but itd be very close call with ethanol. If you are going to run a full stand alone there is really no such thing as OVERKILL when it comes to running large injectors. Why try to compromise the integrity and reliability of your motor just to prove you can make 400 on your setup. If you dont wanna spend alot of money go the safe route and run plenty of injector, a good fuel system, standalone, and some good tuning. I will try and achieve similar power goals with my T3/T04e turbo, a topmount ramhorn manifold, AEM truboost, 740cc injectors, z32 maf, Denso Supra TT OEM fuel pump, Tomei type S FPR, and a custom built HIGHflow intercooler set up in a Vmount configuration. fully stock internal motor, I only have Rocker arm stoppers. Oh, and im running a RS enthalpy ECU. i realistically will probably only make 320 rwhp on the mustang dyno but i might try a pull to see if I can hit 400rwhp on high boost with water meth injection. If I am not satisfied with that setup I will go E85 with 1000-1600cc injectors, dual Denso fuel pumps, -8 fuel lines, AEM EMS, GT3076. lol of course no maf and convert to speed density just cus its the SHEEEIIIT! I dunno what do you guys think?
01-20-2010, 11:10 PM | #53 |
i dont see the big deal in running such large injectors really with a t3/t4 turbo. 740s should cover it plenty. i have my haltech ems sitting right next to me so ill be using that 1000cc injectors for a 400whp sr20 is overkill in my opinion. i didnt even need 740cc injectors to make 400 in my gt28 ZC crx lol. i just used some bluetop dsm injectors and called it a day.
i guess ill see when i get my car on the dyno. |
01-21-2010, 01:47 AM | #54 | |
01-21-2010, 12:16 PM | #56 |
im interested in this thread lol. i would go w at least 1000cc injectors. i maxed out the 740's at around 20 to 21psi
want to be in the 500whp club by the end of next year!!! |
01-21-2010, 03:34 PM | #60 |
oh, forgot to add that this was with E85. you know the whole extra 30% fuel and blah blah blah
this was with a 2871r. my bad for not ebing specific
