Old 04-15-2010, 08:04 PM   #31
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
I think DALAZ is talking about the "rag joint" that connects 2 parts of the steering column in the engine bay before it gets to the rack. I could definitely see this as a possibility for the cause of your problem. Its basically like a flex joint. At this point I think its worth checking out. GL.
mxexux is offline   Reply With Quote
Old 04-15-2010, 10:43 PM   #32
slider2828
slider2828's Avatar
I think you have center play in the rack bro.... If yo replaced ALL that stuff, yu have probably a jacked up rack.... replace it....
Turn and Burn!
Old 04-18-2010, 11:09 PM   #33
klattr1
klattr1's Avatar
klattr1 is on a distinguished road
how old are your motor mounts?
klattr1 is offline   Reply With Quote
Old 06-13-2010, 04:27 PM   #34
GuardianLlama
GuardianLlama's Avatar
GuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfection
EFFFFF i replaced my rack and the problem persists. Although steering feels a ton better and the shake seems more constant. Maybe my brand new wheels came bent. Who knows.
GuardianLlama is offline   Reply With Quote
Old 06-13-2010, 05:13 PM   #35
J40sx
J40sx's Avatar
J40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choices
i have almost the same suspension set up as you. Mine started to shake like crazy also but this is after a year or so from the install, i found that i had low tire pressure, so i just added more air and the it took away most of the shaking, Now it just shakes around 65mph a little
dying is only living, dying to live
J40sx is offline   Reply With Quote
Old 06-13-2010, 08:11 PM   #36
Triperformance
Triperformance is an unknown quantity at this point
Some things I noticed people skipped over to check. 1 piece drive shaft, did it come balanced and is it positioned strait. The other thing could be your tires needing road force balanced (this is when the actual tire is deformed or belt shifted and such). Its common in aftermarket low profile tires. I have always been a Michelin guy cause I have never had an issue with shifted belts but thats a person perference. I think the standard light vehicle tire has a 30lb road force out of round limit, over that and you will have an issue. I agree with rack bushing as well, replaced mine when i had a vibration over bumps doing hard turns. I would start with bushings/obvious stuff first....expecially new parts, inspect everything and make sure nothings loose.
Triperformance is offline   Reply With Quote
Old 06-14-2010, 11:54 AM   #37
slider2828
slider2828's Avatar
Driveshaft makes a huge difference, did you check your subframe bolts? I believe all of it should be torque to 80 ft/lbs same with the rack... Check that... also look for tie rod play and lower ball joint play...
Turn and Burn!
Old 06-15-2010, 08:23 AM   #38
GuardianLlama
I have a new 1 piece driveshaft.
Any yes i have re-tightened my front subframe.
Basically everything is new up front so i dont know what would be worn out.
Old 07-08-2010, 08:25 PM   #39
hondanissan
hondanissan's Avatar
hondanissan is on the path to ruinhondanissan is on the path to ruin
i've got the same problem and i've also done just about as much as you. i just checked my drive shaft just now and it seems to be solid. ...btw, how do i know if the u joints or shaft itself is bad??
hondanissan is offline   Reply With Quote
Old 07-09-2010, 11:05 PM   #40
slider2828
slider2828's Avatar
You can't do it yourself... You must have a driveshaft shop check it... TRUST ME!!! Its worth the money..
Turn and Burn!
Old 07-09-2010, 11:06 PM   #41
slider2828
slider2828's Avatar
Wheel bearing?
Turn and Burn!
Old 07-25-2010, 05:21 PM   #42
Gladman
Gladman's Avatar
Gladman is an unknown quantity at this point
Send a message via MSN to Gladman
Did you ever figure this out?
I did a google search and came up with this topic, havent posted here in ages.
But after doing a 5 bolt swap, new Q45 brakes and wheels I have this problem.
The wheel shakes from 55mph > 80mph and it shakes on and off, it basically shakes for 2 seconds, then nothing for 2 seconds.
The wheels/tires came brand new road force balanced and they shook from the get go. I replaced the front tires and had them rebalanced and the problem didnt go away. I replaced the front wheel bearings, checked the ball joints, tie rods and still shaking.
I've read about the centering spring a couple times now and Im trying to find someone who has actually replaced this. Im getting sick of taking $100 shots in the dark that arent fixing my problem!
Kick Ass 2.4Liter Engine!
Gladman is offline   Reply With Quote
Old 07-25-2010, 06:00 PM   #43
Gladman
Gladman's Avatar
Quick thought update...
I decided to go pull out the centering spring on the rack to see if it was flattened out or something and made an interesting discovery.
With the spring completely removed I can move the steering wheel back and forth the exact same distance that it vibrates under speed without the rack moving. The shaking looks to be directly related to the distance of play in the rack when this spring is removed, which might suggest the tension is too loose and it allowing a miniscule amount of poor balance to effect steering.
Old 07-26-2010, 01:12 AM   #44
slider2828
slider2828's Avatar
There is a nissan tech bulletin out for this.... the part is a spring basically.....
Turn and Burn!
Old 07-27-2010, 01:19 AM   #45
Gladman
Gladman's Avatar
Got new tires, went under the car, cranked the adjustment bolt a 1/4" turn and all vibrations are gone. I doubt you need a new spring, that is just OEM propaganda. The spring itself still holds tension for a given torque spec, so just retorque to the SB spec and you should be good to go.
Old 05-09-2011, 01:56 PM   #46
hondanissan
did you ever find out what the problem was???? my car is still doing it...now i just want to get rid of it cuz i cant figure it out...boohoo.
Old 10-20-2011, 07:14 PM   #47
jacobcartmill
jacobcartmill is an unknown quantity at this point
my S14 is doing this.
i just replaced my tension rods and it did not help at all.
the shaking is violent from ~50-60 mph... like scary.
anyone every figure this out?
jacobcartmill is offline   Reply With Quote
Old 10-21-2011, 09:42 AM   #48
slider2828
slider2828's Avatar
Did you check the rack for play? did you check your wheel bearings for play. Toe rod? What have you checked?
Turn and Burn!
Old 10-21-2011, 09:42 AM   #49
slider2828
slider2828's Avatar
Check tie rod, ball joints on the arms and bolts...
Turn and Burn!
Old 10-21-2011, 11:50 AM   #50
BTplaya
BTplaya's Avatar
BTplaya is an unknown quantity at this point
I had this problem last year. I checked everything up front. Ended up being one of my rear sturts was blown.
95' S14 w/ SR20DET - 412hp
BTplaya is offline   Reply With Quote
